31 #ifndef _RTEMS_RTEMS_PART_H 32 #define _RTEMS_RTEMS_PART_H 87 void *starting_address,
uint32_t rtems_attribute
This defines the type used to contain Classic API attributes.
Definition: attr.h:44
Objects_Control Object
This field is the object management portion of a Partition instance.
Definition: part.h:57
The following defines the Object Control Block used to manage each object local to this node...
Definition: score/include/rtems/score/object.h:232
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: rtems/include/rtems/rtems/types.h:80
This is used to manage a chain.
Definition: score/include/rtems/score/chain.h:83
void * starting_address
This field is the physical starting address of the Partition.
Definition: part.h:59
rtems_status_code rtems_partition_create(rtems_name name, void *starting_address, uint32_t length, uint32_t buffer_size, rtems_attribute attribute_set, rtems_id *id)
RTEMS Partition Create.
Definition: partcreate.c:47
intptr_t length
This field is the size of the Partition in bytes.
Definition: part.h:61
rtems_status_code
Classic API Status.
Definition: status.h:46
uint32_t rtems_name
Classic API object name type.
Definition: rtems/include/rtems/rtems/types.h:74
This field is the attribute set provided at create time.
Definition: part.h:65
The following defines the control block used to manage each partition.
Definition: part.h:55
rtems_status_code rtems_partition_ident(rtems_name name, uint32_t node, rtems_id *id)
RTEMS Partition Ident.
Definition: partident.c:28
Chain_Control Memory
This field is the chain used to manage unallocated buffers.
Definition: part.h:69
This field is the size of each buffer in bytes.
Definition: part.h:63
uint32_t number_of_used_blocks
This field is the of allocated buffers.
Definition: part.h:67
rtems_status_code rtems_partition_return_buffer(rtems_id id, void *buffer)
Definition: partreturnbuffer.c:40
rtems_status_code rtems_partition_delete(rtems_id id)
RTEMS Delete Partition.
Definition: partdelete.c:25
rtems_status_code rtems_partition_get_buffer(rtems_id id, void **buffer)
RTEMS Get Partition Buffer.
Definition: partgetbuffer.c:28
