pppd.h
1 /*
2  * pppd.h - PPP daemon global declarations.
3  *
4  * Copyright (c) 1989 Carnegie Mellon University.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms are permitted
8  * provided that the above copyright notice and this paragraph are
9  * duplicated in all such forms and that any documentation,
10  * advertising materials, and other materials related to such
11  * distribution and use acknowledge that the software was developed
12  * by Carnegie Mellon University. The name of the
13  * University may not be used to endorse or promote products derived
14  * from this software without specific prior written permission.
15  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16  * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17  * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18  *
19  * $Id$
20  */
21
22 #ifndef __PPPD_H__
23 #define __PPPD_H__
24
25 #include <stdbool.h> /* bool */
26 #include <stdio.h> /* for FILE */
27 #include <limits.h> /* for NGROUPS_MAX */
28 #include <sys/param.h>
29 #include <sys/types.h> /* for uint32_t, if defined */
30 #include <sys/time.h> /* for struct timeval */
31 #include <net/ppp_defs.h>
32 #include <rtems/rtemsdialer.h>
33 #include <stdint.h>
34
35 #if defined(__STDC__)
36 #include <stdarg.h>
37 #define __V(x) x
38 #else
39 #include <varargs.h>
40 #define __V(x) (va_alist) va_dcl
41 #define const
42 #define volatile
43 #endif
44
45 #ifdef INET6
46 #include "eui64.h"
47 #endif
48
49 /*
50  * Limits.
51  */
52
53 #define NUM_PPP 1 /* One PPP interface supported (per process) */
54 #define MAXWORDLEN 1024 /* max length of word in file (incl null) */
55 #define MAXARGS 1 /* max # args to a command */
56 #define MAXNAMELEN 256 /* max length of hostname or name for auth */
57 #define MAXSECRETLEN 256 /* max length of password or secret */
58
59 /*
60  * Option descriptor structure.
61  */
62
63 enum opt_type {
64  o_special_noarg = 0,
65  o_special = 1,
66  o_bool,
67  o_int,
68  o_uint32,
69  o_string,
70 };
71
72 typedef struct {
73  char *name; /* name of the option */
74  enum opt_type type;
75  void *addr;
76  char *description;
77  uint32_t flags;
78  void *addr2;
79  int upper_limit;
80  int lower_limit;
81 } option_t;
82
83 /* Values for flags */
84 #define OPT_VALUE 0xffL /* mask for presupplied value */
85 #define OPT_HEX 0x100L /* int option is in hex */
86 #define OPT_NOARG 0x200L /* option doesn't take argument */
87 #define OPT_OR 0x400L /* OR in argument to value */
88 #define OPT_INC 0x800L /* increment value */
89 #define OPT_PRIV 0x1000L /* privileged option */
90 #define OPT_STATIC 0x2000L /* string option goes into static array */
91 #define OPT_LLIMIT 0x4000L /* check value against lower limit */
92 #define OPT_ULIMIT 0x8000L /* check value against upper limit */
93 #define OPT_LIMITS (OPT_LLIMIT|OPT_ULIMIT)
94 #define OPT_ZEROOK 0x10000L /* 0 value is OK even if not within limits */
95 #define OPT_NOINCR 0x20000L /* value mustn't be increased */
96 #define OPT_ZEROINF 0x40000L /* with OPT_NOINCR, 0 == infinity */
97 #define OPT_A2INFO 0x100000L /* addr2 -> option_info to update */
98 #define OPT_A2COPY 0x200000L /* addr2 -> second location to rcv value */
99 #define OPT_ENABLE 0x400000L /* use *addr2 as enable for option */
100 #define OPT_PRIVFIX 0x800000L /* can't be overridden if noauth */
101 #define OPT_PREPASS 0x1000000L /* do this opt in pre-pass to find device */
102 #define OPT_INITONLY 0x2000000L /* option can only be set in init phase */
103 #define OPT_DEVEQUIV 0x4000000L /* equiv to device name */
104 #define OPT_DEVNAM (OPT_PREPASS | OPT_INITONLY | OPT_DEVEQUIV)
105
106 #define OPT_VAL(x) ((x) & OPT_VALUE)
107
108 #ifndef GIDSET_TYPE
109 #define GIDSET_TYPE gid_t
110 #endif
111
112 /* Structure representing a list of permitted IP addresses. */
113 struct permitted_ip {
114  int permit; /* 1 = permit, 0 = forbid */
115  uint32_t base; /* match if (addr & mask) == base */
116  uint32_t mask; /* base and mask are in network byte order */
117 };
118
119 /*
120  * Unfortunately, the linux kernel driver uses a different structure
121  * for statistics from the rest of the ports.
