void | sys_init (void) |
void | sys_cleanup (void) |
void | sys_close (void) |
int | sys_check_options (void) |
int | ppp_available (void) |
int | establish_ppp (int fd) |
void | restore_loop (void) |
void | disestablish_ppp (int fd) |
void | clean_check (void) |
void | set_up_tty (int fd, int local) |
void | restore_tty (int fd) |
void | setdtr (int fd, int on) |
int | get_pty (int *master_fdp, int *slave_fdp, char *slave_name, int uid) |
int | open_ppp_loopback (void) |
void | output (int unit, u_char *p, int len) |
void | ppp_delay (void) |
void | wait_input (struct timeval *timo) |
int | read_packet (u_char *buf) |
int | get_loop_output (void) |
void | ppp_send_config (int unit, int mtu, uint32_t asyncmap, int pcomp, int accomp) |
void | ppp_set_xaccm (int unit, ext_accm accm) |
void | ppp_recv_config (int unit, int mru, uint32_t asyncmap, int pcomp, int accomp) |
int | ccp_test (int unit, u_char *opt_ptr, int opt_len, int for_transmit) |
void | ccp_flags_set (int unit, int isopen, int isup) |
int | ccp_fatal_error (int unit) |
int | get_idle_time (int u, struct ppp_idle *ip) |
int | get_ppp_stats (int u, struct pppd_stats *stats) |
int | sifvjcomp (int u, int vjcomp, int cidcomp, int maxcid) |
int | sifup (int u) |
int | sifnpmode (int u, int proto, enum NPmode mode) |
int | sifdown (int u) |
int | sifaddr (int u, uint32_t o, uint32_t h, uint32_t m) |
int | cifaddr (int u, uint32_t o, uint32_t h) |
int | sifdefaultroute (int u, uint32_t l, uint32_t g) |
int | cifdefaultroute (int u, uint32_t l, uint32_t g) |
int | sifproxyarp (int unit, uint32_t hisaddr) |
int | cifproxyarp (int unit, uint32_t hisaddr) |
uint32_t | GetMask (uint32_t addr) |
int | have_route_to (uint32_t addr) |
int | get_host_seed (void) |
