ppp_defs.h
1 /*
2  * ppp_defs.h - PPP definitions.
3  *
4  * Copyright (c) 1994 The Australian National University.
5  * All rights reserved.
6  *
7  * Permission to use, copy, modify, and distribute this software and its
8  * documentation is hereby granted, provided that the above copyright
9  * notice appears in all copies. This software is provided without any
10  * warranty, express or implied. The Australian National University
11  * makes no representations about the suitability of this software for
12  * any purpose.
13  *
14  * IN NO EVENT SHALL THE AUSTRALIAN NATIONAL UNIVERSITY BE LIABLE TO ANY
15  * PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES
16  * ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
17  * THE AUSTRALIAN NATIONAL UNIVERSITY HAVE BEEN ADVISED OF THE POSSIBILITY
18  * OF SUCH DAMAGE.
19  *
20  * THE AUSTRALIAN NATIONAL UNIVERSITY SPECIFICALLY DISCLAIMS ANY WARRANTIES,
21  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
22  * AND FITNESS FOR A PARTICULAR PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS
23  * ON AN "AS IS" BASIS, AND THE AUSTRALIAN NATIONAL UNIVERSITY HAS NO
24  * OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS,
25  * OR MODIFICATIONS.
26  *
27  * $FreeBSD: src/sys/net/ppp_defs.h,v 1.8 2005/01/07 01:45:35 imp Exp $
28  */
29
30
31 #ifndef _PPP_DEFS_H_
32 #define _PPP_DEFS_H_
33
34 #include <stdint.h>
35
36 /*
37  * The basic PPP frame.
38  */
39 #define PPP_HDRLEN 4 /* octets for standard ppp header */
40 #define PPP_FCSLEN 2 /* octets for FCS */
41 #define PPP_MRU 1500 /* default MRU = max length of info field */
42
43 #define PPP_ADDRESS(p) (((u_char *)(p))[0])
44 #define PPP_CONTROL(p) (((u_char *)(p))[1])
45 #define PPP_PROTOCOL(p) ((((u_char *)(p))[2] << 8) + ((u_char *)(p))[3])
46
47 /*
48  * Significant octet values.
49  */
50 #define PPP_ALLSTATIONS 0xff /* All-Stations broadcast address */
51 #define PPP_UI 0x03 /* Unnumbered Information */
52 #define PPP_FLAG 0x7e /* Flag Sequence */
53 #define PPP_ESCAPE 0x7d /* Asynchronous Control Escape */
54 #define PPP_TRANS 0x20 /* Asynchronous transparency modifier */
55
56 /*
57  * Protocol field values.
58  */
59 #define PPP_IP 0x21 /* Internet Protocol */
60 #define PPP_AT 0x29 /* AppleTalk Protocol */
61 #define PPP_IPX 0x2b /* IPX protocol */
62 #define PPP_VJC_COMP 0x2d /* VJ compressed TCP */
63 #define PPP_VJC_UNCOMP 0x2f /* VJ uncompressed TCP */
64 #define PPP_IPV6 0x57 /* Internet Protocol Version 6 */
65 #define PPP_COMP 0xfd /* compressed packet */
66 #define PPP_IPCP 0x8021 /* IP Control Protocol */
67 #define PPP_ATCP 0x8029 /* AppleTalk Control Protocol */
68 #define PPP_IPXCP 0x802b /* IPX Control Protocol */
69 #define PPP_IPV6CP 0x8057 /* IPv6 Control Protocol */
70 #define PPP_CCP 0x80fd /* Compression Control Protocol */
71 #define PPP_LCP 0xc021 /* Link Control Protocol */
72 #define PPP_PAP 0xc023 /* Password Authentication Protocol */
73 #define PPP_LQR 0xc025 /* Link Quality Report protocol */
74 #define PPP_CHAP 0xc223 /* Cryptographic Handshake Auth. Protocol */
75 #define PPP_CBCP 0xc029 /* Callback Control Protocol */
76
77 /*
78  * Values for FCS calculations.
79  */
80 #define PPP_INITFCS 0xffff /* Initial FCS value */
81 #define PPP_GOODFCS 0xf0b8 /* Good final FCS value */
82 #define PPP_FCS(fcs, c) (((fcs) >> 8) ^ fcstab[((fcs) ^ (c)) & 0xff])
83
84 /*
85  * Extended asyncmap - allows any character to be escaped.
86  */
87 typedef uint32_t ext_accm[8];
88
89 /*
90  * What to do with network protocol (NP) packets.
91  */
92 enum NPmode {
93  NPMODE_PASS, /* pass the packet through */
94  NPMODE_DROP, /* silently drop the packet */
95  NPMODE_ERROR, /* return an error */
96  NPMODE_QUEUE /* save it up for later. */
97 };
98
99 /*
100  * Statistics.
101  */
102 struct pppstat {
103  unsigned int ppp_ibytes; /* bytes received */
104  unsigned int ppp_ipackets; /* packets received */
105  unsigned int ppp_ierrors; /* receive errors */
106  unsigned int ppp_obytes; /* bytes sent */
107  unsigned int ppp_opackets; /* packets sent */
108  unsigned int ppp_oerrors; /* transmit errors */
109 };
110
111 struct vjstat {
112  unsigned int vjs_packets; /* outbound packets */
113  unsigned int vjs_compressed; /* outbound compressed packets */
114  unsigned int vjs_searches; /* searches for connection state */
115  unsigned int vjs_misses; /* times couldn't find conn. state */
116  unsigned int vjs_uncompressedin; /* inbound uncompressed packets */
117  unsigned int vjs_compressedin; /* inbound compressed packets */
118  unsigned int vjs_errorin; /* inbound unknown type packets */
119  unsigned int vjs_tossed; /* inbound packets tossed because of error */
120 };
121
122 struct ppp_stats {
123  struct pppstat p; /* basic PPP statistics */
124  struct vjstat vj; /* VJ header compression statistics */
125 };
126
127 struct compstat {
128  unsigned int unc_bytes; /* total uncompressed bytes */
129  unsigned int unc_packets; /* total uncompressed packets */
130  unsigned int comp_bytes; /* compressed bytes */
131  unsigned int comp_packets; /* compressed packets */
132  unsigned int inc_bytes; /* incompressible bytes */
133  unsigned int inc_packets; /* incompressible packets */
134  unsigned int ratio; /* recent compression ratio << 8 */
135 };
136
137 struct ppp_comp_stats {
138  struct compstat c; /* packet compression statistics */
139  struct compstat d; /* packet decompression statistics */
140 };
141
142 /*
143  * The following structure records the time in seconds since
144  * the last NP packet was sent or received.
145  */
146 struct ppp_idle {
147  time_t xmit_idle; /* time since last NP packet sent */
148  time_t recv_idle; /* time since last NP packet received */
149 };
150
151 #ifndef __P
152 #ifdef __STDC__
153 #define __P(x) x
154 #else
155 #define __P(x) ()
156 #endif
157 #endif
158
159 #endif /* _PPP_DEFS_H_ */
Definition: ppp_defs.h:112
Definition: ppp_defs.h:147
Definition: ppp_defs.h:103
Definition: ppp_defs.h:123
Definition: ppp_defs.h:138
Definition: ppp_defs.h:128
