RTEMS File System Interface for RTEMS. More...
#include <sys/param.h>#include <inttypes.h>#include <string.h>#include <stdlib.h>#include <rtems/rfs/rtems-rfs-file.h>#include <rtems/rfs/rtems-rfs-dir.h>#include <rtems/rfs/rtems-rfs-link.h>#include "rtems-rfs-rtems.h"
| int | rtems_rfs_rtems_fstat (const rtems_filesystem_location_info_t *pathloc, struct stat *buf) |
| The following routine does a stat on a node. | |
| int | rtems_rfs_rtems_rmnod (const rtems_filesystem_location_info_t *parent_pathloc, const rtems_filesystem_location_info_t *pathloc) |
| Routine to remove a node from the RFS file system. More... | |
| int | rtems_rfs_rtems_fdatasync (rtems_libio_t *iop) |
| The following routine does a sync on an inode node. More... | |
| int | rtems_rfs_rtems_initialise (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Forward decl for the ops table. More... | |
| void | rtems_rfs_rtems_shutdown (rtems_filesystem_mount_table_entry_t *mt_entry) |
| Shutdown the file system. | |
| const rtems_filesystem_file_handlers_r | rtems_rfs_rtems_link_handlers |
| Handler table for RFS link nodes. More... | |
| const rtems_filesystem_operations_table | rtems_rfs_ops |
| RFS file system operations table. More... | |
| int rtems_rfs_rtems_fdatasync | ( | rtems_libio_t * | iop | ) |
Currently it flushes everything related to this device.
| iop |
References rtems_rfs_buffer_sync(), rtems_rfs_rtems_error, and rtems_rfs_rtems_pathloc_dev.
| int rtems_rfs_rtems_rmnod | ( | const rtems_filesystem_location_info_t * | parent_pathloc, |
| const rtems_filesystem_location_info_t * | pathloc | ||
| parent_pathloc | |
| pathloc |
References rtems_rfs_rtems_get_pathloc_doff, rtems_rfs_rtems_get_pathloc_ino, rtems_rfs_rtems_pathloc_dev, and rtems_rfs_rtems_trace.
| const rtems_filesystem_operations_table rtems_rfs_ops |
| const rtems_filesystem_file_handlers_r rtems_rfs_rtems_link_handlers |
