telnetd.c File Reference
#include <rtems/error.h>
#include <rtems/pty.h>
#include <rtems/shell.h>
#include <rtems/telnetd.h>
#include <rtems/bspIo.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <unistd.h>
#include <syslog.h>
#include <rtems/userenv.h>
Include dependency graph for telnetd.c:
struct  shell_args
union  uni_sa
struct  wrap_delete_args
typedef union uni_sa uni_sa
char * telnet_get_pty (int socket)
int telnet_pty_initialize (void)
rtems_id telnetd_dflt_spawn (const char *name, unsigned priority, unsigned stackSize, void(*fn)(void *), void *fnarg)
rtems_status_code rtems_telnetd_initialize (void)
 Initializes the Telnet subsystem. More...
rtems_id telnetd_dflt_spawn (const char *name, unsigned int priority, unsigned int stackSize, void(*fn)(void *), void *fnarg)
rtems_id(* telnetd_spawn_task )(const char *, unsigned, unsigned, void(*)(void *), void *) = telnetd_dflt_spawn
◆ rtems_telnetd_initialize()
rtems_status_code rtems_telnetd_initialize ( void  )
Uses the application provided rtems_telnetd_config configuration table.
References rtems_telnetd_config_table::command, RTEMS_ID_NONE, RTEMS_IO_ERROR, RTEMS_RESOURCE_IN_USE, and rtems_telnetd_config.
