RTEMS 5.2
priorityimpl.h
1
10/*
11 * COPYRIGHT (c) 1989-2011.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_POSIX_PRIORITYIMPL_H
20#define _RTEMS_POSIX_PRIORITYIMPL_H
21
23#include <rtems/score/assert.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
42#define POSIX_SCHEDULER_MINIMUM_PRIORITY (1)
43
53 const Scheduler_Control *scheduler
54)
55{
56 _Assert( (int) scheduler->maximum_priority > 1 );
57 return (int) scheduler->maximum_priority - 1;
58}
59
84 const Scheduler_Control *scheduler,
85 int priority,
86 bool *valid
87);
88
99 const Scheduler_Control *scheduler,
100 Priority_Control priority
101);
102
105#ifdef __cplusplus
106}
107#endif
108
109#endif
Information for the Assert Handler.
RTEMS_INLINE_ROUTINE int _POSIX_Priority_Get_maximum(const Scheduler_Control *scheduler)
Gets the maximum POSIX API priority for this scheduler instance.
Definition: priorityimpl.h:52
Priority_Control _POSIX_Priority_To_core(const Scheduler_Control *scheduler, int priority, bool *valid)
Converts the POSIX API priority to the corresponding SuperCore priority and validates it.
Definition: psxpriorityisvalid.c:24
int _POSIX_Priority_From_core(const Scheduler_Control *scheduler, Priority_Control priority)
Converts the SuperCore priority to the corresponding POSIX API priority.
Definition: psxpriorityisvalid.c:42
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
Constants and Structures Associated with the Scheduler.
Scheduler control.
Definition: scheduler.h:269
Priority_Control maximum_priority
The maximum priority value of this scheduler.
Definition: scheduler.h:286
