RTEMS 5.2
raspberrypi.h
1
9/*
10 * Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
11 * Copyright (c) 2013 Alan Cudmore.
12 * Copyright (c) 2015 Yang Qiao
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 *
17 * http://www.rtems.org/license/LICENSE
18 *
19 */
20
21#ifndef LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H
22#define LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H
23
24#include <bspopts.h>
25#include <stdint.h>
26#include <bsp/utility.h>
27
44#define BCM2835_REG(x) (*(volatile uint32_t *)(x))
45#define BCM2835_BIT(n) (1 << (n))
46
55#if (BSP_IS_RPI2 == 1)
56 #define RPI_PERIPHERAL_BASE 0x3F000000
57 #define BASE_OFFSET 0X3F000000
58#else
59 #define RPI_PERIPHERAL_BASE 0x20000000
60 #define BASE_OFFSET 0X5E000000
61#endif
62
63#define RPI_PERIPHERAL_SIZE 0x01000000
64
71#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
72
81#define BCM2835_CLOCK_FREQ 250000000
82
83#define BCM2835_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
84
85#define BCM2835_TIMER_LOD (BCM2835_TIMER_BASE + 0x00)
86#define BCM2835_TIMER_VAL (BCM2835_TIMER_BASE + 0x04)
87#define BCM2835_TIMER_CTL (BCM2835_TIMER_BASE + 0x08)
88#define BCM2835_TIMER_CLI (BCM2835_TIMER_BASE + 0x0C)
89#define BCM2835_TIMER_RIS (BCM2835_TIMER_BASE + 0x10)
90#define BCM2835_TIMER_MIS (BCM2835_TIMER_BASE + 0x14)
91#define BCM2835_TIMER_RLD (BCM2835_TIMER_BASE + 0x18)
92#define BCM2835_TIMER_DIV (BCM2835_TIMER_BASE + 0x1C)
93#define BCM2835_TIMER_CNT (BCM2835_TIMER_BASE + 0x20)
94
95#define BCM2835_TIMER_PRESCALE 0xF9
96
105#define BCM2835_PM_PASSWD_MAGIC 0x5a000000
106
107#define BCM2835_PM_BASE (RPI_PERIPHERAL_BASE + 0x100000)
108
109#define BCM2835_PM_GNRIC (BCM2835_PM_BASE + 0x00)
110#define BCM2835_PM_GNRIC_POWUP 0x00000001
111#define BCM2835_PM_GNRIC_POWOK 0x00000002
112#define BCM2835_PM_GNRIC_ISPOW 0x00000004
113#define BCM2835_PM_GNRIC_MEMREP 0x00000008
114#define BCM2835_PM_GNRIC_MRDONE 0x00000010
115#define BCM2835_PM_GNRIC_ISFUNC 0x00000020
116#define BCM2835_PM_GNRIC_RSTN 0x00000fc0
117#define BCM2835_PM_GNRIC_ENAB 0x00001000
118#define BCM2835_PM_GNRIC_CFG 0x007f0000
119
120#define BCM2835_PM_AUDIO (BCM2835_PM_BASE + 0x04)
121#define BCM2835_PM_AUDIO_APSM 0x000fffff
122#define BCM2835_PM_AUDIO_CTRLEN 0x00100000
123#define BCM2835_PM_AUDIO_RSTN 0x00200000
124
125#define BCM2835_PM_STATUS (BCM2835_PM_BASE + 0x18)
126
127#define BCM2835_PM_RSTC (BCM2835_PM_BASE + 0x1c)
128#define BCM2835_PM_RSTC_DRCFG 0x00000003
129#define BCM2835_PM_RSTC_WRCFG 0x00000030
130#define BCM2835_PM_RSTC_WRCFG_FULL 0x00000020
131#define BCM2835_PM_RSTC_SRCFG 0x00000300
132#define BCM2835_PM_RSTC_QRCFG 0x00003000
133#define BCM2835_PM_RSTC_FRCFG 0x00030000
134#define BCM2835_PM_RSTC_HRCFG 0x00300000
135
136#define BCM2835_PM_RSTS (BCM2835_PM_BASE + 0x20)
137#define BCM2835_PM_RSTS_HADDRQ 0x00000001
138#define BCM2835_PM_RSTS_HADDRF 0x00000002
139#define BCM2835_PM_RSTS_HADDRH 0x00000004
140#define BCM2835_PM_RSTS_HADWRQ 0x00000010
