RTEMS
5.2
include
ioimpl.h
1
7
8
* COPYRIGHT (c) 1989-2008.
9
* On-Line Applications Research Corporation (OAR).
10
11
* The license and distribution terms for this file may be
12
* found in the file LICENSE in this distribution or at
13
* http://www.rtems.org/license/LICENSE.
14
15
16
#ifndef _RTEMS_IOIMPL_H
17
#define _RTEMS_IOIMPL_H
18
19
rtems/io.h
20
rtems/score/isrlock.h
21
22
#ifdef __cplusplus
23
extern
"C"
24
#endif
/* __cplusplus */
25
26
extern
const
size_t
_IO_Number_of_drivers;
27
28
extern
rtems_driver_address_table
_IO_Driver_address_table[];
29
30
extern
bool
_IO_All_drivers_initialized;
31
37
void
_IO_Initialize_all_drivers
void
38
39
ISR_LOCK_DECLARE
extern
, _IO_Driver_registration_lock )
40
41
RTEMS_INLINE_ROUTINE
void
_IO_Driver_registration_acquire(
42
ISR_lock_Context
*lock_context
43
44
45
_ISR_lock_ISR_disable_and_acquire
46
&_IO_Driver_registration_lock,
47
lock_context
48
49
50
51
void
_IO_Driver_registration_release(
52
ISR_lock_Context
*lock_context
53
54
55
_ISR_lock_Release_and_ISR_enable
56
57
lock_context
58
59
60
61
#ifdef __cplusplus
62
63
#endif
/* __cplusplus */
64
65
#endif
/* _RTEMS_IOIMPL_H */
io.h
Classic Input/Output Manager API.
#define RTEMS_INLINE_ROUTINE
Definition:
basedefs.h:66
ISR_LOCK_DECLARE
#define ISR_LOCK_DECLARE(_qualifier, _designator)
Declares an ISR lock variable.
Definition:
isrlock.h:104
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition:
isrlock.h:263
#define _ISR_lock_ISR_disable_and_acquire(_lock, _context)
Acquires an ISR lock.
Definition:
isrlock.h:238
void _IO_Initialize_all_drivers(void)
Initialization of all device drivers.
Definition:
io.c:26
isrlock.h
ISR Locks.
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition:
isrlock.h:65
Definition:
io.h:48
