The following structure defines the port control block. More...
#include <dpmem.h>
Data Fields | |
Objects_Control | Object |
This field is the object management portion of a Port instance. More... | |
void * | internal_base |
This field is the base internal address of the port. More... | |
void * | external_base |
This field is the base external address of the port. More... | |
uint32_t | length |
This field is the length of dual-ported area of the port. More... | |
Each port has a control block associated with it. This control block contains all information required to support the port related operations.
void* Dual_ported_memory_Control::external_base |
void* Dual_ported_memory_Control::internal_base |
uint32_t Dual_ported_memory_Control::length |
Objects_Control Dual_ported_memory_Control::Object |
Referenced by _Dual_ported_memory_Free().
