RTEMS 6.1
Data Structures | Macros
FMC Low Layer Exported Types
struct  FMC_NORSRAM_InitTypeDef
 FMC NORSRAM Configuration Structure definition. More...
struct  FMC_NORSRAM_TimingTypeDef
 FMC NORSRAM Timing parameters structure definition. More...
struct  FMC_NAND_InitTypeDef
 FMC NAND Configuration Structure definition. More...
struct  FMC_NAND_PCC_TimingTypeDef
 FMC NAND Timing parameters structure definition. More...
struct  FMC_SDRAM_InitTypeDef
 FMC SDRAM Configuration Structure definition. More...
struct  FMC_SDRAM_TimingTypeDef
 FMC SDRAM Timing parameters structure definition. More...
struct  FMC_SDRAM_CommandTypeDef
 SDRAM command parameters structure definition. More...
#define FMC_NORSRAM_TypeDef   FMC_Bank1_TypeDef
#define FMC_NORSRAM_EXTENDED_TypeDef   FMC_Bank1E_TypeDef
#define FMC_NAND_TypeDef   FMC_Bank3_TypeDef
#define FMC_SDRAM_TypeDef   FMC_Bank5_6_TypeDef
#define FMC_NORSRAM_DEVICE   FMC_Bank1_R
#define FMC_NORSRAM_EXTENDED_DEVICE   FMC_Bank1E_R
#define FMC_NAND_DEVICE   FMC_Bank3_R
#define FMC_SDRAM_DEVICE   FMC_Bank5_6_R
