if_ppp.h
1 /*
2  * if_ppp.h - Point-to-Point Protocol definitions.
3  *
4  * Copyright (c) 1989 Carnegie Mellon University.
5  * All rights reserved.
6  *
7  * Redistribution and use in source and binary forms are permitted
8  * provided that the above copyright notice and this paragraph are
9  * duplicated in all such forms and that any documentation,
10  * advertising materials, and other materials related to such
11  * distribution and use acknowledge that the software was developed
12  * by Carnegie Mellon University. The name of the
13  * University may not be used to endorse or promote products derived
14  * from this software without specific prior written permission.
15  * THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16  * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18  *
19  * $FreeBSD: src/sys/net/if_ppp.h,v 1.15 2005/01/07 01:45:34 imp Exp $
20  */
21
22
23 #ifndef _IF_PPP_H_
24 #define _IF_PPP_H_
25
26 #include <net/ppp_defs.h> /* NPmode */
27 #include <net/if.h> /* IFNAMSIZ */
28
29 /*
30  * Packet sizes
31  */
32 #define PPP_MTU 1500 /* Default MTU (size of Info field) */
33 #define PPP_MAXMRU 65000 /* Largest MRU we allow */
34 #define PPP_MAXMTU 16384 /* Largest MTU we allow */
35
36 /*
37  * Bit definitions for flags.
38  */
39 #define SC_COMP_PROT 0x00000001 /* protocol compression (output) */
40 #define SC_COMP_AC 0x00000002 /* header compression (output) */
41 #define SC_COMP_TCP 0x00000004 /* TCP (VJ) compression (output) */
42 #define SC_NO_TCP_CCID 0x00000008 /* disable VJ connection-id comp. */
43 #define SC_REJ_COMP_AC 0x00000010 /* reject adrs/ctrl comp. on input */
44 #define SC_REJ_COMP_TCP 0x00000020 /* reject TCP (VJ) comp. on input */
45 #define SC_CCP_OPEN 0x00000040 /* Look at CCP packets */
46 #define SC_CCP_UP 0x00000080 /* May send/recv compressed packets */
47 #define SC_DEBUG 0x00010000 /* enable debug messages */
48 #define SC_LOG_INPKT 0x00020000 /* log contents of good pkts recvd */
49 #define SC_LOG_OUTPKT 0x00040000 /* log contents of pkts sent */
50 #define SC_LOG_RAWIN 0x00080000 /* log all chars received */
51 #define SC_LOG_FLUSH 0x00100000 /* log all chars flushed */
52 #define SC_RCV_B7_0 0x01000000 /* have rcvd char with bit 7 = 0 */
53 #define SC_RCV_B7_1 0x02000000 /* have rcvd char with bit 7 = 1 */
54 #define SC_RCV_EVNP 0x04000000 /* have rcvd char with even parity */
55 #define SC_RCV_ODDP 0x08000000 /* have rcvd char with odd parity */
56 #define SC_SYNC 0x00200000 /* use synchronous HDLC framing */
57 #define SC_MASK 0x0fff00ff /* bits that user can change */
58
59 /*
60  * State bits in sc_flags, not changeable by user.
61  */
62 #define SC_TIMEOUT 0x00000400 /* timeout is currently pending */
63 #define SC_VJ_RESET 0x00000800 /* need to reset VJ decomp */
64 #define SC_COMP_RUN 0x00001000 /* compressor has been initiated */
65 #define SC_DECOMP_RUN 0x00002000 /* decompressor has been initiated */
66 #define SC_DC_ERROR 0x00004000 /* non-fatal decomp error detected */
67 #define SC_DC_FERROR 0x00008000 /* fatal decomp error detected */
68 #define SC_TBUSY 0x10000000 /* xmitter doesn't need a packet yet */
69 #define SC_PKTLOST 0x20000000 /* have lost or dropped a packet */
70 #define SC_FLUSH 0x40000000 /* flush input until next PPP_FLAG */
71 #define SC_ESCAPED 0x80000000 /* saw a PPP_ESCAPE */
72
73 /*
74  * Ioctl definitions.
