Partition_Control Struct Reference
The following defines the control block used to manage each partition. More...
#include <part.h>
Collaboration diagram for Partition_Control:
Collaboration graph
[legend]
Objects_Control Object
 This field is the object management portion of a Partition instance. More...
void * starting_address
 This field is the physical starting address of the Partition. More...
intptr_t length
 This field is the size of the Partition in bytes. More...
uint32_t buffer_size
 This field is the size of each buffer in bytes.
rtems_attribute attribute_set
 This field is the attribute set provided at create time. More...
uint32_t number_of_used_blocks
 This field is the of allocated buffers. More...
Chain_Control Memory
 This field is the chain used to manage unallocated buffers. More...
Field Documentation
◆ attribute_set
rtems_attribute Partition_Control::attribute_set
◆ length
intptr_t Partition_Control::length
Referenced by _Partition_Is_buffer_valid().
◆ Memory
Chain_Control Partition_Control::Memory
Referenced by _Partition_Allocate_buffer(), and _Partition_Free_buffer().
◆ number_of_used_blocks
uint32_t Partition_Control::number_of_used_blocks
◆ Object
Objects_Control Partition_Control::Object
Referenced by _Partition_Free().
◆ starting_address
void* Partition_Control::starting_address
Referenced by _Partition_Is_buffer_on_boundary(), and _Partition_Is_buffer_valid().
