Object Attributes Handler. More...
Modules | |
Classic Attributes Implementation | |
#define | RTEMS_DEFAULT_ATTRIBUTES 0x00000000 |
This is the default value for an attribute set. More... | |
#define | RTEMS_LOCAL 0x00000000 |
This is the attribute constant to indicate local resource. | |
#define | RTEMS_GLOBAL 0x00000002 |
This is the attribute constant to indicate global resource. | |
#define | RTEMS_FIFO 0x00000000 |
This is the attribute constant which reflects that blocking tasks will be managed using FIFO discipline. | |
#define | RTEMS_PRIORITY 0x00000004 |
This is the attribute constant which reflects that blocking tasks will be managed using task priority discipline. | |
#define | RTEMS_NO_FLOATING_POINT 0x00000000 |
This attribute constant indicates that the task will not use the floating point hardware. More... | |
#define | RTEMS_FLOATING_POINT 0x00000001 |
This attribute constant indicates that the task will use the floating point hardware. More... | |
#define | RTEMS_SEMAPHORE_CLASS 0x00000030 |
This is the mask for the attribute bits associated with the Classic API Semaphore Manager. | |
#define | RTEMS_COUNTING_SEMAPHORE 0x00000000 |
This attribute constant indicates that the Classic API Semaphore instance created will be a counting semaphore. | |
#define | RTEMS_BINARY_SEMAPHORE 0x00000010 |
This attribute constant indicates that the Classic API Semaphore instance created will be a proper binary semaphore or mutex. | |
#define | RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020 |
This attribute constant indicates that the Classic API Semaphore instance created will be a simple binary semaphore. | |
#define | RTEMS_NO_INHERIT_PRIORITY 0x00000000 |
This attribute constant indicates that the Classic API Semaphore instance created will NOT use the Priority Inheritance Protocol. | |
#define | RTEMS_INHERIT_PRIORITY 0x00000040 |
This attribute constant indicates that the Classic API Semaphore instance created will use the Priority Inheritance Protocol. More... | |
#define | RTEMS_NO_PRIORITY_CEILING 0x00000000 |
This attribute constant indicates that the Classic API Semaphore instance created will NOT use the Priority Ceiling Protocol. | |
#define | RTEMS_PRIORITY_CEILING 0x00000080 |
This attribute constant indicates that the Classic API Semaphore instance created will use the Priority Ceiling Protocol. More... | |
#define | RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000 |
This attribute constant indicates that the Classic API Semaphore instance created will NOT use the Multiprocessor Resource Sharing Protocol. | |
#define | RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100 |
This attribute constant indicates that the Classic API Semaphore instance created will use the Multiprocessor Resource Sharing Protocol. More... | |
#define | RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000010 |
This attribute constant indicates that the Classic API Barrier instance created will use an automatic release protocol. | |
#define | RTEMS_BARRIER_MANUAL_RELEASE 0x00000000 |
This attribute constant indicates that the Classic API Barrier instance created will use the manual release protocol. | |
#define | RTEMS_APPLICATION_TASK 0x00000000 |
This attribute constant indicates that the task was created by the application using normal Classic API methods. | |
#define | RTEMS_SYSTEM_TASK 0x00008000 |
This attribute constant indicates that the task was created by RTEMS as a support task. | |
Typedefs | |
typedef uint32_t | rtems_attribute |
This defines the type used to contain Classic API attributes. More... | |
This encapsulates functionality which defines and manages the set of Classic API object attributes.
This include file contains all information about the Object Attributes Handler.
#define RTEMS_DEFAULT_ATTRIBUTES 0x00000000 |
Referenced by rpcUdpCleanup().
#define RTEMS_FLOATING_POINT 0x00000001 |
There will be a floating point context associated with this task.
Referenced by _Attributes_Is_floating_point().
#define RTEMS_INHERIT_PRIORITY 0x00000040 |
Referenced by _Attributes_Has_at_most_one_protocol(), and _Attributes_Is_inherit_priority().
#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100 |
Referenced by _Attributes_Has_at_most_one_protocol(), and _Attributes_Is_multiprocessor_resource_sharing().
#define RTEMS_NO_FLOATING_POINT 0x00000000 |
If the architecture permits it, then the FPU will be disabled when the task is executing.
#define RTEMS_PRIORITY_CEILING 0x00000080 |
Referenced by _Attributes_Has_at_most_one_protocol(), _Attributes_Is_priority_ceiling(), and rtems_semaphore_create().
typedef uint32_t rtems_attribute |
These are primarily used when creating objects.
