RTEMS 5.2
z8530.h
1
10/*
11 * COPYRIGHT (c) 1989-2011.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_ZILOG_Z8530_H
20#define _RTEMS_ZILOG_Z8530_H
21
22#ifdef __cplusplus
23extern "C" {
24#endif
25
26/* macros */
27
28#define VOL8( ptr ) ((volatile uint8_t *)(ptr))
29
30#define Z8x30_STATE0 ( z8530 ) \
31 { char *garbage; \
32 (garbage) = *(VOL8(z8530)) \
33 }
34
35#define Z8x30_WRITE_CONTROL( z8530, reg, data ) \
36 *(VOL8(z8530)) = (reg); \
37 *(VOL8(z8530)) = (data)
38
39#define Z8x30_READ_CONTROL( z8530, reg, data ) \
40 *(VOL8(z8530)) = (reg); \
41 (data) = *(VOL8(z8530))
42
43#define Z8x30_WRITE_DATA( z8530, data ) \
44 *(VOL8(z8530)) = (data);
45
46#define Z8x30_READ_DATA( z8530, data ) \
47 (data) = *(VOL8(z8530));
48
49
50/* RR_0 Bit Definitions */
51
52#define RR_0_TX_BUFFER_EMPTY 0x04
53#define RR_0_RX_DATA_AVAILABLE 0x01
54
55/* read registers */
56
57#define RR_0 0x00
58#define RR_1 0x01
59#define RR_2 0x02
60#define RR_3 0x03
61#define RR_4 0x04
62#define RR_5 0x05
63#define RR_6 0x06
64#define RR_7 0x07
65#define RR_8 0x08
66#define RR_9 0x09
67#define RR_10 0x0A
68#define RR_11 0x0B
69#define RR_12 0x0C
70#define RR_13 0x0D
71#define RR_14 0x0E
72#define RR_15 0x0F
73
74/* write registers */
75
76#define WR_0 0x00
77#define WR_1 0x01
78#define WR_2 0x02
79#define WR_3 0x03
80#define WR_4 0x04
81#define WR_5 0x05
82#define WR_6 0x06
83#define WR_7 0x07
84#define WR_8 0x08
85#define WR_9 0x09
86#define WR_10 0x0A
87#define WR_11 0x0B
88#define WR_12 0x0C
89#define WR_13 0x0D
90#define WR_14 0x0E
91#define WR_15 0x0F
92
93#ifdef __cplusplus
94}
95#endif
96
97#endif
