RTEMS 5.2
bfin.h
1
13/*
14 *
15 * COPYRIGHT (c) 1989-2006.
16 * On-Line Applications Research Corporation (OAR).
17 * modified by Alain Schaefer <alain.schaefer@easc.ch>
18 * and Antonio Giovanini <antonio@atos.com.br>
19 *
20 * The license and distribution terms for this file may be
21 * found in the file LICENSE in this distribution or at
22 * http://www.rtems.org/license/LICENSE.
23 *
24 */
25
26#ifndef _RTEMS_SCORE_BFIN_H
27#define _RTEMS_SCORE_BFIN_H
28
29#ifdef __cplusplus
30extern "C" {
31#endif
32
33
34/*
35 * This file contains the information required to build
36 * RTEMS for a particular member of the Blackfin family.
37 * It does this by setting variables to indicate which
38 * implementation dependent features are present in a particular
39 * member of the family.
40 *
41 * This is a good place to list all the known CPU models
42 * that this port supports and which RTEMS CPU model they correspond
43 * to.
44 */
45
46/*
47 * Figure out all CPU Model Feature Flags based upon compiler
48 * predefines.
49 */
50#if defined(__BFIN__)
51#define CPU_MODEL_NAME "BF533"
52#define BF_HAS_FPU 0
53#else
54
55#error "Unsupported CPU Model"
56
57#endif
58
59/*
60 * Define the name of the CPU family.
61 */
62
63#define CPU_NAME "BFIN"
64
65#ifdef __cplusplus
66}
67#endif
68
69#endif /* _RTEMS_SCORE_BFIN_H */
