RTEMS 6.1
FMC_SDRAM_CommandTypeDef Struct Reference
SDRAM command parameters structure definition. More...
#include <stm32h7xx_ll_fmc.h>
uint32_t CommandMode
uint32_t CommandTarget
uint32_t AutoRefreshNumber
uint32_t ModeRegisterDefinition
Field Documentation
◆ AutoRefreshNumber
uint32_t FMC_SDRAM_CommandTypeDef::AutoRefreshNumber
Defines the number of consecutive auto refresh command issued in auto refresh mode. This parameter can be a value between Min_Data = 1 and Max_Data = 15
◆ CommandMode
uint32_t FMC_SDRAM_CommandTypeDef::CommandMode
Defines the command issued to the SDRAM device. This parameter can be a value of FMC SDRAM Command Mode.
◆ CommandTarget
uint32_t FMC_SDRAM_CommandTypeDef::CommandTarget
Defines which device (1 or 2) the command will be issued to. This parameter can be a value of FMC SDRAM Command Target.
◆ ModeRegisterDefinition
uint32_t FMC_SDRAM_CommandTypeDef::ModeRegisterDefinition
Defines the SDRAM Mode register content
