RTEMS 6.1
Flexible Memory Controller Bank5 and 6. More...
#include <stm32h723xx.h>
__IO uint32_t SDCR [2]
__IO uint32_t SDTR [2]
__IO uint32_t SDCMR
__IO uint32_t SDRTR
__IO uint32_t SDSR
Field Documentation
◆ SDCMR
__IO uint32_t FMC_Bank5_6_TypeDef::SDCMR
SDRAM Command Mode register, Address offset: 0x150
◆ SDCR
__IO uint32_t FMC_Bank5_6_TypeDef::SDCR
SDRAM Control registers , Address offset: 0x140-0x144
◆ SDRTR
__IO uint32_t FMC_Bank5_6_TypeDef::SDRTR
SDRAM Refresh Timer register, Address offset: 0x154
◆ SDSR
__IO uint32_t FMC_Bank5_6_TypeDef::SDSR
SDRAM Status register, Address offset: 0x158
◆ SDTR
__IO uint32_t FMC_Bank5_6_TypeDef::SDTR
SDRAM Timing registers , Address offset: 0x148-0x14C
The documentation for this struct was generated from the following files:
