RTEMS 5.2
sonic.h
1/*
2 * RTEMS NETWORK DRIVER FOR NATIONAL DP83932 `SONIC'
3 * SYSTEMS-ORIENTED NETWORK INTERFACE CONTROLLER
4 *
5 * REUSABLE CHIP DRIVER CONFIGURATION
6 *
7 * References:
8 *
9 * 1) DP83932C-20/25/33 MHz SONIC(TM) Systems-Oriented Network Interface
10 * Controller data sheet. TL/F/10492, RRD-B30M105, National Semiconductor,
11 * 1995.
12 *
13 * 2) Software Driver Programmer's Guide for the DP83932 SONIC(TM),
14 * Application Note 746, Wesley Lee and Mike Lui, TL/F/11140,
15 * RRD-B30M75, National Semiconductor, March, 1991.
16 *
17 * COPYRIGHT (c) 1989-1997.
18 * On-Line Applications Research Corporation (OAR).
19 *
20 * The license and distribution terms for this file may be
21 * found in the file LICENSE in this distribution or at
22 * http://www.rtems.org/license/LICENSE.
23 */
24
25#ifndef _SONIC_DP83932_
26#define _SONIC_DP83932_
27
28
29 /*
30 * Debug levels
31 *
32 */
33
34#define SONIC_DEBUG_NONE 0x0000
35#define SONIC_DEBUG_ALL 0xFFFF
36#define SONIC_DEBUG_PRINT_REGISTERS 0x0001
37#define SONIC_DEBUG_MEMORY 0x0002
38#define SONIC_DEBUG_MEMORY_ALLOCATE 0x0004
39#define SONIC_DEBUG_MEMORY_DESCRIPTORS 0x0008
40#define SONIC_DEBUG_FRAGMENTS 0x0008
41#define SONIC_DEBUG_CAM 0x0010
42#define SONIC_DEBUG_DESCRIPTORS 0x0020
43#define SONIC_DEBUG_ERRORS 0x0040
44#define SONIC_DEBUG_DUMP_TX_MBUFS 0x0080
45#define SONIC_DEBUG_DUMP_RX_MBUFS 0x0100
46
47#define SONIC_DEBUG_DUMP_MBUFS \
48 (SONIC_DEBUG_DUMP_TX_MBUFS|SONIC_DEBUG_DUMP_RX_MBUFS)
49
50#define SONIC_DEBUG (SONIC_DEBUG_NONE)
51/*
52#define SONIC_DEBUG (SONIC_DEBUG_ERRORS | SONIC_DEBUG_PRINT_REGISTERS |\
53 SONIC_DEBUG_DESCRIPTORS)
54*/
55
56/*
57 ((SONIC_DEBUG_ALL) & ~(SONIC_DEBUG_PRINT_REGISTERS|SONIC_DEBUG_DUMP_MBUFS))
58 ((SONIC_DEBUG_ALL) & ~(SONIC_DEBUG_DUMP_MBUFS))
59*/
60
61#if (SONIC_DEBUG & SONIC_DEBUG_PRINT_REGISTERS)
62extern char SONIC_Reg_name[64][6];
63#endif
64
65
66/*
67 * Configuration Information
68 */
69
70typedef void (*sonic_write_register_t)(
71 void *base,
72 uint32_t regno,
73 uint32_t value
74);
75
76typedef uint32_t (*sonic_read_register_t)(
77 void *base,
78 uint32_t regno
79);
80
81typedef struct {
82 void *base_address;
83 uint32_t vector;
84 uint32_t dcr_value;
85 uint32_t dc2_value;
86 uint32_t tda_count;
87 uint32_t rda_count;
88 sonic_write_register_t write_register;
89 sonic_read_register_t read_register;
91
92/*
93 ******************************************************************
94 * *
95 * Device Registers *
96 * *
97 ******************************************************************
98 */
99#define SONIC_REG_CR 0x00 /* Command */
100#define SONIC_REG_DCR 0x01 /* Data configuration */
101#define SONIC_REG_RCR 0x02 /* Receive control */
102#define SONIC_REG_TCR 0x03 /* Transmit control */
103#define SONIC_REG_IMR 0x04 /* Interrupt mask */
104#define SONIC_REG_ISR 0x05 /* Interrupt status */
105#define SONIC_REG_UTDA 0x06 /* Upper transmit descriptor address */
106#define SONIC_REG_CTDA 0x07 /* Current transmit descriptor address */
107#define SONIC_REG_URDA 0x0D /* Upper receive descriptor address */
108#define SONIC_REG_CRDA 0x0E /* Current receive descriptor address */
109#define SONIC_REG_EOBC 0x13 /* End of buffer word count */
110#define SONIC_REG_URRA 0x14 /* Upper receive resource */
111#define SONIC_REG_RSA 0x15 /* Resource start address */
112#define SONIC_REG_REA 0x16 /* Resource end address */
113#define SONIC_REG_RRP 0x17 /* Resouce read pointer */
114#define SONIC_REG_RWP 0x18 /* Resouce write pointer */
115#define SONIC_REG_CEP 0x21 /* CAM entry pointer */
116#define SONIC_REG_CAP2 0x22 /* CAM address port 2 */
117#define SONIC_REG_CAP1 0x23 /* CAM address port 1 */
118#define SONIC_REG_CAP0 0x24 /* CAM address port 0 */
119#define SONIC_REG_CE 0x25 /* CAM enable */
120#define SONIC_REG_CDP 0x26 /* CAM descriptor pointer */
121#define SONIC_REG_CDC 0x27 /* CAM descriptor count */
122#define SONIC_REG_SR 0x28 /* Silicon revision */
123#define SONIC_REG_WT0 0x29 /* Watchdog timer 0 */
124#define SONIC_REG_WT1 0x2A /* Watchdog timer 1 */
125#define SONIC_REG_RSC 0x2B /* Receive sequence counter */
126#define SONIC_REG_CRCT 0x2C /* CRC error tally */
127#define SONIC_REG_FAET 0x2D /* FAE tally */
128#define SONIC_REG_MPT 0x2E /* Missed packet tally */
129#define SONIC_REG_MDT 0x2F /* TX Maximum Deferral */
130#define SONIC_REG_DCR2 0x3F /* Data configuration 2 */
131
132/*
133 * Command register
134 */
135#define CR_LCAM 0x0200
136#define CR_RRRA 0x0100
137#define CR_RST 0x0080
138#define CR_ST 0x0020
139#define CR_STP 0x0010
140#define CR_RXEN 0x0008
141#define CR_RXDIS 0x0004
142#define CR_TXP 0x0002
143#define CR_HTX 0x0001
144
145/*
146 * Data configuration register
147 */
148#define DCR_EXBUS 0x8000
149#define DCR_LBR 0x2000
150#define DCR_PO1 0x1000
151#define DCR_PO0 0x0800
152#define DCR_SBUS 0x0400
153#define DCR_USR1 0x0200
154#define DCR_USR0 0x0100
155#define DCR_WC1 0x0080
156#define DCR_WC0 0x0040
157#define DCR_DW 0x0020
158#define DCR_BMS 0x0010
159#define DCR_RFT1 0x0008
160#define DCR_RFT0 0x0004
161#define DCR_TFT1 0x0002
162#define DCR_TFT0 0x0001
163
164/* data configuration register aliases */
165#define DCR_SYNC DCR_SBUS /* synchronous (memory cycle 2 clocks) */
166#define DCR_ASYNC 0 /* asynchronous (memory cycle 3 clocks) */
167
168#define DCR_WAIT0 0 /* 0 wait states added */
169#define DCR_WAIT1 DCR_WC0 /* 1 wait state added */
170#define DCR_WAIT2 DCR_WC1 /* 2 wait states added */
171#define DCR_WAIT3 (DCR_WC1|DCR_WC0) /* 3 wait states added */
172
173#define DCR_DW16 0 /* use 16-bit DMA accesses */
174#define DCR_DW32 DCR_DW /* use 32-bit DMA accesses */
175
176#define DCR_DMAEF 0 /* DMA until TX/RX FIFO has emptied/filled */
177#define DCR_DMABLOCK DCR_BMS /* DMA until RX/TX threshold crossed */
178
179#define DCR_RFT4 0 /* receive threshold 4 bytes */
180#define DCR_RFT8 DCR_RFT0 /* receive threshold 8 bytes */
181#define DCR_RFT16 DCR_RFT1 /* receive threshold 16 bytes */
182#define DCR_RFT24 (DCR_RFT1|DCR_RFT0) /* receive threshold 24 bytes */
183
184#define DCR_TFT8 0 /* transmit threshold 8 bytes */
185#define DCR_TFT16 DCR_TFT0 /* transmit threshold 16 bytes */
186#define DCR_TFT24 DCR_TFT1 /* transmit threshold 24 bytes */
187#define DCR_TFT28 (DCR_TFT1|DCR_TFT0) /* transmit threshold 28 bytes */
188
189/*
190 * Receive control register
191 */
192#define RCR_ERR 0x8000
193#define RCR_RNT 0x4000
194#define RCR_BRD 0x2000
195#define RCR_PRO 0x1000
196#define RCR_AMC 0x0800
197#define RCR_LB1 0x0400
198#define RCR_LB0 0x0200
199#define RCR_MC 0x0100
