RTEMS 5.2
priorityimpl.h
1
9/*
10 * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_PRIORITYIMPL_H
24#define _RTEMS_SCORE_PRIORITYIMPL_H
25
28
29#ifdef __cplusplus
30extern "C" {
31#endif /* __cplusplus */
32
45 Priority_Actions *actions
46)
47{
48 actions->actions = NULL;
49}
50
60 Priority_Actions *actions,
61 Priority_Aggregation *aggregation,
62 Priority_Node *node,
64)
65{
66#if defined(RTEMS_SMP)
67 aggregation->Action.next = NULL;
68#endif
69 aggregation->Action.node = node;
70 aggregation->Action.type = type;
71
72 actions->actions = aggregation;
73}
74
84 const Priority_Actions *actions
85)
86{
87 return actions->actions == NULL;
88}
89
99 const Priority_Aggregation *aggregation
100)
101{
102#if defined(RTEMS_SMP)
103 return aggregation != NULL;
104#else
105 (void) aggregation;
106 return false;
107#endif
108}
109
118 Priority_Actions *actions
119)
120{
121 Priority_Aggregation *aggregation;
122
123 aggregation = actions->actions;
124 actions->actions = NULL;
125
126 return aggregation;
127}
128
136 Priority_Actions *actions,
137 Priority_Aggregation *aggregation
138)
139{
140#if defined(RTEMS_SMP)
141 /*
142 * Priority aggregations are only added to action lists, so do not care about
143 * the current next pointer value.
144 */
145 aggregation->Action.next = actions->actions;
146#endif
147 actions->actions = aggregation;
148}
149
157 Priority_Node *node,
158 Priority_Control priority
159)
160{
161 node->priority = priority;
162 _RBTree_Initialize_node( &node->Node.RBTree );
163}
164
172 Priority_Node *node,
173 Priority_Control priority
174)
175{
176 node->priority = priority;
177}
178
185 Priority_Node *node
186)
187{
188 _RBTree_Set_off_tree( &node->Node.RBTree );
189}
190
200 const Priority_Node *node
201)
202{
203 return !_RBTree_Is_node_off_tree( &node->Node.RBTree );
204}
205
212 Priority_Aggregation *aggregation
213)
214{
215#if defined(RTEMS_DEBUG)
216#if defined(RTEMS_SMP)
217 aggregation->Action.next = NULL;
218#endif
219 aggregation->Action.node = NULL;
220 aggregation->Action.type = PRIORITY_ACTION_INVALID;
221#endif
222 _RBTree_Initialize_node( &aggregation->Node.Node.RBTree );
223 _RBTree_Initialize_empty( &aggregation->Contributors );
224}
225
233 Priority_Aggregation *aggregation,
234 Priority_Node *node
235)
236{
237#if defined(RTEMS_DEBUG)
238#if defined(RTEMS_SMP)
239 aggregation->Action.next = NULL;
240#endif
241 aggregation->Action.node = NULL;
242 aggregation->Action.type = PRIORITY_ACTION_INVALID;
243#endif
244 _Priority_Node_initialize( &aggregation->Node, node->priority );
245 _RBTree_Initialize_one( &aggregation->Contributors, &node->Node.RBTree );
246}
247
257 const Priority_Aggregation *aggregation
258)
259{
260 return _RBTree_Is_empty( &aggregation->Contributors );
261}
262
271 const Priority_Aggregation *aggregation
272)
273{
274 return aggregation->Node.priority;
275}
276
285 const Priority_Aggregation *aggregation
286)
287{
288#if defined(RTEMS_SMP)
289 return aggregation->scheduler;
290#else
291 return &_Scheduler_Table[ 0 ];
292#endif
293}
294
303 const Priority_Aggregation *aggregation
304)
305{
306 return (Priority_Node *) _RBTree_Minimum( &aggregation->Contributors );
307}
308
316 Priority_Aggregation *aggregation,
317 Priority_Node *node
318)
319{
320 aggregation->Action.node = node;
321}
322
330 Priority_Aggregation *aggregation,
332)
333{
334 aggregation->Action.type = type;
