RTEMS 6.1
FMC_NORSRAM_InitTypeDef Struct Reference
FMC NORSRAM Configuration Structure definition. More...
#include <stm32h7xx_ll_fmc.h>
uint32_t NSBank
uint32_t DataAddressMux
uint32_t MemoryType
uint32_t MemoryDataWidth
uint32_t BurstAccessMode
uint32_t WaitSignalPolarity
uint32_t WaitSignalActive
uint32_t WriteOperation
uint32_t WaitSignal
uint32_t ExtendedMode
uint32_t AsynchronousWait
uint32_t WriteBurst
uint32_t ContinuousClock
uint32_t WriteFifo
uint32_t PageSize
Field Documentation
◆ AsynchronousWait
uint32_t FMC_NORSRAM_InitTypeDef::AsynchronousWait
Enables or disables wait signal during asynchronous transfers, valid only with asynchronous Flash memories. This parameter can be a value of FMC Asynchronous Wait
◆ BurstAccessMode
uint32_t FMC_NORSRAM_InitTypeDef::BurstAccessMode
Enables or disables the burst access mode for Flash memory, valid only with synchronous burst Flash memories. This parameter can be a value of FMC Burst Access Mode
◆ ContinuousClock
uint32_t FMC_NORSRAM_InitTypeDef::ContinuousClock
Enables or disables the FMC clock output to external memory devices. This parameter is only enabled through the FMC_BCR1 register, and don't care through FMC_BCR2..4 registers. This parameter can be a value of FMC Continuous Clock
◆ DataAddressMux
uint32_t FMC_NORSRAM_InitTypeDef::DataAddressMux
Specifies whether the address and data values are multiplexed on the data bus or not. This parameter can be a value of FMC Data Address Bus Multiplexing
◆ ExtendedMode
uint32_t FMC_NORSRAM_InitTypeDef::ExtendedMode
Enables or disables the extended mode. This parameter can be a value of FMC Extended Mode
◆ MemoryDataWidth
uint32_t FMC_NORSRAM_InitTypeDef::MemoryDataWidth
Specifies the external memory device width. This parameter can be a value of FMC NORSRAM Data Width
◆ MemoryType
uint32_t FMC_NORSRAM_InitTypeDef::MemoryType
Specifies the type of external memory attached to the corresponding memory device. This parameter can be a value of FMC Memory Type
◆ NSBank
uint32_t FMC_NORSRAM_InitTypeDef::NSBank
Specifies the NORSRAM memory device that will be used. This parameter can be a value of FMC NOR/SRAM Bank
◆ PageSize
uint32_t FMC_NORSRAM_InitTypeDef::PageSize
Specifies the memory page size. This parameter can be a value of FMC Page Size
◆ WaitSignal
uint32_t FMC_NORSRAM_InitTypeDef::WaitSignal
Enables or disables the wait state insertion via wait signal, valid for Flash memory access in burst mode. This parameter can be a value of FMC Wait Signal
◆ WaitSignalActive
uint32_t FMC_NORSRAM_InitTypeDef::WaitSignalActive
Specifies if the wait signal is asserted by the memory one clock cycle before the wait state or during the wait state, valid only when accessing memories in burst mode. This parameter can be a value of FMC Wait Timing
◆ WaitSignalPolarity
uint32_t FMC_NORSRAM_InitTypeDef::WaitSignalPolarity
Specifies the wait signal polarity, valid only when accessing the Flash memory in burst mode. This parameter can be a value of FMC Wait Signal Polarity
◆ WriteBurst
uint32_t FMC_NORSRAM_InitTypeDef::WriteBurst
Enables or disables the write burst operation. This parameter can be a value of FMC Write Burst
◆ WriteFifo
uint32_t FMC_NORSRAM_InitTypeDef::WriteFifo
Enables or disables the write FIFO used by the FMC controller. This parameter is only enabled through the FMC_BCR1 register, and don't care through FMC_BCR2..4 registers. This parameter can be a value of FMC_Write_FIFO
◆ WriteOperation
uint32_t FMC_NORSRAM_InitTypeDef::WriteOperation
Enables or disables the write operation in the selected device by the FMC. This parameter can be a value of FMC Write Operation