122  * This structure serves as a common representation for the bits
123  * pppd needs.
124  */
125 struct pppd_stats {
126  unsigned int bytes_in;
127  unsigned int bytes_out;
128 };
129
130 /* Used for storing a sequence of words. Usually malloced. */
131 struct wordlist {
132  struct wordlist *next;
133  char *word;
134 };
135
136 /*
137  * Global variables.
138  */
139
140 extern int pppd_kill_link; /* Signal to terminate processing loop */
141 extern int hungup; /* Physical layer has disconnected */
142 extern int pppifunit; /* Interface unit number */
143 extern char ifname[]; /* Interface name */
144 extern int pppd_ttyfd; /* Serial device file descriptor */
145 extern char hostname[]; /* Our hostname */
146 extern u_char outpacket_buf[]; /* Buffer for outgoing packets */
147 extern int pppd_phase; /* Current state of link - see values below */
148 extern int baud_rate; /* Current link speed in bits/sec */
149 extern int redirect_stderr;/* Connector's stderr should go to file */
150 extern char peer_authname[];/* Authenticated name of peer */
151 extern int privileged; /* We were run by real-uid root */
152 extern int need_holdoff; /* Need holdoff period after link terminates */
153 extern char **script_env; /* Environment variables for scripts */
154 extern int detached; /* Have detached from controlling tty */
155 extern GIDSET_TYPE groups[NGROUPS_MAX]; /* groups the user is in */
156 extern int ngroups; /* How many groups valid in groups */
157 extern struct pppd_stats link_stats; /* byte/packet counts etc. for link */
158 extern int using_pty; /* using pty as device (notty or pty opt.) */
159 extern int log_to_fd; /* logging to this fd as well as syslog */
160 extern char *no_ppp_msg; /* message to print if ppp not in kernel */
161 extern volatile int pppd_status; /* exit status for pppd */
162 extern int devnam_fixed; /* can no longer change devnam */
163 extern int unsuccess; /* # unsuccessful connection attempts */
164 extern int do_callback; /* set if we want to do callback next */
165 extern int doing_callback; /* set if this is a callback */
166 extern dialerfp pppd_dialer; /* script dialer function callback */
167
168 /* Values for do_callback and doing_callback */
169 #define CALLBACK_DIALIN 1 /* we are expecting the call back */
170 #define CALLBACK_DIALOUT 2 /* we are dialling out to call back */
171
172 /*
173  * Variables set by command-line options.
