RTEMS 5.2
no_cpu.h
1/* no_cpu.h
2 *
3 * This file sets up basic CPU dependency settings based on
4 * compiler settings. For example, it can determine if
5 * floating point is available. This particular implementation
6 * is specified to the NO CPU port.
7 *
8 *
9 * COPYRIGHT (c) 1989-1999.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 *
16 */
17
18#ifndef _RTEMS_SCORE_NO_CPU_H
19#define _RTEMS_SCORE_NO_CPU_H
20
21#ifdef __cplusplus
22extern "C" {
23#endif
24
25/*
26 * This file contains the information required to build
27 * RTEMS for a particular member of the NO CPU family.
28 * It does this by setting variables to indicate which
29 * implementation dependent features are present in a particular
30 * member of the family.
31 *
32 * This is a good place to list all the known CPU models
33 * that this port supports and which RTEMS CPU model they correspond
34 * to.
35 */
36
37#if defined(rtems_multilib)
38/*
39 * Figure out all CPU Model Feature Flags based upon compiler
40 * predefines.
41 */
42
43#define CPU_MODEL_NAME "rtems_multilib"
44#define NOCPU_HAS_FPU 1
45
46#elif defined(no_cpu)
47
48#define CPU_MODEL_NAME "no_cpu_model"
49#define NOCPU_HAS_FPU 1
50
51#else
52
53#error "Unsupported CPU Model"
54
55#endif
56
57/*
58 * Define the name of the CPU family.
59 */
60
61#define CPU_NAME "NO CPU"
62
63#ifdef __cplusplus
64}
65#endif
66
67#endif /* _RTEMS_SCORE_NO_CPU_H */