75  */
76
77 struct npioctl {
78  int protocol; /* PPP procotol, e.g. PPP_IP */
79  enum NPmode mode;
80 };
81
82 /* Structure describing a CCP configuration option, for PPPIOCSCOMPRESS */
83 struct ppp_option_data {
84  u_char *ptr;
85  u_int length;
86  int transmit;
87 };
88
89 struct ifpppstatsreq {
90  char ifr_name[IFNAMSIZ];
91  struct ppp_stats stats;
92 };
93
94 struct ifpppcstatsreq {
95  char ifr_name[IFNAMSIZ];
96  struct ppp_comp_stats stats;
97 };
98
99 /*
100  * Ioctl definitions.
101  */
102
103 #define PPPIOCSTASK _IOW('t', 91, int) /* set pppd task id */
104 #define PPPIOCGFLAGS _IOR('t', 90, int) /* get configuration flags */
105 #define PPPIOCSFLAGS _IOW('t', 89, int) /* set configuration flags */
106 #define PPPIOCGASYNCMAP _IOR('t', 88, int) /* get async map */
107 #define PPPIOCSASYNCMAP _IOW('t', 87, int) /* set async map */
108 #define PPPIOCGUNIT _IOR('t', 86, int) /* get ppp unit number */
109 #define PPPIOCGRASYNCMAP _IOR('t', 85, int) /* get receive async map */
110 #define PPPIOCSRASYNCMAP _IOW('t', 84, int) /* set receive async map */
111 #define PPPIOCGMRU _IOR('t', 83, int) /* get max receive unit */
112 #define PPPIOCSMRU _IOW('t', 82, int) /* set max receive unit */
113 #define PPPIOCSMAXCID _IOW('t', 81, int) /* set VJ max slot ID */
114 #define PPPIOCGXASYNCMAP _IOR('t', 80, ext_accm) /* get extended ACCM */
115 #define PPPIOCSXASYNCMAP _IOW('t', 79, ext_accm) /* set extended ACCM */
116 #define PPPIOCXFERUNIT _IO('t', 78) /* transfer PPP unit */
117 #define PPPIOCSCOMPRESS _IOW('t', 77, struct ppp_option_data)
118 #define PPPIOCGNPMODE _IOWR('t', 76, struct npioctl) /* get NP mode */
119 #define PPPIOCSNPMODE _IOW('t', 75, struct npioctl) /* set NP mode */
120 #define PPPIOCGIDLE _IOR('t', 74, struct ppp_idle) /* get idle time */
121 #ifdef PPP_FILTER
122 #define PPPIOCSPASS _IOW('t', 71, struct bpf_program) /* set pass filter */
123 #define PPPIOCSACTIVE _IOW('t', 70, struct bpf_program) /* set active filt */
124 #endif /* PPP_FILTER */
125
126 /* PPPIOC[GS]MTU are alternatives to SIOC[GS]IFMTU, used under Ultrix */
127 #define PPPIOCGMTU _IOR('t', 73, int) /* get interface MTU */
128 #define PPPIOCSMTU _IOW('t', 72, int) /* set interface MTU */
129
130 /*
131  * These two are interface ioctls so that pppstats can do them on
132  * a socket without having to open the serial device.
133  */
134 #define SIOCGPPPSTATS _IOWR('i', 123, struct ifpppstatsreq)
135 #define SIOCGPPPCSTATS _IOWR('i', 122, struct ifpppcstatsreq)
136
137 #if !defined(ifr_mtu)
138 #define ifr_mtu ifr_ifru.ifru_metric
139 #endif
140
141 #endif /* _IF_PPP_H_ */
Definition: if_ppp.h:84
Definition: if_ppp.h:78
Definition: if_ppp.h:90
Definition: if_ppp.h:95
Definition: ppp_defs.h:123
Definition: ppp_defs.h:138