174  */
175
176 extern int debug; /* Debug flag */
177 extern int kdebugflag; /* Tell kernel to print debug messages */
178 extern int default_device; /* Using /dev/tty or equivalent */
179 extern char devnam[MAXPATHLEN]; /* Device name */
180 extern int crtscts; /* Use hardware flow control */
181 extern bool modem; /* Use modem control lines */
182 extern int inspeed; /* Input/Output speed requested */
183 extern uint32_t netmask; /* IP netmask to set on interface */
184 extern bool lockflag; /* Create lock file to lock the serial dev */
185 extern bool nodetach; /* Don't detach from controlling tty */
186 extern bool updetach; /* Detach from controlling tty when link up */
187 extern char *initializer; /* Script to initialize physical link */
188 extern char *connect_script; /* Script to establish physical link */
189 extern char *disconnect_script; /* Script to disestablish physical link */
190 extern char *welcomer; /* Script to welcome client after connection */
191 extern char *ptycommand; /* Command to run on other side of pty */
192 extern int maxconnect; /* Maximum connect time (seconds) */
193 extern char user[MAXNAMELEN];/* Our name for authenticating ourselves */
194 extern char passwd[MAXSECRETLEN]; /* Password for PAP or CHAP */
195 extern bool auth_required; /* Peer is required to authenticate */
196 extern bool persist; /* Reopen link after it goes down */
197 extern bool uselogin; /* Use /etc/passwd for checking PAP */
198 extern char our_name[MAXNAMELEN];/* Our name for authentication purposes */
199 extern char remote_name[MAXNAMELEN]; /* Peer's name for authentication */
200 extern bool explicit_remote;/* remote_name specified with remotename opt */
201 extern bool demand; /* Do dial-on-demand */
202 extern char *ipparam; /* Extra parameter for ip up/down scripts */
203 extern bool cryptpap; /* Others' PAP passwords are encrypted */
204 extern int idle_time_limit;/* Shut down link if idle for this long */
205 extern int holdoff; /* Dead time before restarting */
206 extern bool holdoff_specified; /* true if user gave a holdoff value */
207 extern bool notty; /* Stdin/out is not a tty */
208 extern char *record_file; /* File to record chars sent/received */
209 extern bool sync_serial; /* Device is synchronous serial device */
210 extern int maxfail; /* Max # of unsuccessful connection attempts */
211 extern char linkname[MAXPATHLEN]; /* logical name for link */
212 extern bool tune_kernel; /* May alter kernel settings as necessary */
213 extern int connect_delay; /* Time to delay after connect script */
214
215 #ifdef PPP_FILTER
216 extern struct bpf_program pass_filter; /* Filter for pkts to pass */
217 extern struct bpf_program active_filter; /* Filter for link-active pkts */
218 #endif
219
220 #ifdef MSLANMAN
221 extern bool ms_lanman; /* Use LanMan password instead of NT */
222  /* Has meaning only with MS-CHAP challenges */
223 #endif
224
225 extern char *current_option; /* the name of the option being parsed */
226 extern int privileged_option; /* set iff the current option came from root */
227 extern char *option_source; /* string saying where the option came from */
228
229 /*
230  * Values for phase.
231  */
232 #define PHASE_DEAD 0
233 #define PHASE_INITIALIZE 1
234 #define PHASE_SERIALCONN 2
235 #define PHASE_DORMANT 3
236 #define PHASE_ESTABLISH 4
237 #define PHASE_AUTHENTICATE 5
238 #define PHASE_CALLBACK 6
239 #define PHASE_NETWORK 7
240 #define PHASE_RUNNING 8
241 #define PHASE_TERMINATE 9
242 #define PHASE_DISCONNECT 10
243 #define PHASE_HOLDOFF 11
244
245 /*
246  * The following struct gives the addresses of procedures to call
247  * for a particular protocol.
248  */
249 struct protent {
250  u_short protocol; /* PPP protocol number */
251  /* Initialization procedure */
252  void (*init)(int unit);
253  /* Process a received packet */
254  void (*input)(int unit, u_char *pkt, int len);
255  /* Process a received protocol-reject */
256  void (*protrej)(int unit);
257  /* Lower layer has come up */
258  void (*lowerup)(int unit);
259  /* Lower layer has gone down */
260  void (*lowerdown)(int unit);
261  /* Open the protocol */
262  void (*open)(int unit);
263  /* Close the protocol */
264  void (*close)(int unit, char *reason);
265  /* Print a packet in readable form */
266  int (*printpkt)(u_char *pkt, int len,
267  void (*printer)(void *, char *, ...),
268  void *arg);
269  /* Process a received data packet */
270  void (*datainput)(int unit, u_char *pkt, int len);
271  bool enabled_flag; /* 0 iff protocol is disabled */
272  char *name; /* Text name of protocol */
273  char *data_name; /* Text name of corresponding data protocol */
274  option_t *options; /* List of command-line options */
275  /* Check requested options, assign defaults */
276  void (*check_options)(void);
277  /* Configure interface for demand-dial */
278  int (*demand_conf)(int unit);
279  /* Say whether to bring up link for this pkt */
280  int (*active_pkt)(u_char *pkt, int len);
281 };
282
283 /* Table of pointers to supported protocols */
284 extern struct protent *protocols[];
285
286 /*
287  * Prototypes.