200#define RCR_BC 0x0080
201#define RCR_LPKT 0x0040
202#define RCR_CRS 0x0020
203#define RCR_COL 0x0010
204#define RCR_CRCR 0x0008
205#define RCR_FAER 0x0004
206#define RCR_LBK 0x0002
207#define RCR_PRX 0x0001
208
209/*
210 * Transmit control register
211 */
212#define TCR_PINT 0x8000
213#define TCR_POWC 0x4000
214#define TCR_CRCI 0x2000
215#define TCR_EXDIS 0x1000
216#define TCR_EXD 0x0400
217#define TCR_DEF 0x0200
218#define TCR_NCRS 0x0100
219#define TCR_CRSL 0x0080
220#define TCR_EXC 0x0040
221#define TCR_OWC 0x0020
222#define TCR_PMB 0x0008
223#define TCR_FU 0x0004
224#define TCR_BCM 0x0002
225#define TCR_PTX 0x0001
226
227/*
228 * Interrupt mask register
229 */
230#define IMR_BREN 0x4000
231#define IMR_HBLEN 0x2000
232#define IMR_LCDEN 0x1000
233#define IMR_PINTEN 0x0800
234#define IMR_PRXEN 0x0400
235#define IMR_PTXEN 0x0200
236#define IMR_TXEREN 0x0100
237#define IMR_TCEN 0x0080
238#define IMR_RDEEN 0x0040
239#define IMR_RBEEN 0x0020
240#define IMR_RBAEEN 0x0010
241#define IMR_CRCEN 0x0008
242#define IMR_FAEEN 0x0004
243#define IMR_MPEN 0x0002
244#define IMR_RFOEN 0x0001
245
246/*
247 * Interrupt status register
248 */
249#define ISR_BR 0x4000
250#define ISR_HBL 0x2000
251#define ISR_LCD 0x1000
252#define ISR_PINT 0x0800
253#define ISR_PKTRX 0x0400
254#define ISR_TXDN 0x0200
255#define ISR_TXER 0x0100
256#define ISR_TC 0x0080
257#define ISR_RDE 0x0040
258#define ISR_RBE 0x0020
259#define ISR_RBAE 0x0010
260#define ISR_CRC 0x0008
261#define ISR_FAE 0x0004
262#define ISR_MP 0x0002
263#define ISR_RFO 0x0001
264
265/*
266 * Data configuration register 2
267 */
268#define DCR2_EXPO3 0x8000
269#define DCR2_EXPO2 0x4000
270#define DCR2_EXPO1 0x2000
271#define DCR2_EXPO0 0x1000
272#define DCR2_HBDIS 0x0800
273#define DCR2_PH 0x0010
274#define DCR2_PCM 0x0004
275#define DCR2_PCNM 0x0002
276#define DCR2_RJCM 0x0001
277
278/*
279 * Known values for the Silicon Revision Register.
280 * Note that DP83934 has revision 5 and seems to work.
281 */
282
283#define SONIC_REVISION_B 4
284#define SONIC_REVISION_DP83934 5
285#define SONIC_REVISION_C 6
286
287/*
288 ******************************************************************
289 * *
290 * Transmit Buffer Management *
291 * *
292 ******************************************************************
293 */
294
295/*
296 * Transmit descriptor area entry.
297 * There is one transmit descriptor for each packet to be transmitted.
298 * Statically reserve space for up to MAXIMUM_FRAGS_PER_PACKET fragments
299 * per descriptor.
300 */
301#define MAXIMUM_FRAGS_PER_DESCRIPTOR 6
303 uint32_t status;
304 uint32_t pkt_config;
305 uint32_t pkt_size;
306 uint32_t frag_count;
307
308 /*
309 * Packet fragment pointers
310 */
312 uint32_t frag_lsw; /* LSW of fragment address */
313#define frag_link frag_lsw
314 uint32_t frag_msw; /* MSW of fragment address */
315 uint32_t frag_size;
316 } frag[MAXIMUM_FRAGS_PER_DESCRIPTOR];
317
318 /*
319 * Space for link if all fragment pointers are used.
320 */
321 uint32_t link_pad;
322
323 /*
324 * Extra RTEMS stuff
325 */
326 struct TransmitDescriptor *next; /* Circularly-linked list */
327 struct mbuf *mbufp; /* First mbuf in packet */
328 volatile uint32_t *linkp; /* Pointer to un[xxx].link */
329};
332
333/*
334 * Transmit Configuration.
