RTEMS 5.2
rtl-unwind.h
1/*
2 * COPYRIGHT (c) 2016, 2018 Chris Johns <chrisj@rtems.org>
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
16#if !defined (_RTEMS_RTL_UNWIND_H_)
17#define _RTEMS_RTL_UNWIND_H_
18
19#include "rtl-elf.h"
20
21#ifdef __cplusplus
22extern "C" {
23#endif /* __cplusplus */
24
36 const char* name,
37 uint32_t flags);
38
48
58
59#ifdef __cplusplus
60}
61#endif /* __cplusplus */
62
63#endif
RTEMS Run-Time Linker ELF Headers.
bool rtems_rtl_elf_unwind_parse(const rtems_rtl_obj *obj, const char *name, uint32_t flags)
Definition: rtl-mdreloc-arm.c:602
bool rtems_rtl_elf_unwind_register(rtems_rtl_obj *obj)
Definition: rtl-mdreloc-arm.c:613
bool rtems_rtl_elf_unwind_deregister(rtems_rtl_obj *obj)
Definition: rtl-mdreloc-arm.c:619
Definition: rtl-obj.h:181