288  */
289
290 /* Procedures exported from main.c. */
291 void die(int); /* Cleanup and exit */
292 void quit(void); /* like die(1) */
293 void novm(char *); /* Say we ran out of memory, and die */
294 void ppptimeout(void (*func)(void *), void *arg, int t);
295  /* Call func(arg) after t seconds */
296 void pppuntimeout(void (*func)(void *), void *arg);
297  /* Cancel call to func(arg) */
298 void update_link_stats(int); /* Get stats at link termination */
299 void new_phase(int); /* signal start of new phase */
300
301 /* Procedures exported from utils.c. */
302 void log_packet(u_char *, int, char *, int);
303  /* Format a packet and log it with syslog */
304 void print_string(void *, int, void (*) (void *, char *, ...),
305  void *); /* Format a string for output */
306 int slprintf(char *, int, char *, ...); /* sprintf++ */
307 int vslprintf(char *, int, char *, va_list); /* vsprintf++ */
308 size_t strlcpy(char *, const char *, size_t); /* safe strcpy */
309 size_t strlcat(char *, const char *, size_t); /* safe strncpy */
310 void pppd_dbglog(char *, ...); /* log a debug message */
311 void pppd_info(char *, ...); /* log an informational message */
312 void pppd_notice(char *, ...); /* log a notice-level message */
313 void pppd_warn(char *, ...); /* log a warning message */
314 void pppd_error(char *, ...); /* log an error message */
315 void pppd_fatal(char *, ...); /* log an error message and die(1) */
316
317 #define dbglog pppd_dbglog
318 #define info pppd_info
319 #define notice pppd_notice
320 #define warn pppd_warn
321 #define error pppd_error
322 #define fatal pppd_fatal
323
324 /* Procedures exported from auth.c */
325 void link_required(int); /* we are starting to use the link */
326 void link_terminated(int); /* we are finished with the link */
327 void link_down(int); /* the LCP layer has left the Opened state */
328 void link_established(int); /* the link is up; authenticate now */
329 void start_networks(void); /* start all the network control protos */
330 void np_up(int, int); /* a network protocol has come up */
331 void np_down(int, int); /* a network protocol has gone down */
332 void np_finished(int, int); /* a network protocol no longer needs link */
333 void auth_peer_fail(int, int);
334  /* peer failed to authenticate itself */
335 void auth_peer_success(int, int, char *, int);
336  /* peer successfully authenticated itself */
337 void auth_withpeer_fail(int, int);
338  /* we failed to authenticate ourselves */
339 void auth_withpeer_success(int, int);
340  /* we successfully authenticated ourselves */
341 int auth_check_options(void);
342  /* check authentication options supplied */
343 void auth_reset(int); /* check what secrets we have */
344 int check_passwd(int, char *, int, char *, int, char **);
345  /* Check peer-supplied username/password */
346 int get_secret(int, char *, char *, unsigned char *, int *, int);
347  /* get "secret" for chap */
348 int auth_ip_addr(int, uint32_t);
349  /* check if IP address is authorized */
350 int bad_ip_adrs(uint32_t);
351  /* check if IP address is unreasonable */
352
353 /* Procedures exported from demand.c */
354 void demand_conf(void); /* config interface(s) for demand-dial */
355 void demand_block(void); /* set all NPs to queue up packets */
356 void demand_unblock(void); /* set all NPs to pass packets */
357 void demand_discard(void); /* set all NPs to discard packets */
358 void demand_rexmit(int); /* retransmit saved frames for an NP */
359 int loop_chars(unsigned char *, int); /* process chars from loopback */
360 int loop_frame(unsigned char *, int); /* should we bring link up? */
361
362 /* Procedures exported from sys-*.c */
363 void sys_init(void); /* Do system-dependent initialization */
364 void sys_cleanup(void); /* Restore system state before exiting */
365 int sys_check_options(void); /* Check options specified */
366 void sys_close(void); /* Clean up in a child before execing */
367 int ppp_available(void); /* Test whether ppp kernel support exists */
368 int get_pty(int *, int *, char *, int); /* Get pty master/slave */
369 int open_ppp_loopback(void); /* Open loopback for demand-dialling */
370 int establish_ppp(int); /* Turn serial port into a ppp interface */