335 * For standard Ethernet transmission, all bits in the transmit
336 * configuration field are set to 0.
337 */
338#define TDA_CONFIG_PINT 0x8000
339#define TDA_CONFIG_POWC 0x4000
340#define TDA_CONFIG_CRCI 0x2000
341#define TDA_CONFIG_EXDIS 0x1000
342
343/*
344 * Transmit status
345 */
346#define TDA_STATUS_COLLISION_MASK 0xF800
347#define TDA_STATUS_COLLISION_SHIFT 11
348#define TDA_STATUS_EXD 0x0400
349#define TDA_STATUS_DEF 0x0200
350#define TDA_STATUS_NCRS 0x0100
351#define TDA_STATUS_CRSL 0x0080
352#define TDA_STATUS_EXC 0x0040
353#define TDA_STATUS_OWC 0x0020
354#define TDA_STATUS_PMB 0x0008
355#define TDA_STATUS_FU 0x0004
356#define TDA_STATUS_BCM 0x0002
357#define TDA_STATUS_PTX 0x0001
358
359#define TDA_LINK_EOL 0x0001
360#define TDA_LINK_EOL_MASK 0xFFFE
361
362
363
364/*
365 ******************************************************************
366 * *
367 * Receive Buffer Management *
368 * *
369 ******************************************************************
370 */
371
372/*
373 * Receive resource area entry.
374 * There is one receive resource entry for each receive buffer area (RBA).
375 * This driver allows only one packet per receive buffer area, so one
376 * receive resource entry corresponds to one correctly-received packet.
377 */
379 uint32_t buff_ptr_lsw; /* LSW of RBA address */
380 uint32_t buff_ptr_msw; /* MSW of RBA address */
381 uint32_t buff_wc_lsw; /* LSW of RBA size (16-bit words) */
382 uint32_t buff_wc_msw; /* MSW of RBA size (16-bit words) */
383};
386
387/*
388 * Receive descriptor area entry.
389 * There is one receive descriptor for each packet received.
390 */
392 uint32_t status;
393 uint32_t byte_count;
394 uint32_t pkt_lsw; /* LSW of packet address */
395 uint32_t pkt_msw; /* MSW of packet address */
396 uint32_t seq_no;
397 uint32_t link;
398 uint32_t in_use;
399
400 /*
401 * Extra RTEMS stuff
402 */
403 volatile struct ReceiveDescriptor *next; /* Circularly-linked list */
404 struct mbuf *mbufp; /* First mbuf in packet */
405};
408
409typedef struct {
410 uint32_t cep; /* CAM Entry Pointer */
411 uint32_t cap0; /* CAM Address Port 0 xx-xx-xx-xx-YY-YY */
412 uint32_t cap1; /* CAM Address Port 1 xx-xx-YY-YY-xxxx */
413 uint32_t cap2; /* CAM Address Port 2 YY-YY-xx-xx-xx-xx */
414 uint32_t ce;
416
418
419/*
420 * Receive status
421 */
422#define RDA_STATUS_ERR 0x8800
423#define RDA_STATUS_RNT 0x4000
424#define RDA_STATUS_BRD 0x2000
425#define RDA_STATUS_PRO 0x1000
426#define RDA_STATUS_AMC 0x0800
427#define RDA_STATUS_LB1 0x0400
428#define RDA_STATUS_LB0 0x0200
429#define RDA_STATUS_MC 0x0100
430#define RDA_STATUS_BC 0x0080
431#define RDA_STATUS_LPKT 0x0040
432#define RDA_STATUS_CRS 0x0020
433#define RDA_STATUS_COL 0x0010
434#define RDA_STATUS_CRCR 0x0008
435#define RDA_STATUS_FAER 0x0004
436#define RDA_STATUS_LBK 0x0002
437#define RDA_STATUS_PRX 0x0001
438
439#define RDA_LINK_EOL 0x0001
440#define RDA_LINK_EOL_MASK 0xFFFE
441#define RDA_IN_USE 0x0000 /* SONIC has finished with the packet */
442 /* and the driver can process it */
443#define RDA_FREE 0xFFFF /* SONIC can use it */
444
445/*
446 * Attach routine
447 */
448
449int rtems_sonic_driver_attach (
450 struct rtems_bsdnet_ifconfig *config,
452);
453
454#ifdef CPU_U32_FIX
455void ipalign(struct mbuf *m);
456#endif
457
458#endif /* _SONIC_DP83932_ */
Definition: sonic.h:409
Definition: sonic.h:391
Definition: sonic.h:378
Definition: sonic.h:302
Definition: deflate.c:115
Definition: sonic.h:81
