RTEMS
5.2
include
rtems-rfs-format.h
1
11
12
* COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#if !defined (_RTEMS_RFS_FORMAT_H_)
20
#define _RTEMS_RFS_FORMAT_H_
21
22
#include <stddef.h>
23
#include <stdbool.h>
24
#include <stdint.h>
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
29
30
rtems/rfs/rtems-rfs-trace.h
31
36
typedef
struct
_rtems_rfs_format_config
37
41
size_t
block_size
42
46
size_t
group_blocks
47
51
size_t
group_inodes
52
56
int
inode_overhead
57
61
size_t
max_name_length
62
66
bool
initialise_inodes
67
71
bool
verbose
72
73
74
84
int
rtems_rfs_format
const
char
* name,
const
config
85
86
#ifdef __cplusplus
87
88
#endif
89
90
#endif
rtems_rfs_format
int rtems_rfs_format(const char *name, const rtems_rfs_format_config *config)
Definition:
rtems-rfs-format.c:540
struct _rtems_rfs_format_config rtems_rfs_format_config
rtems-rfs-trace.h
Manages the Trace and Debugging Features of the RTEMS RFS File System.
Definition:
rtems-rfs-format.h:37
_rtems_rfs_format_config::verbose
bool verbose
Definition:
rtems-rfs-format.h:71
_rtems_rfs_format_config::group_inodes
size_t group_inodes
Definition:
rtems-rfs-format.h:51
_rtems_rfs_format_config::block_size
size_t block_size
Definition:
rtems-rfs-format.h:41
_rtems_rfs_format_config::initialise_inodes
bool initialise_inodes
Definition:
rtems-rfs-format.h:66
_rtems_rfs_format_config::max_name_length
size_t max_name_length
Definition:
rtems-rfs-format.h:61
_rtems_rfs_format_config::group_blocks
size_t group_blocks
Definition:
rtems-rfs-format.h:46
_rtems_rfs_format_config::inode_overhead
int inode_overhead
Definition:
rtems-rfs-format.h:56
config_s
Definition:
deflate.c:115