371 void restore_loop(void); /* Transfer ppp unit back to loopback */
372 void disestablish_ppp(int); /* Restore port to normal operation */
373 void clean_check(void); /* Check if line was 8-bit clean */
374 void set_up_tty(int, int); /* Set up port's speed, parameters, etc. */
375 void restore_tty(int); /* Restore port's original parameters */
376 void setdtr(int, int); /* Raise or lower port's DTR line */
377 void output(int, u_char *, int); /* Output a PPP packet */
378 void wait_input(struct timeval *); /* Wait for input, with timeout */
379
380 void ppp_delay(void); /* delay task for a little while */
381 int read_packet(u_char *); /* Read PPP packet */
382 int get_loop_output(void); /* Read pkts from loopback */
383 void ppp_send_config(int, int, uint32_t, int, int);
384  /* Configure i/f transmit parameters */
385 void ppp_set_xaccm(int, ext_accm);
386  /* Set extended transmit ACCM */
387 void ppp_recv_config(int, int, uint32_t, int, int);
388  /* Configure i/f receive parameters */
389 int ccp_test(int, u_char *, int, int);
390  /* Test support for compression scheme */
391 void ccp_flags_set(int, int, int);
392  /* Set kernel CCP state */
393 int ccp_fatal_error(int); /* Test for fatal decomp error in kernel */
394 int get_idle_time(int, struct ppp_idle *);
395  /* Find out how long link has been idle */
396 int get_ppp_stats(int, struct pppd_stats *);
397  /* Return link statistics */
398 int sifvjcomp(int, int, int, int);
399  /* Configure VJ TCP header compression */
400 int sifup(int); /* Configure i/f up for one protocol */
401 int sifnpmode(int u, int proto, enum NPmode mode);
402  /* Set mode for handling packets for proto */
403 int sifdown(int); /* Configure i/f down for one protocol */
404 int sifaddr(int, uint32_t, uint32_t, uint32_t);
405  /* Configure IPv4 addresses for i/f */
406 int cifaddr(int, uint32_t, uint32_t);
407  /* Reset i/f IP addresses */
408 #ifdef INET6
409 int sif6addr(int, eui64_t, eui64_t);
410  /* Configure IPv6 addresses for i/f */
411 int cif6addr(int, eui64_t, eui64_t);
412  /* Remove an IPv6 address from i/f */
413 #endif
414 int sifdefaultroute(int, uint32_t, uint32_t);
415  /* Create default route through i/f */
416 int cifdefaultroute(int, uint32_t, uint32_t);
417  /* Delete default route through i/f */
418 int sifproxyarp(int, uint32_t);
419  /* Add proxy ARP entry for peer */
420 int cifproxyarp(int, uint32_t);
421  /* Delete proxy ARP entry for peer */
422 uint32_t GetMask(uint32_t); /* Get appropriate netmask for address */
423 int lock(char *); /* Create lock file for device */
424 int relock(int); /* Rewrite lock file with new pid */
425 void unlock(void); /* Delete previously-created lock file */
426 void logwtmp(const char *, const char *, const char *);
427  /* Write entry to wtmp file */
428 int get_host_seed(void); /* Get host-dependent random number seed */
429 int have_route_to(uint32_t); /* Check if route to addr exists */
430 #ifdef PPP_FILTER
431 int set_filters(struct bpf_program *pass, struct bpf_program *active);
432  /* Set filter programs in kernel */
433 #endif
434 #ifdef IPX_CHANGE
435 int sipxfaddr(int, unsigned long, unsigned char *);
436 int cipxfaddr(int);
437 #endif
438
439 /* Procedures exported from options.c */
440 int parse_args(int argc, char **argv);
441  /* Parse options from arguments given */
442 int options_from_file(char *filename, int must_exist, int check_prot,
443  int privileged);
444  /* Parse options from an options file */
445 int options_from_user(void); /* Parse options from user's .ppprc */
446 int options_for_tty(void); /* Parse options from /etc/ppp/options.tty */
447 int options_from_list(struct wordlist *, int privileged);
448  /* Parse options from a wordlist */
449 int getword(FILE *f, char *word, int *newlinep, char *filename);
450  /* Read a word from a file */
451 void option_error(char *fmt, ...);
452  /* Print an error message about an option */
453 int int_option(char *, int *);
454  /* Simplified number_option for decimal ints */
455 void add_options(option_t *); /* Add extra options */
456
457 /*
458  * This structure is used to store information about certain
459  * options, such as where the option value came from (/etc/ppp/options,
460  * command line, etc.) and whether it came from a privileged source.
