RTEMS 5.2
amba.h
1
7/*
8 * AMBA Plag & Play Bus Driver Macros
9 *
10 * Macros used for AMBA Plug & Play bus scanning
11 *
12 * COPYRIGHT (c) 2004.
13 * Gaisler Research
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef __AMBA_H__
21#define __AMBA_H__
22
35#ifndef GRLIB_IO_AREA
36#define GRLIB_IO_AREA 0xfff00000
37#endif
38
39#define GRLIB_CONF_AREA 0xff000
40#define GRLIB_AHB_SLAVE_CONF_AREA (1 << 11)
41
42#define GRLIB_AHB_CONF_WORDS 8
43#define GRLIB_APB_CONF_WORDS 2
44#define GRLIB_AHB_MASTERS 64
45#define GRLIB_AHB_SLAVES 64
46#define GRLIB_APB_SLAVES 16
47
48#if defined(RTEMS_MULTIPROCESSING)
49 #define GRLIB_CLOCK_INDEX \
50 (rtems_configuration_get_user_multiprocessing_table() ? GRLIB_Cpu_Index : 0)
51#else
52 #define GRLIB_CLOCK_INDEX 0
53#endif
54
55#if defined(RTEMS_SMP)
56#define GRLIB_COUNTER_GPTIMER_INDEX (GRLIB_CLOCK_INDEX + 1)
57#else
58#define GRLIB_COUNTER_GPTIMER_INDEX GRLIB_CLOCK_INDEX
59#endif
60
61#define GRLIB_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000
62
63#define GRLIB_IRQMPSTATUS_CPUNR 28
64
65#include <grlib/ambapp.h>
66#include <grlib/grlib.h>
67
68#ifdef __cplusplus
69extern "C" {
70#endif
71
72/* The AMBA Plug&Play info of the bus that the cpu sits on */
73extern struct ambapp_bus ambapp_plb;
74
75extern uint32_t GRLIB_Cpu_Index;
76extern const unsigned char GRLIB_mp_irq;
77
78extern volatile struct irqmp_regs *GRLIB_IrqCtrl_Regs;
79extern struct ambapp_dev *GRLIB_IrqCtrl_Adev;
80extern int GRLIB_IrqCtrl_EIrq;
81extern volatile struct gptimer_regs *GRLIB_Timer_Regs;
82extern struct ambapp_dev *GRLIB_Timer_Adev;
83void gptimer_initialize(void);
84void irqmp_initialize(void);
85
86static inline uint32_t grlib_up_counter_frequency(void)
87{
88 /*
89 * For simplicity, assume that the interrupt controller uses the processor
90 * clock. This is at least true on the GR740.
91 */
92 return ambapp_freq_get(&ambapp_plb, GRLIB_IrqCtrl_Adev);
93}
94
95extern rtems_interrupt_lock GRLIB_IrqCtrl_Lock;
96
97
98static inline uint32_t grlib_get_cpu_count(
99 volatile struct irqmp_regs *irqmp
100)
101{
102 uint32_t mpstat = irqmp->mpstat;
103
104 return ((mpstat >> GRLIB_IRQMPSTATUS_CPUNR) & 0xf) + 1;
105}
106
107#define GRLIB_IRQCTRL_ACQUIRE( _lock_context ) \
108 rtems_interrupt_lock_acquire( &GRLIB_IrqCtrl_Lock, _lock_context )
109
110#define GRLIB_IRQCTRL_RELEASE( _lock_context ) \
111 rtems_interrupt_lock_release( &GRLIB_IrqCtrl_Lock, _lock_context )
112
113#define GRLIB_Cpu_Unmask_interrupt( _source, _cpu ) \
114 do { \
115 rtems_interrupt_lock_context _lock_context; \
116 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
117 GRLIB_IrqCtrl_Regs->mask[_cpu] |= (1U << (_source)); \
118 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
119 } while (0)
120
121#define GRLIB_Cpu_Mask_interrupt( _source, _cpu ) \
122 do { \
123 rtems_interrupt_lock_context _lock_context; \
124 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
125 GRLIB_IrqCtrl_Regs->mask[_cpu] &= ~(1U << (_source)); \
126 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
127 } while (0)
128
129#define GRLIB_Enable_interrupt_broadcast( _source ) \
130 do { \
131 rtems_interrupt_lock_context _lock_context; \
132 uint32_t _mask = 1U << ( _source ); \
133 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
134 GRLIB_IrqCtrl_Regs->bcast |= _mask; \
135 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
136 } while (0)
137
138#define GRLIB_Disable_interrupt_broadcast( _source ) \
139 do { \
140 rtems_interrupt_lock_context _lock_context; \
141 uint32_t _mask = 1U << ( _source ); \
142 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
143 GRLIB_IrqCtrl_Regs->bcast &= ~_mask; \
144 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
145 } while (0)
146
147#define BSP_Cpu_Is_interrupt_masked( _source, _cpu ) \
148 (!(GRLIB_IrqCtrl_Regs->mask[_cpu] & (1U << (_source))))
149
150#ifdef __cplusplus
151}
152#endif
153
156#endif /* __AMBA_H__ */
Common GRLIB AMBA Core Register definitions.
ISR lock control.
Definition: isrlock.h:56
Definition: ambapp.h:126
Definition: ambapp.h:43
Definition: grlib.h:101
Definition: grlib.h:55
