RTEMS 5.2
rtems-fdt.h
1/*
2 * COPYRIGHT (c) 2013-2017 Chris Johns <chrisj@rtems.org>
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 *
8 * Interface based on the libdft:
9 * libfdt - Flat Device Tree manipulation
10 * Copyright (C) 2006 David Gibson, IBM Corporation.
11 */
22#if !defined (_RTEMS_FDT_H_)
23#define _RTEMS_FDT_H_
24
25#include <rtems.h>
26#include <rtems/chain.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif /* __cplusplus */
31
35struct rtems_fdt_blob;
36typedef struct rtems_fdt_blob rtems_fdt_blob;
37
43typedef struct
44{
47
48/*
49 * The following are mappings to the standard FDT calls.
50 */
51
55#define RTEMS_FDT_ERR_NOTFOUND 1
59#define RTEMS_FDT_ERR_EXISTS 2
65#define RTEMS_FDT_ERR_NOSPACE 3
66
67/* Error codes: codes for bad parameters */
73#define RTEMS_FDT_ERR_BADOFFSET 4
78#define RTEMS_FDT_ERR_BADPATH 5
83#define RTEMS_FDT_ERR_BADPHANDLE 6
89#define RTEMS_FDT_ERR_BADSTATE 7
90
91/* Error codes: codes for bad device tree blobs */
92
97#define RTEMS_FDT_ERR_TRUNCATED 8
102#define RTEMS_FDT_ERR_BADMAGIC 9
108#define RTEMS_FDT_ERR_BADVERSION 10
114#define RTEMS_FDT_ERR_BADSTRUCTURE 11
121#define RTEMS_FDT_ERR_BADLAYOUT 12
125#define RTEMS_FDT_ERR_INTERNAL 13
126
127/* RTEMS error codes. */
128
132#define RTEMS_FDT_ERR_INVALID_HANDLE 100
136#define RTEMS_FDT_ERR_NO_MEMORY 101
140#define RTEMS_FDT_ERR_NOT_FOUND 102
144#define RTEMS_FDT_ERR_READ_FAIL 103
148#define RTEMS_FDT_ERR_REFERENCED 104
149
150#define RTEMS_FDT_ERR_RTEMS_MIN 100
151#define RTEMS_FDT_ERR_MAX 104
152
159
167
174
182bool rtems_fdt_valid_handle (const rtems_fdt_handle* handle);
183
198int rtems_fdt_find_path_offset (rtems_fdt_handle* handle, const char* path);
199
208int rtems_fdt_load (const char* const filename, rtems_fdt_handle* handle);
209
217int rtems_fdt_register (const void* blob, rtems_fdt_handle* handle);
218
227
237
250 int n,
251 uint64_t* address,
252 uint64_t* size);
253
268 int parentoffset,
269 const char* const name,
270 int namelen);
271
287 int parentoffset,
288 const char* const name);
289
300int rtems_fdt_path_offset (rtems_fdt_handle* handle, const char* path);
301
314const char* rtems_fdt_get_name (rtems_fdt_handle* handle,
315 int nodeoffset,
316 int* length);
317
333 int nodeoffset,
334 const char* const name,
335 int namelen,
336 int* length);
337
353const void *rtems_fdt_getprop (rtems_fdt_handle* handle,
354 int nodeoffset,
355 const char* const name,
356 int* length);
357
367uint32_t rtems_fdt_get_phandle (rtems_fdt_handle* handle, int nodeoffset);
368
379 const char* const name,
380 int namelen);
381
392const char* rtems_fdt_get_alias (rtems_fdt_handle* handle, const char* name);
393
408 int nodeoffset,
409 char* buf,
410 int buflen);
411
429 int nodeoffset,
430 int supernodedepth,
431 int* nodedepth);
432
444int rtems_fdt_node_depth (rtems_fdt_handle* handle, int nodeoffset);
445
458int rtems_fdt_parent_offset (rtems_fdt_handle* handle, int nodeoffset);
459
490 int startoffset,
491 const char* const propname,
492 const void* propval,
493 int proplen);
494
505 uint32_t phandle);
506
520 int nodeoffset,
521 const char* const compatible);
522
548 int startoffset,
549 const char* compatible);
550
559int rtems_fdt_next_node (rtems_fdt_handle* handle, int offset, int* depth);
560
567const char* rtems_fdt_strerror (int errval);
568
572int rtems_fdt_prop_value(const char* const path,
573 const char* const propname,
574 void* value,
575 size_t* size);
576
581int rtems_fdt_prop_map (const char* const path,
582 const char* const propname,
583 const char* const names[],
584 uint32_t* values,
585 size_t count);
586
587/*
588 * Get a value given a path and a property.
589 */
590int rtems_fdt_get_value (const char* const path,
591 const char* const property,
592 size_t size,
593 uint32_t* value);
594
599
604const char *rtems_fdt_entry_name(rtems_fdt_handle* handle, int id);
605
610int rtems_fdt_entry_offset(rtems_fdt_handle* handle, int id);
611
612/*
613 * Helper function to convert the void* property result to a 32bit unsigned int.
