RTEMS
5.2
bsps
powerpc
gen5200
nvram
m93cxx.h
1
2
| Project: RTEMS generic MPC5200 BSP |
3
4
| Partially based on the code references which are named below. |
5
| Adaptions, modifications, enhancements and any recent parts of |
6
| the code are: |
7
| Copyright (c) 2005 |
8
| Embedded Brains GmbH |
9
| Obere Lagerstr. 30 |
10
| D-82178 Puchheim |
11
| Germany |
12
| rtems@embedded-brains.de |
13
14
| The license and distribution terms for this file may be |
15
| found in the file LICENSE in this distribution or at |
16
17
| http://www.rtems.org/license/LICENSE. |
18
19
20
| this file contains definitions for the M93Cxx EEPROM devices |
21
22
23
24
/* Module: m93cxx.h */
25
/* Date: 07/17/2003 */
26
/* Purpose: RTEMS M93C64-based header file */
27
28
29
30
/* Description: M93C46 is a serial microwire EEPROM which contains */
31
/* 1Kbit (128 bytes/64 words) of non-volatile memory. */
32
/* The device can be configured for byte- or word- */
33
/* access. The driver provides a file-like interface */
34
/* to this memory. */
35
36
/* MPC5x00 PIN settings: */
37
38
/* PSC3_6 (output) -> MC93C46 serial data in (D) */
39
/* PSC3_7 (input) -> MC93C46 serial data out (Q) */
40
/* PSC3_8 (output) -> MC93C46 chip select input (S) */
41
/* PSC3_9 (output) -> MC93C46 serial clock (C) */
42
43
44
45
/* Code */
46
/* References: none */
47
/* Module: */
48
/* Project: */
49
/* Version */
50
/* Date: */
51
/* Author: */
52
/* Copyright: */
53
54
55
56
/* Partially based on the code references which are named above. */
57
/* Adaptions, modifications, enhancements and any recent parts of */
58
/* the code are under the right of */
59
60
/* IPR Engineering, Dachauer Straße 38, D-80335 München */
61
/* Copyright(C) 2003 */
62
63
64
65
/* IPR Engineering makes no representation or warranties with */
66
/* respect to the performance of this computer program, and */
67
/* specifically disclaims any responsibility for any damages, */
68
/* special or consequential, connected with the use of this program. */
69
70
71
72
/* Version history: 1.0 */
73
74
75
76
#ifndef __M93CXX_H__
77
#define __M93CXX_H__
78
79
#ifdef __cplusplus
80
extern
"C"
81
#endif
82
83
static
void
m93cxx_enable_write(
void
84
static
void
m93cxx_disable_write(
void
85
static
void
m93cxx_write_byte(uint32_t, uint8_t);
86
static
uint8_t m93cxx_read_byte(uint32_t);
87
void
wait_usec(
unsigned
long
88
89
#define M93CXX_MODE_WORD
90
/*#define M93C46_MODE_BYTE*/
91
#define M93C46
92
#define M93C46_NVRAM_SIZE 128
93
94
#define GPIO_PSC3_6 (1 << 12)
95
#define GPIO_PSC3_7 (1 << 13)
96
#define GPIO_PSC3_8 (1 << 26)
97
#define GPIO_PSC3_9 (1 << 26)
98
99
#define START_BIT 0x1
100
#define EWDS_OPCODE 0x0
101
#define WRAL_OPCODE 0x1
102
#define ERAL_OPCODE 0x2
103
#define EWEN_OPCODE 0x3
104
#define WRITE_OPCODE 0x4
105
#define READ_OPCODE 0x8
106
#define ERASE_OPCODE 0xC
107
108
#define WAIT(i) wait_usec(i)
109
110
#define ENABLE_CHIP_SELECT mpc5200.gpiosido |= GPIO_PSC3_8
111
#define DISABLE_CHIP_SELECT mpc5200.gpiosido &= ~GPIO_PSC3_8
112
#define SET_DATA_BIT_HIGH mpc5200.gpiosdo |= GPIO_PSC3_6
113
#define SET_DATA_BIT_LOW mpc5200.gpiosdo &= ~GPIO_PSC3_6
114
115
#ifdef M93CXX_MODE_BYTE
116
#define GET_DATA_BYTE_SHIFT(val) ((val) |= ((mpc5200.gpiosdi & GPIO_PSC3_7) >> 13)); \
117
((val) <<= 1)
118
#define SET_DATA_BYTE_SHIFT(val) (((val) & 0x80) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
119
((val) <<= 1)
120
#else
121
#define GET_DATA_WORD_SHIFT(val) ((val) |= ((mpc5200.gpiosdi & GPIO_PSC3_7) >> 13)); \
122
((val) <<= 1)
123
#define SET_DATA_WORD_SHIFT(val) (((val) & 0x8000) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
124
((val) <<= 1)
125
#endif
126
127
#define MASK_HEAD_SHIFT(head) ((((head) & 0x80000000) >> 31) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
128
((head) <<= 1)
129
#define DO_CLOCK_CYCLE mpc5200.gpiowdo |= GPIO_PSC3_9; \
130
WAIT(1000); \
131
mpc5200.gpiowdo &= ~GPIO_PSC3_9
132
#define CHECK_WRITE_BUSY while(!(mpc5200.gpiosdi & GPIO_PSC3_7))
133
134
135
136
#ifdef M93C46
137
#define M93C46_EWDS ((START_BIT << 31) | (EWDS_OPCODE << 27))
138
#define M93C46_WRAL ((START_BIT << 31) | (WRAL_OPCODE << 27))
139
#define M93C46_ERAL ((START_BIT << 31) | (ERAL_OPCODE << 27))
140
#define M93C46_EWEN ((START_BIT << 31) | (EWEN_OPCODE << 27))
141
#define M93C46_READ(addr) ((START_BIT << 31) | (READ_OPCODE << 27) | ((addr) << 22))
142
#define M93C46_WRITE(addr) ((START_BIT << 31) | (WRITE_OPCODE << 27) | ((addr) << 22))
143
#define M93C46_ERASE(addr) ((START_BIT << 31) | (ERASE_OPCODE << 27) | ((addr) << 22))
144
#define M93C46_CLOCK_CYCLES 10
145
#endif
146
#else
147
#ifdef M93C46
148
149
150
151
152
#define M93C46_READ(addr) ((START_BIT << 31) | (READ_OPCODE << 27) | ((addr) << 23))
153
#define M93C46_WRITE(addr) ((START_BIT << 31) | (WRITE_OPCODE << 27) | ((addr) << 23))
154
#define M93C46_ERASE(addr) ((START_BIT << 31) | (ERASE_OPCODE << 27) | ((addr) << 23))
155
#define M93C46_CLOCK_CYCLES 9
156
#endif
157
#endif
158
159
#ifdef __cplusplus
160
161
#endif
162
163
#endif
/* __M93CXX_H__ */
