fsm.h
1 /*
2  * fsm.h - {Link, IP} Control Protocol Finite State Machine definitions.
3  *
4  * Copyright (c) 1989 Carnegie Mellon University.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms are permitted
8  * provided that the above copyright notice and this paragraph are
9  * duplicated in all such forms and that any documentation,
10  * advertising materials, and other materials related to such
11  * distribution and use acknowledge that the software was developed
12  * by Carnegie Mellon University. The name of the
13  * University may not be used to endorse or promote products derived
14  * from this software without specific prior written permission.
15  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16  * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17  * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18  *
19  * $Id$
20  */
21
22 /*
23  * Packet header = Code, id, length.
24  */
25 #define HEADERLEN 4
26
27
28 /*
29  * CP (LCP, IPCP, etc.) codes.
30  */
31 #define CONFREQ 1 /* Configuration Request */
32 #define CONFACK 2 /* Configuration Ack */
33 #define CONFNAK 3 /* Configuration Nak */
34 #define CONFREJ 4 /* Configuration Reject */
35 #define TERMREQ 5 /* Termination Request */
36 #define TERMACK 6 /* Termination Ack */
37 #define CODEREJ 7 /* Code Reject */
38
39
40 /*
41  * Each FSM is described by an fsm structure and fsm callbacks.
42  */
43 typedef struct fsm {
44  int unit; /* Interface unit number */
45  int protocol; /* Data Link Layer Protocol field value */
46  int state; /* State */
47  int flags; /* Contains option bits */
48  u_char id; /* Current id */
49  u_char reqid; /* Current request id */
50  u_char seen_ack; /* Have received valid Ack/Nak/Rej to Req */
51  int timeouttime; /* Timeout time in milliseconds */
52  int maxconfreqtransmits; /* Maximum Configure-Request transmissions */
53  int retransmits; /* Number of retransmissions left */
54  int maxtermtransmits; /* Maximum Terminate-Request transmissions */
55  int nakloops; /* Number of nak loops since last ack */
56  int maxnakloops; /* Maximum number of nak loops tolerated */
57  struct fsm_callbacks *callbacks; /* Callback routines */
58  char *term_reason; /* Reason for closing protocol */
59  int term_reason_len; /* Length of term_reason */
60 } fsm;
61
62
63 typedef struct fsm_callbacks {
64  void (*resetci) /* Reset our Configuration Information */
65  (fsm *);
66  int (*cilen) /* Length of our Configuration Information */
67  (fsm *);
68  void (*addci) /* Add our Configuration Information */
69  (fsm *, u_char *, int *);
70  int (*ackci) /* ACK our Configuration Information */
71  (fsm *, u_char *, int);
72  int (*nakci) /* NAK our Configuration Information */
73  (fsm *, u_char *, int);
74  int (*rejci) /* Reject our Configuration Information */
75  (fsm *, u_char *, int);
76  int (*reqci) /* Request peer's Configuration Information */
77  (fsm *, u_char *, int *, int);
78  void (*up) /* Called when fsm reaches OPENED state */
79  (fsm *);
80  void (*down) /* Called when fsm leaves OPENED state */
81  (fsm *);
82  void (*starting) /* Called when we want the lower layer */
83  (fsm *);
84  void (*finished) /* Called when we don't want the lower layer */
85  (fsm *);
86  void (*protreject) /* Called when Protocol-Reject received */
87  (int);
88  void (*retransmit) /* Retransmission is necessary */
89  (fsm *);
90  int (*extcode) /* Called when unknown code received */
91  (fsm *, int, int, u_char *, int);
92  char *proto_name; /* String name for protocol (for messages) */
94
95
96 /*
97  * Link states.
98  */
99 #define INITIAL 0 /* Down, hasn't been opened */
100 #define STARTING 1 /* Down, been opened */
101 #define CLOSED 2 /* Up, hasn't been opened */
102 #define STOPPED 3 /* Open, waiting for down event */
103 #define CLOSING 4 /* Terminating the connection, not open */
104 #define STOPPING 5 /* Terminating, but open */
105 #define REQSENT 6 /* We've sent a Config Request */
106 #define ACKRCVD 7 /* We've received a Config Ack */
107 #define ACKSENT 8 /* We've sent a Config Ack */
108 #define OPENED 9 /* Connection available */
109
110
111 /*
112  * Flags - indicate options controlling FSM operation
113  */
114 #define OPT_PASSIVE 1 /* Don't die if we don't get a response */
115 #define OPT_RESTART 2 /* Treat 2nd OPEN as DOWN, UP */
116 #define OPT_SILENT 4 /* Wait for peer to speak first */
117
118
119 /*
120  * Timeouts.
121  */
122 #define DEFTIMEOUT 5 /* Timeout time in seconds */
123 #define DEFMAXTERMREQS 2 /* Maximum Terminate-Request transmissions */
124 #define DEFMAXCONFREQS 10 /* Maximum Configure-Request transmissions */
125 #define DEFMAXNAKLOOPS 5 /* Maximum number of nak loops */
126
127
128 /*
129  * Prototypes
130  */
131 void fsm_init(fsm *);
132 void fsm_lowerup(fsm *);
133 void fsm_lowerdown(fsm *);
134 void fsm_open(fsm *);
135 void fsm_close(fsm *, char *);
136 void fsm_input(fsm *, u_char *, int);
137 void fsm_protreject(fsm *);
138 void fsm_sdata(fsm *, u_char, u_char, u_char *, int);
139
140
141 /*
142  * Variables
143  */
144 extern int peer_mru[]; /* currently negotiated peer MRU (per unit) */
Definition: fsm.h:44
Definition: fsm.h:64