614 */
615uint32_t rtems_fdt_get_uint32 (const void* prop);
616
617#ifdef __cplusplus
618}
619#endif /* __cplusplus */
620
621#endif
Chain API.
int rtems_fdt_node_offset_by_phandle(rtems_fdt_handle *handle, uint32_t phandle)
Definition: rtems-fdt.c:879
int rtems_fdt_supernode_atdepth_offset(rtems_fdt_handle *handle, int nodeoffset, int supernodedepth, int *nodedepth)
Definition: rtems-fdt.c:833
int rtems_fdt_next_node(rtems_fdt_handle *handle, int offset, int *depth)
Definition: rtems-fdt.c:909
void rtems_fdt_init_handle(rtems_fdt_handle *handle)
Definition: rtems-fdt.c:336
uint32_t rtems_fdt_get_phandle(rtems_fdt_handle *handle, int nodeoffset)
Definition: rtems-fdt.c:796
const char * rtems_fdt_get_alias(rtems_fdt_handle *handle, const char *name)
Definition: rtems-fdt.c:814
int rtems_fdt_num_entries(rtems_fdt_handle *handle)
Definition: rtems-fdt.c:1078
const char * rtems_fdt_strerror(int errval)
Definition: rtems-fdt.c:917
int rtems_fdt_subnode_offset_namelen(rtems_fdt_handle *handle, int parentoffset, const char *const name, int namelen)
Definition: rtems-fdt.c:714
const char * rtems_fdt_get_name(rtems_fdt_handle *handle, int nodeoffset, int *length)
Definition: rtems-fdt.c:751
int rtems_fdt_path_offset(rtems_fdt_handle *handle, const char *path)
Definition: rtems-fdt.c:745
int rtems_fdt_prop_map(const char *const path, const char *const propname, const char *const names[], uint32_t *values, size_t count)
Definition: rtems-fdt.c:971
int rtems_fdt_entry_offset(rtems_fdt_handle *handle, int id)
Definition: rtems-fdt.c:1098
int rtems_fdt_node_check_compatible(rtems_fdt_handle *handle, int nodeoffset, const char *const compatible)
Definition: rtems-fdt.c:887
void rtems_fdt_dup_handle(rtems_fdt_handle *from, rtems_fdt_handle *to)
Definition: rtems-fdt.c:343
const char * rtems_fdt_get_alias_namelen(rtems_fdt_handle *handle, const char *const name, int namelen)
Definition: rtems-fdt.c:804
int rtems_fdt_find_path_offset(rtems_fdt_handle *handle, const char *path)
Definition: rtems-fdt.c:416
int rtems_fdt_subnode_offset(rtems_fdt_handle *handle, int parentoffset, const char *const name)
Definition: rtems-fdt.c:728
int rtems_fdt_parent_offset(rtems_fdt_handle *handle, int nodeoffset)
Definition: rtems-fdt.c:855
int rtems_fdt_node_depth(rtems_fdt_handle *handle, int nodeoffset)
Definition: rtems-fdt.c:847
bool rtems_fdt_valid_handle(const rtems_fdt_handle *handle)
Definition: rtems-fdt.c:387
const void * rtems_fdt_getprop_namelen(rtems_fdt_handle *handle, int nodeoffset, const char *const name, int namelen, int *length)
Definition: rtems-fdt.c:766
int rtems_fdt_prop_value(const char *const path, const char *const propname, void *value, size_t *size)
Definition: rtems-fdt.c:934
int rtems_fdt_node_offset_by_compatible(rtems_fdt_handle *handle, int startoffset, const char *compatible)
Definition: rtems-fdt.c:897
const void * rtems_fdt_getprop(rtems_fdt_handle *handle, int nodeoffset, const char *const name, int *length)
Definition: rtems-fdt.c:782
int rtems_fdt_node_offset_by_prop_value(rtems_fdt_handle *handle, int startoffset, const char *const propname, const void *propval, int proplen)
Definition: rtems-fdt.c:863
int rtems_fdt_register(const void *blob, rtems_fdt_handle *handle)
Definition: rtems-fdt.c:620
int rtems_fdt_load(const char *const filename, rtems_fdt_handle *handle)
Definition: rtems-fdt.c:453
const char * rtems_fdt_entry_name(rtems_fdt_handle *handle, int id)
Definition: rtems-fdt.c:1088
void rtems_fdt_release_handle(rtems_fdt_handle *handle)
Definition: rtems-fdt.c:357
int rtems_fdt_get_mem_rsv(rtems_fdt_handle *handle, int n, uint64_t *address, uint64_t *size)
Definition: rtems-fdt.c:703
int rtems_fdt_unload(rtems_fdt_handle *handle)
Definition: rtems-fdt.c:663
int rtems_fdt_get_path(rtems_fdt_handle *handle, int nodeoffset, char *buf, int buflen)
Definition: rtems-fdt.c:822
int rtems_fdt_num_mem_rsv(rtems_fdt_handle *handle)
Definition: rtems-fdt.c:695
const void * blob
Definition: rtems-fdt.c:47
Definition: rtems-fdt.h:44
rtems_fdt_blob * blob
Definition: rtems-fdt.h:45
unsigned size
Definition: tte.h:1