141#define BCM2835_PM_RSTS_HADWRF 0x00000020
142#define BCM2835_PM_RSTS_HADWRH 0x00000040
143#define BCM2835_PM_RSTS_HADSRQ 0x00000100
144#define BCM2835_PM_RSTS_HADSRF 0x00000200
145#define BCM2835_PM_RSTS_HADSRH 0x00000400
146#define BCM2835_PM_RSTS_HADPOR 0x00001000
147
148#define BCM2835_PM_WDOG (BCM2835_PM_BASE + 0x24)
149
158#define BCM2835_GPIO_REGS_BASE (RPI_PERIPHERAL_BASE + 0x200000)
159
160#define BCM2835_GPIO_GPFSEL1 (BCM2835_GPIO_REGS_BASE + 0x04)
161#define BCM2835_GPIO_GPSET0 (BCM2835_GPIO_REGS_BASE + 0x1C)
162#define BCM2835_GPIO_GPCLR0 (BCM2835_GPIO_REGS_BASE + 0x28)
163#define BCM2835_GPIO_GPLEV0 (BCM2835_GPIO_REGS_BASE + 0x34)
164#define BCM2835_GPIO_GPEDS0 (BCM2835_GPIO_REGS_BASE + 0x40)
165#define BCM2835_GPIO_GPREN0 (BCM2835_GPIO_REGS_BASE + 0x4C)
166#define BCM2835_GPIO_GPFEN0 (BCM2835_GPIO_REGS_BASE + 0x58)
167#define BCM2835_GPIO_GPHEN0 (BCM2835_GPIO_REGS_BASE + 0x64)
168#define BCM2835_GPIO_GPLEN0 (BCM2835_GPIO_REGS_BASE + 0x70)
169#define BCM2835_GPIO_GPAREN0 (BCM2835_GPIO_REGS_BASE + 0x7C)
170#define BCM2835_GPIO_GPAFEN0 (BCM2835_GPIO_REGS_BASE + 0x88)
171#define BCM2835_GPIO_GPPUD (BCM2835_GPIO_REGS_BASE + 0x94)
172#define BCM2835_GPIO_GPPUDCLK0 (BCM2835_GPIO_REGS_BASE + 0x98)
173
182#define BCM2835_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
183
184#define AUX_ENABLES (BCM2835_AUX_BASE + 0x04)
185#define AUX_MU_IO_REG (BCM2835_AUX_BASE + 0x40)
186#define AUX_MU_IER_REG (BCM2835_AUX_BASE + 0x44)
187#define AUX_MU_IIR_REG (BCM2835_AUX_BASE + 0x48)
188#define AUX_MU_LCR_REG (BCM2835_AUX_BASE + 0x4C)
189#define AUX_MU_MCR_REG (BCM2835_AUX_BASE + 0x50)
190#define AUX_MU_LSR_REG (BCM2835_AUX_BASE + 0x54)
191#define AUX_MU_MSR_REG (BCM2835_AUX_BASE + 0x58)
192#define AUX_MU_SCRATCH (BCM2835_AUX_BASE + 0x5C)
193#define AUX_MU_CNTL_REG (BCM2835_AUX_BASE + 0x60)
194#define AUX_MU_STAT_REG (BCM2835_AUX_BASE + 0x64)
195#define AUX_MU_BAUD_REG (BCM2835_AUX_BASE + 0x68)
196
207#define BCM2835_I2C_BASE (RPI_PERIPHERAL_BASE + 0x804000)
208
209#define BCM2835_I2C_C (BCM2835_I2C_BASE + 0x00)
210#define BCM2835_I2C_S (BCM2835_I2C_BASE + 0x04)
211#define BCM2835_I2C_DLEN (BCM2835_I2C_BASE + 0x08)
212#define BCM2835_I2C_A (BCM2835_I2C_BASE + 0x0C)
213#define BCM2835_I2C_FIFO (BCM2835_I2C_BASE + 0x10)
214#define BCM2835_I2C_DIV (BCM2835_I2C_BASE + 0x14)
215#define BCM2835_I2C_DEL (BCM2835_I2C_BASE + 0x18)
216#define BCM2835_I2C_CLKT (BCM2835_I2C_BASE + 0x1C)
217
226#define BCM2835_SPI_BASE (RPI_PERIPHERAL_BASE + 0x204000)
227
228#define BCM2835_SPI_CS (BCM2835_SPI_BASE + 0x00)
229#define BCM2835_SPI_FIFO (BCM2835_SPI_BASE + 0x04)
230#define BCM2835_SPI_CLK (BCM2835_SPI_BASE + 0x08)
231#define BCM2835_SPI_DLEN (BCM2835_SPI_BASE + 0x0C)
232#define BCM2835_SPI_LTOH (BCM2835_SPI_BASE + 0x10)
233#define BCM2835_SPI_DC (BCM2835_SPI_BASE + 0x14)
234
243#define BCM2835_I2C_SPI_BASE (RPI_PERIPHERAL_BASE + 0x214000)
244
245#define BCM2835_I2C_SPI_DR (BCM2835_I2C_SPI_BASE + 0x00)
