RTEMS 6.1
FMC_NORSRAM_TimingTypeDef Struct Reference
FMC NORSRAM Timing parameters structure definition. More...
#include <stm32h7xx_ll_fmc.h>
uint32_t AddressSetupTime
uint32_t AddressHoldTime
uint32_t DataSetupTime
uint32_t BusTurnAroundDuration
uint32_t CLKDivision
uint32_t DataLatency
uint32_t AccessMode
Field Documentation
◆ AccessMode
uint32_t FMC_NORSRAM_TimingTypeDef::AccessMode
Specifies the asynchronous access mode. This parameter can be a value of FMC Access Mode
◆ AddressHoldTime
uint32_t FMC_NORSRAM_TimingTypeDef::AddressHoldTime
Defines the number of HCLK cycles to configure the duration of the address hold time. This parameter can be a value between Min_Data = 1 and Max_Data = 15.
Note
This parameter is not used with synchronous NOR Flash memories.
◆ AddressSetupTime
uint32_t FMC_NORSRAM_TimingTypeDef::AddressSetupTime
Defines the number of HCLK cycles to configure the duration of the address setup time. This parameter can be a value between Min_Data = 0 and Max_Data = 15.
Note
◆ BusTurnAroundDuration
uint32_t FMC_NORSRAM_TimingTypeDef::BusTurnAroundDuration
Defines the number of HCLK cycles to configure the duration of the bus turnaround. This parameter can be a value between Min_Data = 0 and Max_Data = 15.
Note
This parameter is only used for multiplexed NOR Flash memories.
◆ CLKDivision
uint32_t FMC_NORSRAM_TimingTypeDef::CLKDivision
Defines the period of CLK clock output signal, expressed in number of HCLK cycles. This parameter can be a value between Min_Data = 2 and Max_Data = 16.
Note
This parameter is not used for asynchronous NOR Flash, SRAM or ROM accesses.
◆ DataLatency
uint32_t FMC_NORSRAM_TimingTypeDef::DataLatency
Defines the number of memory clock cycles to issue to the memory before getting the first data. The parameter value depends on the memory type as shown below:
  • It must be set to 0 in case of a CRAM
  • It is don't care in asynchronous NOR, SRAM or ROM accesses
  • It may assume a value between Min_Data = 2 and Max_Data = 17 in NOR Flash memories with synchronous burst mode enable
◆ DataSetupTime
uint32_t FMC_NORSRAM_TimingTypeDef::DataSetupTime
Defines the number of HCLK cycles to configure the duration of the data setup time. This parameter can be a value between Min_Data = 1 and Max_Data = 255.
Note
This parameter is used for SRAMs, ROMs and asynchronous multiplexed NOR Flash memories.