461  */
462
463 struct option_info {
464  int priv; /* was value set by sysadmin? */
465  char *source; /* where option came from */
466 };
467
468 extern struct option_info devnam_info;
469 extern struct option_info initializer_info;
470 extern struct option_info connect_script_info;
471 extern struct option_info disconnect_script_info;
472 extern struct option_info welcomer_info;
473 extern struct option_info ptycommand_info;
474
475 /*
476  * Hooks to enable plugins to change various things.
477  */
478 extern int (*new_phase_hook)(int);
479 extern int (*idle_time_hook)(struct ppp_idle *);
480 extern int (*holdoff_hook)(void);
481 extern int (*pap_check_hook)(void);
482 extern int (*pap_auth_hook)(char *user, char *passwd/*, char **msgp,
483  struct wordlist **paddrs,
484  struct wordlist **popts*/);
485 extern void (*pap_logout_hook)(void);
486 extern int (*pap_passwd_hook)(char *user, char *passwd);
487 extern void (*ip_up_hook)(void);
488 extern void (*ip_down_hook)(void);
489 extern void (*auth_linkup_hook)(void);
490 extern void (*auth_linkdown_hook)(void);
491
492 /*
493  * Inline versions of get/put char/short/long.
494  * Pointer is advanced; we assume that both arguments
495  * are lvalues and will already be in registers.
496  * cp MUST be u_char *.
497  */
498 #define GETCHAR(c, cp) { \
499  (c) = *(cp)++; \
500 }
501 #define PUTCHAR(c, cp) { \
502  *(cp)++ = (u_char) (c); \
503 }
504
505
506 #define GETSHORT(s, cp) { \
507  (s) = *(cp)++ << 8; \
508  (s) |= *(cp)++; \
509 }
510 #define PUTSHORT(s, cp) { \
511  *(cp)++ = (u_char) ((s) >> 8); \
512  *(cp)++ = (u_char) (s); \
513 }
514
515 #define GETLONG(l, cp) { \
516  (l) = *(cp)++ << 8; \
517  (l) |= *(cp)++; (l) <<= 8; \
518  (l) |= *(cp)++; (l) <<= 8; \
519  (l) |= *(cp)++; \
520 }
521 #define PUTLONG(l, cp) { \
522  *(cp)++ = (u_char) ((l) >> 24); \
523  *(cp)++ = (u_char) ((l) >> 16); \
524  *(cp)++ = (u_char) ((l) >> 8); \
525  *(cp)++ = (u_char) (l); \
526 }
527
528 #define INCPTR(n, cp) ((cp) += (n))
529 #define DECPTR(n, cp) ((cp) -= (n))
530
531 /*
532  * System dependent definitions for user-level 4.3BSD UNIX implementation.
533  */
534
535 #define TIMEOUT(r, f, t) ppptimeout((r), (f), (t))
536 #define UNTIMEOUT(r, f) pppuntimeout((r), (f))
537
538 #define BCOPY(s, d, l) memcpy(d, s, l)
539 #define BZERO(s, n) memset(s, 0, n)
540
541 #define PRINTMSG(m, l) { info("Remote message: %0.*v", l, m); }
542
543 /*
544  * MAKEHEADER - Add Header fields to a packet.
545  */
546 #define MAKEHEADER(p, t) { \
547  PUTCHAR(PPP_ALLSTATIONS, p); \
548  PUTCHAR(PPP_UI, p); \
549  PUTSHORT(t, p); }
550
551 /*
552  * Exit status values.
