Data Structures | Typedefs | Functions | Variables
telnetd.h File Reference
#include <rtems/shell.h>
Include dependency graph for telnetd.h:
struct  rtems_telnetd_config_table
 Telnet configuration structure. More...
typedef void(* rtems_telnetd_command) (char *, void *)
 Telnet command type.
bool rtems_telnetd_login_check (const char *user, const char *passphrase)
 Standard Telnet login check that uses DES to encrypt the passphrase. More...
rtems_status_code rtems_telnetd_initialize (void)
 Initializes the Telnet subsystem. More...
rtems_telnetd_config_table rtems_telnetd_config
 Telnet configuration. More...
◆ rtems_telnetd_initialize()
rtems_status_code rtems_telnetd_initialize ( void  )
Uses the application provided rtems_telnetd_config configuration table.
References rtems_telnetd_config_table::command, RTEMS_ID_NONE, RTEMS_IO_ERROR, RTEMS_RESOURCE_IN_USE, and rtems_telnetd_config.
◆ rtems_telnetd_login_check()
bool rtems_telnetd_login_check ( const char *  user,
const char *  passphrase
Takes a passphrase, encrypts it and compares it to the encrypted passphrase in the TELNETD_PASSWD environment variable. No password is required if TELNETD_PASSWD is unset. The argument user is ignored.
Variable Documentation
◆ rtems_telnetd_config
The application must provide this configuration table. It is used by rtems_telnetd_initialize() to configure the Telnet subsystem. Do not modify the entries after the intialization since it is used internally.
Referenced by rtems_telnetd_initialize().