246#define BCM2835_I2C_SPI_RSR (BCM2835_I2C_SPI_BASE + 0x04)
247#define BCM2835_I2C_SPI_SLV (BCM2835_I2C_SPI_BASE + 0x08)
248#define BCM2835_I2C_SPI_CR (BCM2835_I2C_SPI_BASE + 0x0C)
249#define BCM2835_I2C_SPI_FR (BCM2835_I2C_SPI_BASE + 0x10)
250#define BCM2835_I2C_SPI_IFLS (BCM2835_I2C_SPI_BASE + 0x14)
251#define BCM2835_I2C_SPI_IMSC (BCM2835_I2C_SPI_BASE + 0x18)
252#define BCM2835_I2C_SPI_RIS (BCM2835_I2C_SPI_BASE + 0x1C)
253#define BCM2835_I2C_SPI_MIS (BCM2835_I2C_SPI_BASE + 0x20)
254#define BCM2835_I2C_SPI_ICR (BCM2835_I2C_SPI_BASE + 0x24)
255#define BCM2835_I2C_SPI_DMACR (BCM2835_I2C_SPI_BASE + 0x28)
256#define BCM2835_I2C_SPI_TDR (BCM2835_I2C_SPI_BASE + 0x2C)
257#define BCM2835_I2C_SPI_GPUSTAT (BCM2835_I2C_SPI_BASE + 0x30)
258#define BCM2835_I2C_SPI_HCTRL (BCM2835_I2C_SPI_BASE + 0x34)
259
268#define BCM2835_BASE_INTC (RPI_PERIPHERAL_BASE + 0xB200)
269
270#define BCM2835_IRQ_BASIC (BCM2835_BASE_INTC + 0x00)
271#define BCM2835_IRQ_PENDING1 (BCM2835_BASE_INTC + 0x04)
272#define BCM2835_IRQ_PENDING2 (BCM2835_BASE_INTC + 0x08)
273#define BCM2835_IRQ_FIQ_CTRL (BCM2835_BASE_INTC + 0x0C)
274#define BCM2835_IRQ_ENABLE1 (BCM2835_BASE_INTC + 0x10)
275#define BCM2835_IRQ_ENABLE2 (BCM2835_BASE_INTC + 0x14)
276#define BCM2835_IRQ_ENABLE_BASIC (BCM2835_BASE_INTC + 0x18)
277#define BCM2835_IRQ_DISABLE1 (BCM2835_BASE_INTC + 0x1C)
278#define BCM2835_IRQ_DISABLE2 (BCM2835_BASE_INTC + 0x20)
279#define BCM2835_IRQ_DISABLE_BASIC (BCM2835_BASE_INTC + 0x24)
280
294#define BCM2835_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
295
296#define BCM2835_GPU_TIMER_CS (BCM2835_GPU_TIMER_BASE + 0x00)
297#define BCM2835_GPU_TIMER_CS_M0 0x00000001
298#define BCM2835_GPU_TIMER_CS_M1 0x00000002
299#define BCM2835_GPU_TIMER_CS_M2 0x00000004
300#define BCM2835_GPU_TIMER_CS_M3 0x00000008
301#define BCM2835_GPU_TIMER_CLO (BCM2835_GPU_TIMER_BASE + 0x04)
302#define BCM2835_GPU_TIMER_CHI (BCM2835_GPU_TIMER_BASE + 0x08)
303#define BCM2835_GPU_TIMER_C0 (BCM2835_GPU_TIMER_BASE + 0x0C)
304#define BCM2835_GPU_TIMER_C1 (BCM2835_GPU_TIMER_BASE + 0x10)
305#define BCM2835_GPU_TIMER_C2 (BCM2835_GPU_TIMER_BASE + 0x14)
306#define BCM2835_GPU_TIMER_C3 (BCM2835_GPU_TIMER_BASE + 0x18)
307
321#define BCM2835_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000)
322
331#define BCM2835_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
332
333#define BCM2835_MBOX_PEEK (BCM2835_MBOX_BASE+0x10)
334#define BCM2835_MBOX_READ (BCM2835_MBOX_BASE+0x00)
335#define BCM2835_MBOX_WRITE (BCM2835_MBOX_BASE+0x20)
336#define BCM2835_MBOX_STATUS (BCM2835_MBOX_BASE+0x18)
337#define BCM2835_MBOX_SENDER (BCM2835_MBOX_BASE+0x14)
338#define BCM2835_MBOX_CONFIG (BCM2835_MBOX_BASE+0x1C)
339
340#define BCM2835_MBOX_FULL 0x80000000
341#define BCM2835_MBOX_EMPTY 0x40000000
342
351/* Power Manager channel */
352#define BCM2835_MBOX_CHANNEL_PM 0
353/* Framebuffer channel */
354#define BCM2835_MBOX_CHANNEL_FB 1
355 /* Virtual UART channel */
356#define BCM2835_MBOX_CHANNEL_VUART 2
