pppd
ipcp.h
1
2
* ipcp.h - IP Control Protocol definitions.
3
4
* Copyright (c) 1989 Carnegie Mellon University.
5
* All rights reserved.
6
7
* Redistribution and use in source and binary forms are permitted
8
* provided that the above copyright notice and this paragraph are
9
* duplicated in all such forms and that any documentation,
10
* advertising materials, and other materials related to such
11
* distribution and use acknowledge that the software was developed
12
* by Carnegie Mellon University. The name of the
13
* University may not be used to endorse or promote products derived
14
* from this software without specific prior written permission.
15
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16
* IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17
* WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18
19
* $Id$
20
21
22
23
* Options.
24
25
#define CI_ADDRS 1
/* IP Addresses */
26
#define CI_COMPRESSTYPE 2
/* Compression Type */
27
#define CI_ADDR 3
28
29
#define CI_MS_DNS1 129
/* Primary DNS value */
30
#define CI_MS_WINS1 130
/* Primary WINS value */
31
#define CI_MS_DNS2 131
/* Secondary DNS value */
32
#define CI_MS_WINS2 132
/* Secondary WINS value */
33
34
#define MAX_STATES 16
/* from slcompress.h */
35
36
#define IPCP_VJMODE_OLD 1
/* "old" mode (option # = 0x0037) */
37
#define IPCP_VJMODE_RFC1172 2
/* "old-rfc"mode (option # = 0x002d) */
38
#define IPCP_VJMODE_RFC1332 3
/* "new-rfc"mode (option # = 0x002d, */
39
/* maxslot and slot number compression) */
40
41
#define IPCP_VJ_COMP 0x002d
/* current value for VJ compression option*/
42
#define IPCP_VJ_COMP_OLD 0x0037
/* "old" (i.e, broken) value for VJ */
43
/* compression option*/
44
45
typedef
struct
ipcp_options
46
bool
neg_addr;
/* Negotiate IP Address? */
47
bool
old_addrs;
/* Use old (IP-Addresses) option? */
48
bool
req_addr;
/* Ask peer to send IP address? */
49
bool
default_route;
/* Assign default route through interface? */
50
bool
proxy_arp;
/* Make proxy ARP entry for peer? */
51
bool
neg_vj;
/* Van Jacobson Compression? */
52
bool
old_vj;
/* use old (short) form of VJ option? */
53
bool
accept_local;
/* accept peer's value for ouraddr */
54
bool
accept_remote;
/* accept peer's value for hisaddr */
55
bool
req_dns1;
/* Ask peer to send primary DNS address? */
56
bool
req_dns2;
/* Ask peer to send secondary DNS address? */
57
int
vj_protocol;
/* protocol value to use in VJ option */
58
int
maxslotindex;
/* values for RFC1332 VJ compression neg. */
59
bool
cflag;
60
uint32_t ouraddr, hisaddr;
/* Addresses in NETWORK BYTE ORDER */
61
uint32_t dnsaddr[2];
/* Primary and secondary MS DNS entries */
62
uint32_t winsaddr[2];
/* Primary and secondary MS WINS entries */
63
ipcp_options
64
65
extern
fsm
ipcp_fsm[];
66
extern
ipcp_options
ipcp_wantoptions[];
67
extern
ipcp_options
ipcp_gotoptions[];
68
extern
ipcp_options
ipcp_allowoptions[];
69
extern
ipcp_options
ipcp_hisoptions[];
70
71
char
*ip_ntoa(uint32_t);
72
73
extern
struct
protent
ipcp_protent;
fsm
Definition:
fsm.h:44
protent
Definition:
pppd.h:250
ipcp_options
Definition:
ipcp.h:46