335}
336
346 Priority_Aggregation *aggregation,
347 Priority_Node *node,
349)
350{
351 aggregation->Action.node = node;
352 aggregation->Action.type = type;
353}
354
364 const Priority_Aggregation *aggregation
365)
366{
367#if defined(RTEMS_SMP)
368 return aggregation->Action.next;
369#else
370 (void) aggregation;
371 return NULL;
372#endif
373}
374
385 const void *left,
386 const RBTree_Node *right
387)
388{
389 const Priority_Control *the_left;
390 const Priority_Node *the_right;
391
392 the_left = (const Priority_Control*) left;
393 the_right = RTEMS_CONTAINER_OF( right, Priority_Node, Node.RBTree );
394
395 return *the_left < the_right->priority;
396}
397
412 Priority_Aggregation *aggregation,
413 Priority_Node *node,
414 Priority_Control priority
415)
416{
418 &aggregation->Contributors,
419 &node->Node.RBTree,
420 &priority,
422 );
423}
424
434 Priority_Aggregation *aggregation,
435 Priority_Node *node
436)
437{
438 _RBTree_Extract( &aggregation->Contributors, &node->Node.RBTree );
439}
440
451 Priority_Aggregation *aggregation,
452 Priority_Node *node
453)
454{
455 _Priority_Plain_extract( aggregation, node );
456 _Priority_Plain_insert( aggregation, node, node->priority );
457}
458
459typedef void ( *Priority_Add_handler )(
460 Priority_Aggregation *aggregation,
461 Priority_Actions *actions,
462 void *arg
463);
464
465typedef void ( *Priority_Change_handler )(
466 Priority_Aggregation *aggregation,
467 bool prepend_it,
468 Priority_Actions *actions,
469 void *arg
470);
471
472typedef void ( *Priority_Remove_handler )(
473 Priority_Aggregation *aggregation,
474 Priority_Actions *actions,
475 void *arg
476);
477
489 Priority_Aggregation *aggregation,
490 bool prepend_it,
491 Priority_Actions *actions,
492 void *arg
493)
494{
495 (void) aggregation;
496 (void) prepend_it;
497 (void) actions;
498 (void) arg;
499}
500
511 Priority_Aggregation *aggregation,
512 Priority_Actions *actions,
513 void *arg
514)
515{
516 (void) aggregation;
517 (void) actions;
518 (void) arg;
519}
520
535 Priority_Aggregation *aggregation,
536 Priority_Node *node,
537 Priority_Actions *actions,
538 Priority_Change_handler change,
539 void *arg
540)
541{
542 bool is_new_minimum;
543
544 _Assert( !_Priority_Is_empty( aggregation ) );
545 is_new_minimum = _Priority_Plain_insert( aggregation, node, node->priority );
546
547 if ( is_new_minimum ) {
548 aggregation->Node.priority = node->priority;
549 ( *change )( aggregation, false, actions, arg );
550 }
551}
552
566 Priority_Aggregation *aggregation,
567 Priority_Node *node,
568 Priority_Actions *actions,
569 Priority_Add_handler add,
570 Priority_Change_handler change,
571 void *arg
572)
573{
574 if ( _Priority_Is_empty( aggregation ) ) {
575 _Priority_Initialize_one( aggregation, node );
576 ( *add )( aggregation, actions, arg );
577 } else {
578 _Priority_Non_empty_insert( aggregation, node, actions, change, arg );
579 }
580}
581
600 Priority_Aggregation *aggregation,
601 Priority_Node *node,
602 Priority_Actions *actions,
603 Priority_Remove_handler remove,
604 Priority_Change_handler change,
605 void *arg
606)
607{
608 _Priority_Plain_extract( aggregation, node );
609
610 if ( _Priority_Is_empty( aggregation ) ) {
611 ( *remove )( aggregation, actions, arg );
612 } else {
613 Priority_Node *min;
614
615 min = _Priority_Get_minimum_node( aggregation );
616
617 if ( node->priority < min->priority ) {