357 /* VCHIQ channel */
358#define BCM2835_MBOX_CHANNEL_VCHIQ 3
359 /* LEDs channel */
360#define BCM2835_MBOX_CHANNEL_LED 4
361 /* Button channel */
362#define BCM2835_MBOX_CHANNEL_BUTTON 5
363 /* Touch screen channel */
364#define BCM2835_MBOX_CHANNEL_TOUCHS 6
365/* Property tags (ARM <-> VC) channel */
366#define BCM2835_MBOX_CHANNEL_PROP_AVC 8
367 /* Property tags (VC <-> ARM) channel */
368#define BCM2835_MBOX_CHANNEL_PROP_VCA 9
369
378#define BCM2835_USB_BASE (RPI_PERIPHERAL_BASE + 0x980000) /* DTC_OTG USB controller */
379
388#define BCM2836_CORE_LOCAL_PERIPH_BASE 0x40000000
389#define BCM2836_CORE_LOCAL_PERIPH_SIZE 0x00040000
390
399#define BCM2836_MAILBOX_0_WRITE_SET_BASE 0x40000080
400#define BCM2836_MAILBOX_1_WRITE_SET_BASE 0x40000084
401#define BCM2836_MAILBOX_2_WRITE_SET_BASE 0x40000088
402#define BCM2836_MAILBOX_3_WRITE_SET_BASE 0x4000008C
403#define BCM2836_MAILBOX_0_READ_CLEAR_BASE 0x400000C0
404#define BCM2836_MAILBOX_1_READ_CLEAR_BASE 0x400000C4
405#define BCM2836_MAILBOX_2_READ_CLEAR_BASE 0x400000C8
406#define BCM2836_MAILBOX_3_READ_CLEAR_BASE 0x400000CC
407
416#define BCM2836_CORE_TIMER_CTRL 0x40000000
417
418#define BCM2836_CORE_TIMER_CTRL_APB_CLK 0x00000100
419#define BCM2836_CORE_TIMER_CTRL_INC_2 0x00000200
420
421#define BCM2836_CORE_TIMER_PRESCALER 0x40000008
422
423#define BCM2836_CORE_TIMER_LS32 0x4000001C
424#define BCM2836_CORE_TIMER_MS32 0x40000020
425
434#define BCM2836_LOCAL_TIMER_CTRL 0x40000034
435
436#define BCM2836_LOCAL_TIMER_CTRL_IRQ_FLAG 0x80000000
437#define BCM2836_LOCAL_TIMER_CTRL_IRQ_EN 0x20000000
438#define BCM2836_LOCAL_TIMER_CTRL_TIMER_EN 0x10000000
439#define BCM2836_LOCAL_TIMER_RELOAD 0x0FFFFFFF
440
441#define BCM2836_LOCAL_TIMER_IRQ_RELOAD 0x40000038
442
443#define BCM2836_LOCAL_TIMER_IRQ_CLEAR 0x80000000
444#define BCM2836_LOCAL_TIMER_RELOAD_NOW 0x40000000
445
446#define BCM2836_LOCAL_TIMER_IRQ_ROUTING 0x40000024
447#define BCM2836_LOCAL_TIMER_ROU_CORE0_IRQ 0x00
448#define BCM2836_LOCAL_TIMER_ROU_CORE1_IRQ 0x01
449#define BCM2836_LOCAL_TIMER_ROU_CORE2_IRQ 0x02
450#define BCM2836_LOCAL_TIMER_ROU_CORE3_IRQ 0x03
451#define BCM2836_LOCAL_TIMER_ROU_CORE0_FIQ 0x04
452#define BCM2836_LOCAL_TIMER_ROU_CORE1_FIQ 0x05
453#define BCM2836_LOCAL_TIMER_ROU_CORE2_FIQ 0x06
454#define BCM2836_LOCAL_TIMER_ROU_CORE3_FIQ 0x07
455
464#define BCM2836_GPU_IRQ_ROUTING 0x4000000C
465
466#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE0 0x00000000
467#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE1 0x00000001
468#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE2 0x00000002
469#define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE4 0x00000003
470
471#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE0 0x00000000
472#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE1 0x00000004
473#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE2 0x00000008
474#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE4 0x0000000C
475
