RTEMS File Systems Buffer Routines. More...
#include <sys/stat.h>#include <inttypes.h>#include <errno.h>#include <fcntl.h>#include <string.h>#include <rtems/rfs/rtems-rfs-buffer.h>#include <rtems/rfs/rtems-rfs-file-system.h>
| int | rtems_rfs_buffer_handle_request (rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *handle, rtems_rfs_buffer_block block, bool read) |
| Request a buffer. More... | |
| int | rtems_rfs_buffer_handle_release (rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *handle) |
| Release a buffer. More... | |
| int | rtems_rfs_buffer_open (const char *name, rtems_rfs_file_system *fs) |
| Open the buffer interface. More... | |
| int | rtems_rfs_buffer_close (rtems_rfs_file_system *fs) |
| Close the buffer interface. More... | |
| int | rtems_rfs_buffer_sync (rtems_rfs_file_system *fs) |
| Sync all buffers to the media. More... | |
| int | rtems_rfs_buffer_setblksize (rtems_rfs_file_system *fs, size_t size) |
| Set the block size of the device. More... | |
| int | rtems_rfs_buffers_release (rtems_rfs_file_system *fs) |
| Release any chained buffers. More... | |
| int rtems_rfs_buffer_close | ( | rtems_rfs_file_system * | fs | ) |
| [in] | fs | is the file system data. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_buffer_handle_release | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_buffer_handle * | handle | ||
Release a buffer.
If the buffer is dirty the buffer is written to disk. The result does not indicate if the data was successfully written to the disk as this operation may be performed in asynchronously to this release.
| [in] | handle | is the handle the requested buffer is attached to. |
Referenced by rtems_rfs_file_io_release().
| int rtems_rfs_buffer_handle_request | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_buffer_handle * | handle, | ||
| rtems_rfs_buffer_block | block, | ||
| bool | read | ||
Request a buffer.
The buffer can be filled with data from the media (read == true) or you can request a buffer to fill with data.
| [in] | block | is the block number. |
| [in] | read | Read the data from the disk. |
| int rtems_rfs_buffer_open | ( | const char * | name, |
| rtems_rfs_file_system * | fs | ||
| [in] | name | is a pointer to the device name to the media. |
| int rtems_rfs_buffer_setblksize | ( | rtems_rfs_file_system * | fs, |
| size_t | size | ||
| [in] | size | is the new block size. |
| int rtems_rfs_buffer_sync | ( | rtems_rfs_file_system * | fs | ) |
Referenced by rtems_rfs_rtems_fdatasync().
| int rtems_rfs_buffers_release | ( | rtems_rfs_file_system * | fs | ) |
