Objects_Information Struct Reference
The following defines the structure for the information used to manage each class of objects. More...
#include <objectimpl.h>
Collaboration diagram for Objects_Information:
Collaboration graph
[legend]
Objects_APIs the_api
 This field indicates the API of this object class. More...
uint16_t the_class
 This is the class of this object set. More...
Objects_Id minimum_id
 This is the minimum valid id of this object class. More...
Objects_Id maximum_id
 This is the maximum valid id of this object class. More...
Objects_Maximum maximum
 This is the maximum number of objects in this class. More...
bool auto_extend
 This is the true if unlimited objects in this class. More...
Objects_Maximum allocation_size
 This is the number of objects in a block. More...
size_t size
 This is the size in bytes of each object instance. More...
Objects_Control ** local_table
 This points to the table of local objects. More...
Chain_Control Inactive
 This is the chain of inactive control blocks. More...
Objects_Maximum inactive
 This is the number of objects on the Inactive list. More...
uint32_t * inactive_per_block
 This is the number of inactive objects per block. More...
void ** object_blocks
 This is a table to the chain of inactive object memory blocks. More...
uint16_t name_length
 This is the maximum length of names. More...
Field Documentation
◆ allocation_size
Objects_Maximum Objects_Information::allocation_size
Referenced by _Objects_Free().
◆ auto_extend
bool Objects_Information::auto_extend
◆ Inactive
Chain_Control Objects_Information::Inactive
Referenced by _Objects_Active_count(), and _Objects_Free().
◆ inactive
Objects_Maximum Objects_Information::inactive
◆ inactive_per_block
uint32_t* Objects_Information::inactive_per_block
◆ local_table
Objects_Control** Objects_Information::local_table
Referenced by rtems_iterate_over_all_threads().
◆ maximum
Objects_Maximum Objects_Information::maximum
Referenced by _Objects_Active_count(), _Objects_Get_next(), and rtems_iterate_over_all_threads().
◆ maximum_id
Objects_Id Objects_Information::maximum_id
Referenced by rtems_rate_monotonic_reset_all_statistics().
◆ minimum_id
Objects_Id Objects_Information::minimum_id
Referenced by _Objects_Get_next(), and rtems_rate_monotonic_reset_all_statistics().
◆ name_length
uint16_t Objects_Information::name_length
◆ object_blocks
void** Objects_Information::object_blocks
◆ size
size_t Objects_Information::size
◆ the_api
Objects_APIs Objects_Information::the_api
◆ the_class
uint16_t Objects_Information::the_class