476#define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE4 0x0000000C
477
478
487/* Timers interrupt control registers */
488#define BCM2836_CORE0_TIMER_IRQ_CTRL_BASE 0x40000040
489#define BCM2836_CORE1_TIMER_IRQ_CTRL_BASE 0x40000044
490#define BCM2836_CORE2_TIMER_IRQ_CTRL_BASE 0x40000048
491#define BCM2836_CORE3_TIMER_IRQ_CTRL_BASE 0x4000004C
492
493#define BCM2836_CORE_TIMER_IRQ_CTRL(cpuidx) \
494 (BCM2836_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
495
496/*
497 * Where to route timer interrupt to, IRQ/FIQ
498 * Setting both the IRQ and FIQ bit gives an FIQ
499 */
500#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_IRQ 0x01
501#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_IRQ 0x02
502#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_IRQ 0x04
503#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_IRQ 0x08
504#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_FIQ 0x10
505#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_FIQ 0x20
506#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_FIQ 0x40
507#define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_FIQ 0x80
508
509/* CPU mailbox registers */
510#define BCM2836_MAILBOX_IRQ_CTRL_BASE 0x40000050
511#define BCM2836_MAILBOX_IRQ_CTRL(cpuidx) \
512 (BCM2836_MAILBOX_IRQ_CTRL_BASE + 0x4 * (cpuidx))
513/*
514 * Where to route mailbox interrupt to, IRQ/FIQ
515 * Setting both the IRQ and FIQ bit gives an FIQ
516 */
517#define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_IRQ 0x01
518#define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_IRQ 0x02
519#define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_IRQ 0x04
520#define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_IRQ 0x08
521#define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_FIQ 0x10
522#define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_FIQ 0x20
523#define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_FIQ 0x40
524#define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_FIQ 0x80
525
526#define BCM2836_IRQ_SOURCE_REG_BASE 0x40000060
527#define BCM2836_IRQ_SOURCE_REG(cpuidx) \
528 (BCM2836_IRQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
529
530#define BCM2836_FIQ_SOURCE_REG_BASE 0x40000070
531#define BCM2836_FIQ_SOURCE_REG(cpuidx) \
532 (BCM2836_FIQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
533
534#define BCM2836_IRQ_SOURCE_TIMER0 0x00000001
535#define BCM2836_IRQ_SOURCE_TIMER1 0x00000002
536#define BCM2836_IRQ_SOURCE_TIMER2 0x00000004
537#define BCM2836_IRQ_SOURCE_TIMER3 0x00000008
538#define BCM2836_IRQ_SOURCE_MBOX0 0x00000010
539#define BCM2836_IRQ_SOURCE_MBOX1 0x00000020
540#define BCM2836_IRQ_SOURCE_MBOX2 0x00000040
541#define BCM2836_IRQ_SOURCE_MBOX3 0x00000080
542#define BCM2836_IRQ_SOURCE_GPU 0x00000100
543#define BCM2836_IRQ_SOURCE_PMU 0x00000200
544#define BCM2836_IRQ_SOURCE_LOCAL_TIMER 0x00000800
545
548#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
Utility macros.