553  */
554 #define EXIT_OK 0
555 #define EXIT_FATAL_ERROR 1
556 #define EXIT_OPTION_ERROR 2
557 #define EXIT_NOT_ROOT 3
558 #define EXIT_NO_KERNEL_SUPPORT 4
559 #define EXIT_USER_REQUEST 5
560 #define EXIT_LOCK_FAILED 6
561 #define EXIT_OPEN_FAILED 7
562 #define EXIT_CONNECT_FAILED 8
563 #define EXIT_PTYCMD_FAILED 9
564 #define EXIT_NEGOTIATION_FAILED 10
565 #define EXIT_PEER_AUTH_FAILED 11
566 #define EXIT_IDLE_TIMEOUT 12
567 #define EXIT_CONNECT_TIME 13
568 #define EXIT_CALLBACK 14
569 #define EXIT_PEER_DEAD 15
570 #define EXIT_HANGUP 16
571 #define EXIT_LOOPBACK 17
572 #define EXIT_INIT_FAILED 18
573 #define EXIT_AUTH_TOPEER_FAILED 19
574
575 /*
576  * Debug macros. Slightly useful for finding bugs in pppd, not particularly
577  * useful for finding out why your connection isn't being established.
578  */
579
580 #ifdef DEBUGALL
581 #define DEBUGMAIN 1
582 #define DEBUGFSM 1
583 #define DEBUGLCP 1
584 #define DEBUGIPCP 1
585 #define DEBUGIPV6CP 1
586 #define DEBUGUPAP 1
587 #define DEBUGCHAP 1
588 #endif
589 #define DEBUGMAIN 1
590 #define DEBUGUPAP 1
591 #define DEBUGCHAP 1
592
593
594 #ifdef DEBUGMAIN
595 #define MAINDEBUG(x) if (debug) dbglog x
596 #else
597 #define MAINDEBUG(x)
598 #endif
599
600 #ifdef DEBUGSYS
601 #define SYSDEBUG(x) if (debug) dbglog x
602 #else
603 #define SYSDEBUG(x)
604 #endif
605
606 #ifdef DEBUGFSM
607 #define FSMDEBUG(x) if (debug) dbglog x
608 #else
609 #define FSMDEBUG(x)
610 #endif
611
612 #ifdef DEBUGLCP
613 #define LCPDEBUG(x) if (debug) dbglog x
614 #else
615 #define LCPDEBUG(x)
616 #endif
617
618 #ifdef DEBUGIPCP
619 #define IPCPDEBUG(x) if (debug) dbglog x
620 #else
621 #define IPCPDEBUG(x)
622 #endif
623
624 #ifdef DEBUGIPV6CP
625 #define IPV6CPDEBUG(x) if (debug) dbglog x
626 #else
627 #define IPV6CPDEBUG(x)
628 #endif
629
630 #ifdef DEBUGUPAP
631 #define UPAPDEBUG(x) if (debug) dbglog x
632 #else
633 #define UPAPDEBUG(x)
634 #endif
635
636 #ifdef DEBUGCHAP
637 #define CHAPDEBUG(x) if (debug) dbglog x
638 #else
639 #define CHAPDEBUG(x)
640 #endif
641
642 #ifdef DEBUGIPXCP
643 #define IPXCPDEBUG(x) if (debug) dbglog x
644 #else
645 #define IPXCPDEBUG(x)
646 #endif
647
648 #ifndef SIGTYPE
649 #if defined(sun) || defined(SYSV) || defined(POSIX_SOURCE)
650 #define SIGTYPE void
651 #else
652 #define SIGTYPE int
653 #endif /* defined(sun) || defined(SYSV) || defined(POSIX_SOURCE) */
654 #endif /* SIGTYPE */
655
656 #endif /* __PPP_H__ */
Definition: pppd.h:464
Definition: pppd.h:73
Definition: pppd.h:114
Definition: mount_prot.h:53
Definition: bpf.h:68
Definition: pppd.h:126
Definition: ppp_defs.h:147
Definition: pppd.h:132
Definition: pppd.h:250
int open(const char *path, int oflag,...)
POSIX 1003.1 5.3.1 - Open a File.
Definition: open.c:130
like strcat/strncat, doesn&#39;t overflow destination buffer, always leaves destination null-terminated (...
Definition: strlcat.c:38