618 aggregation->Node.priority = min->priority;
619 ( *change )( aggregation, true, actions, arg );
620 }
621 }
622}
623
638 Priority_Aggregation *aggregation,
639 Priority_Node *node,
640 Priority_Actions *actions,
641 Priority_Change_handler change,
642 void *arg
643)
644{
645 Priority_Node *min;
646
647 _Priority_Plain_extract( aggregation, node );
648 _Assert( !_Priority_Is_empty( aggregation ) );
649
650 min = _Priority_Get_minimum_node( aggregation );
651
652 if ( node->priority < min->priority ) {
653 aggregation->Node.priority = min->priority;
654 ( *change )( aggregation, true, actions, arg );
655 }
656}
657
674 Priority_Aggregation *aggregation,
675 Priority_Node *node,
676 bool prepend_it,
677 Priority_Actions *actions,
678 Priority_Change_handler change,
679 void *arg
680)
681{
682 Priority_Node *min;
683
684 _Priority_Plain_changed( aggregation, node );
685
686 min = _Priority_Get_minimum_node( aggregation );
687
688 if ( min->priority != aggregation->Node.priority ) {
689 aggregation->Node.priority = min->priority;
690 ( *change )( aggregation, prepend_it, actions, arg );
691 }
692}
693
705 Priority_Aggregation *aggregation,
706 Priority_Node *victim,
707 Priority_Node *replacement
708)
709{
710 replacement->priority = victim->priority;
712 &aggregation->Contributors,
713 &victim->Node.RBTree,
714 &replacement->Node.RBTree
715 );
716}
717
720#ifdef __cplusplus
721}
722#endif /* __cplusplus */
723
724#endif /* _RTEMS_SCORE_PRIORITYIMPL_H */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_CONTAINER_OF(_m, _type, _member_name)
Returns a pointer to the container of a specified member pointer.
Definition: basedefs.h:430
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE bool _Priority_Is_empty(const Priority_Aggregation *aggregation)
Checks if the priority aggregation is empty.
Definition: priorityimpl.h:256
RTEMS_INLINE_ROUTINE void _Priority_Set_action_type(Priority_Aggregation *aggregation, Priority_Action_type type)
Sets the action type of the priority aggregation.
Definition: priorityimpl.h:329
RTEMS_INLINE_ROUTINE void _Priority_Node_initialize(Priority_Node *node, Priority_Control priority)
Initializes the priority node to the given priority.
Definition: priorityimpl.h:156
RTEMS_INLINE_ROUTINE bool _Priority_Actions_is_empty(const Priority_Actions *actions)
Checks if the priority actions is empty.
Definition: priorityimpl.h:83
RTEMS_INLINE_ROUTINE void _Priority_Set_action(Priority_Aggregation *aggregation, Priority_Node *node, Priority_Action_type type)
Sets the action type and action node of the priority aggregation.
Definition: priorityimpl.h:345
RTEMS_INLINE_ROUTINE bool _Priority_Plain_insert(Priority_Aggregation *aggregation, Priority_Node *node, Priority_Control priority)
Inserts the node with the given priority into the priority aggregation's contributors.
Definition: priorityimpl.h:411
RTEMS_INLINE_ROUTINE Priority_Node * _Priority_Get_minimum_node(const Priority_Aggregation *aggregation)
Gets the minimum node of the priority aggregation.
Definition: priorityimpl.h:302
RTEMS_INLINE_ROUTINE void _Priority_Change_nothing(Priority_Aggregation *aggregation, bool prepend_it, Priority_Actions *actions, void *arg)
Does nothing.
Definition: priorityimpl.h:488
RTEMS_INLINE_ROUTINE bool _Priority_Node_is_active(const Priority_Node *node)
Checks if the priority node is active.
