struct | Partition_Control |
The following defines the control block used to manage each partition. More... | |
rtems_status_code | rtems_partition_create (rtems_name name, void *starting_address, uint32_t length, uint32_t buffer_size, rtems_attribute attribute_set, rtems_id *id) |
RTEMS Partition Create. More... | |
rtems_status_code | rtems_partition_ident (rtems_name name, uint32_t node, rtems_id *id) |
RTEMS Partition Ident. More... | |
rtems_status_code | rtems_partition_delete (rtems_id id) |
RTEMS Delete Partition. More... | |
rtems_status_code | rtems_partition_get_buffer (rtems_id id, void **buffer) |
RTEMS Get Partition Buffer. More... | |
rtems_status_code | rtems_partition_return_buffer (rtems_id id, void *buffer) |
rtems_partition_return_buffer More... | |
