RTEMS 6.1
FMC SDRAM Configuration Structure definition. More...
#include <stm32h7xx_ll_fmc.h>
uint32_t SDBank
uint32_t ColumnBitsNumber
uint32_t RowBitsNumber
uint32_t MemoryDataWidth
uint32_t InternalBankNumber
uint32_t CASLatency
uint32_t WriteProtection
uint32_t SDClockPeriod
uint32_t ReadBurst
uint32_t ReadPipeDelay
Field Documentation
◆ CASLatency
uint32_t FMC_SDRAM_InitTypeDef::CASLatency
Defines the SDRAM CAS latency in number of memory clock cycles. This parameter can be a value of FMC SDRAM CAS Latency.
◆ ColumnBitsNumber
uint32_t FMC_SDRAM_InitTypeDef::ColumnBitsNumber
Defines the number of bits of column address. This parameter can be a value of FMC SDRAM Column Bits number.
◆ InternalBankNumber
uint32_t FMC_SDRAM_InitTypeDef::InternalBankNumber
Defines the number of the device's internal banks. This parameter can be of FMC SDRAM Internal Banks Number.
◆ MemoryDataWidth
uint32_t FMC_SDRAM_InitTypeDef::MemoryDataWidth
Defines the memory device width. This parameter can be a value of FMC SDRAM Memory Bus Width.
◆ ReadBurst
uint32_t FMC_SDRAM_InitTypeDef::ReadBurst
This bit enable the SDRAM controller to anticipate the next read commands during the CAS latency and stores data in the Read FIFO. This parameter can be a value of FMC SDRAM Read Burst.
◆ ReadPipeDelay
uint32_t FMC_SDRAM_InitTypeDef::ReadPipeDelay
Define the delay in system clock cycles on read data path. This parameter can be a value of FMC SDRAM Read Pipe Delay.
◆ RowBitsNumber
uint32_t FMC_SDRAM_InitTypeDef::RowBitsNumber
Defines the number of bits of column address. This parameter can be a value of FMC SDRAM Row Bits number.
◆ SDBank
uint32_t FMC_SDRAM_InitTypeDef::SDBank
Specifies the SDRAM memory device that will be used. This parameter can be a value of FMC SDRAM Bank
◆ SDClockPeriod
uint32_t FMC_SDRAM_InitTypeDef::SDClockPeriod
Define the SDRAM Clock Period for both SDRAM devices and they allow to disable the clock before changing frequency. This parameter can be a value of FMC SDRAM Clock Period.
◆ WriteProtection
uint32_t FMC_SDRAM_InitTypeDef::WriteProtection
Enables the SDRAM device to be accessed in write mode. This parameter can be a value of FMC SDRAM Write Protection.