Definition: priorityimpl.h:199
RTEMS_INLINE_ROUTINE void _Priority_Plain_extract(Priority_Aggregation *aggregation, Priority_Node *node)
Extracts the priority node from the aggregation.
Definition: priorityimpl.h:433
RTEMS_INLINE_ROUTINE void _Priority_Extract(Priority_Aggregation *aggregation, Priority_Node *node, Priority_Actions *actions, Priority_Remove_handler remove, Priority_Change_handler change, void *arg)
Extracts the node from the aggregation.
Definition: priorityimpl.h:599
RTEMS_INLINE_ROUTINE void _Priority_Replace(Priority_Aggregation *aggregation, Priority_Node *victim, Priority_Node *replacement)
Replaces one node by another.
Definition: priorityimpl.h:704
RTEMS_INLINE_ROUTINE void _Priority_Remove_nothing(Priority_Aggregation *aggregation, Priority_Actions *actions, void *arg)
Does nothing.
Definition: priorityimpl.h:510
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
RTEMS_INLINE_ROUTINE void _Priority_Actions_add(Priority_Actions *actions, Priority_Aggregation *aggregation)
Adds actions to the priority actions' actions.
Definition: priorityimpl.h:135
RTEMS_INLINE_ROUTINE Priority_Aggregation * _Priority_Get_next_action(const Priority_Aggregation *aggregation)
Gets the next action of the priority aggregation.
Definition: priorityimpl.h:363
RTEMS_INLINE_ROUTINE void _Priority_Non_empty_insert(Priority_Aggregation *aggregation, Priority_Node *node, Priority_Actions *actions, Priority_Change_handler change, void *arg)
Inserts the node in a nonempty aggregation and handles change if the node is the new minimum.
Definition: priorityimpl.h:534
RTEMS_INLINE_ROUTINE bool _Priority_Less(const void *left, const RBTree_Node *right)
Compares two priorities.
Definition: priorityimpl.h:384
RTEMS_INLINE_ROUTINE void _Priority_Actions_initialize_empty(Priority_Actions *actions)
Initializes the priority actions empty.
Definition: priorityimpl.h:44
RTEMS_INLINE_ROUTINE void _Priority_Extract_non_empty(Priority_Aggregation *aggregation, Priority_Node *node, Priority_Actions *actions, Priority_Change_handler change, void *arg)
Definition: priorityimpl.h:637
RTEMS_INLINE_ROUTINE Priority_Aggregation * _Priority_Actions_move(Priority_Actions *actions)
Moves the priority actions' actions.
Definition: priorityimpl.h:117
RTEMS_INLINE_ROUTINE void _Priority_Initialize_empty(Priority_Aggregation *aggregation)
Initializes the priority aggregation empty.
Definition: priorityimpl.h:211
RTEMS_INLINE_ROUTINE void _Priority_Node_set_priority(Priority_Node *node, Priority_Control priority)
Sets the priority of the priority node to the given priority.
Definition: priorityimpl.h:171
RTEMS_INLINE_ROUTINE void _Priority_Plain_changed(Priority_Aggregation *aggregation, Priority_Node *node)
Updates the priority of the node in the aggregation.
Definition: priorityimpl.h:450
RTEMS_INLINE_ROUTINE void _Priority_Node_set_inactive(Priority_Node *node)
Sets the priority node inactive.
Definition: priorityimpl.h:184
RTEMS_INLINE_ROUTINE bool _Priority_Actions_is_valid(const Priority_Aggregation *aggregation)
Checks if the priority actions is valid.
Definition: priorityimpl.h:98
RTEMS_INLINE_ROUTINE void _Priority_Initialize_one(Priority_Aggregation *aggregation, Priority_Node *node)
Initializes the priority aggregation with the given information.
Definition: priorityimpl.h:232
RTEMS_INLINE_ROUTINE void _Priority_Actions_initialize_one(Priority_Actions *actions, Priority_Aggregation *aggregation, Priority_Node *node, Priority_Action_type type)
Initializes the priority actions with the given information.
RTEMS_INLINE_ROUTINE void _Priority_Insert(Priority_Aggregation *aggregation, Priority_Node *node, Priority_Actions *actions, Priority_Add_handler add, Priority_Change_handler change, void *arg)
Definition: priorityimpl.h:565
The priority action type.
Definition: priority.h:116
RTEMS_INLINE_ROUTINE Priority_Control _Priority_Get_priority(const Priority_Aggregation *aggregation)
Gets the priority aggregation's priority.
Definition: priorityimpl.h:270
RTEMS_INLINE_ROUTINE void _Priority_Set_action_node(Priority_Aggregation *aggregation, Priority_Node *node)
Sets the action node of the priority aggregation.
Definition: priorityimpl.h:315
RTEMS_INLINE_ROUTINE void _Priority_Changed(Priority_Aggregation *aggregation, Priority_Node *node, bool prepend_it, Priority_Actions *actions, Priority_Change_handler change, void *arg)
Definition: priorityimpl.h:673
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Priority_Get_scheduler(const Priority_Aggregation *aggregation)
Gets the priority aggregation's scheduler.
Definition: priorityimpl.h:284
RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty(const RBTree_Control *the_rbtree)
Checks if the RBTree is empty.
Definition: rbtree.h:375
void _RBTree_Extract(RBTree_Control *the_rbtree, RBTree_Node *the_node)
Extracts (removes) the node from the red-black tree.
Definition: rbtreeextract.c:35
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty(RBTree_Control *the_rbtree)
Initializes this RBTree as empty.
Definition: rbtree.h:410
RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_tree(const RBTree_Node *the_node)
Checks if this red-black tree node is off-tree.
Definition: rbtree.h:103
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_one(RBTree_Control *the_rbtree, RBTree_Node *the_node)
Initializes this red-black tree to contain exactly the specified node.
Definition: rbtree.h:424
RTEMS_INLINE_ROUTINE void _RBTree_Set_off_tree(RBTree_Node *the_node)
Sets a red-black tree node as off-tree.
Definition: rbtree.h:88
RTEMS_INLINE_ROUTINE bool _RBTree_Insert_inline(RBTree_Control *the_rbtree, RBTree_Node *the_node, const void *key, bool(*less)(const void *, const RBTree_Node *))
Inserts the node into the red-black tree.
Definition: rbtree.h:508
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_node(RBTree_Node *the_node)
Initializes a red-black tree node.
Definition: rbtree.h:129
void _RBTree_Replace_node(RBTree_Control *the_rbtree, RBTree_Node *victim, RBTree_Node *replacement)
Replaces a node in the red-black tree without a rebalance.
Definition: rbtreereplace.c:29
RBTree_Node * _RBTree_Minimum(const RBTree_Control *the_rbtree)
Returns the minimum node of the red-black tree.
Definition: rbtreenext.c:36
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
Priority Handler API.
Constants and Structures Associated with the Scheduler.
A list of priority actions.
Definition: priority.h:193
Priority_Aggregation * actions
The first action of a priority action list.
Definition: priority.h:197
The priority aggregation.
Definition: priority.h:133
The type of the action.
Definition: priority.h:182
Priority_Node Node
This priority node reflects the overall priority of the aggregation.
Definition: priority.h:147
RBTree_Control Contributors
A red-black tree to contain priority nodes contributing to the overall priority of this priority aggr...
Definition: priority.h:153
struct Priority_Aggregation::@3980 Action
A priority action block to manage priority node additions, changes and removals.
Priority_Node * node
The priority node of the action.
Definition: priority.h:177
The priority node to build up a priority aggregation.
Definition: priority.h:98
The priority value of this node.
Definition: priority.h:110
union Priority_Node::@3979 Node
Node component for a chain or red-black tree.
Red-black tree node.
Definition: rbtree.h:55
Scheduler control.
Definition: scheduler.h:269
