RTEMS
5.2
Toggle main menu visibility
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
include
inttypes.h
1
12
13
* COPYRIGHT (c) 2017 On-Line Applications Research Corporation.
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
20
#ifndef _RTEMS_INTTYPES_H
21
#define _RTEMS_INTTYPES_H
22
23
inttypes.h
24
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
29
40
#if __RTEMS_SIZEOF_MODE_T__ == 8
41
#define PRIomode_t PRIo64
42
#elif __RTEMS_SIZEOF_MODE_T__ == 4
43
#define PRIomode_t PRIo32
44
#else
45
#error "PRIomode_t: unsupported size of mode_t"
46
#endif
47
49
#if __RTEMS_SIZEOF_OFF_T__ == 8
50
#define PRIooff_t PRIo64
51
#elif __RTEMS_SIZEOF_OFF_T__ == 4
52
#define PRIooff_t PRIo32
53
#else
54
#error "PRIooff_t: unsupported size of off_t"
55
#endif
56
58
59
#define PRIdoff_t PRId64
60
61
#define PRIdoff_t PRId32
62
#else
63
#error "PRIdoff_t: unsupported size of off_t"
64
#endif
65
67
#if __RTEMS_SIZEOF_TIME_T__ == 8
68
#define PRIdtime_t PRId64
69
#elif __RTEMS_SIZEOF_TIME_T__ == 4
70
#define PRIdtime_t PRId32
71
#else
72
#error "PRIdtime_t: unsupported size of time_t"
73
#endif
74
76
#if __RTEMS_SIZEOF_BLKSIZE_T__ == 8
77
#define PRIxblksize_t PRIx64
78
#elif __RTEMS_SIZEOF_BLKSIZE_T__ == 4
79
#define PRIxblksize_t PRIx32
80
#else
81
/* Warn and fall back to "long" */
82
#warning "unsupported size of blksize_t"
83
#define PRIxblksize_t "lx"
84
#endif
85
87
#if __RTEMS_SIZEOF_BLKCNT_T__ == 8
88
#define PRIxblkcnt_t PRIx64
89
#elif __RTEMS_SIZEOF_BLKCNT_T__ == 4
90
#define PRIxblkcnt_t PRIx32
91
#else
92
93
#warning "unsupported size of blkcnt_t"
94
#define PRIxblkcnt_t "lx"
95
#endif
96
97
98
* Various inttypes.h-stype macros to assist printing
99
* certain system types on different targets.
100
101
102
#define PRIxrtems_id PRIx32
103
104
/* c.f. cpukit/score/include/rtems/score/priority.h */
105
#define PRIdPriority_Control PRIu64
106
#define PRIxPriority_Control PRIx64
107
/* rtems_task_priority is a typedef to Priority_Control */
108
#define PRIdrtems_task_priority PRIu32
109
#define PRIxrtems_task_priority PRIx32
110
111
/* c.f. cpukit/score/include/rtems/score/watchdog.h */
112
#define PRIdWatchdog_Interval PRIu32
113
/* rtems_interval is a typedef to Watchdog_Interval */
114
#define PRIdrtems_interval PRIdWatchdog_Interval
115
116
/* c.f. cpukit/score/include/rtems/score/thread.h */
117
#define PRIdThread_Entry_numeric_type PRIuPTR
118
/* rtems_task_argument is a typedef to Thread_Entry_numeric_type */
119
#define PRIdrtems_task_argument PRIdThread_Entry_numeric_type
120
121
/* rtems_event_set is a typedef to uint32_t */
122
#define PRIxrtems_event_set PRIx32
123
124
/* newlib defines pthread_t as a typedef to __uint32_t which matches
125
* RTEMS expectations for an Object ID.
126
127
#define PRIxpthread_t PRIx32
128
129
/* rtems_signal_set is a typedef to uint32_t */
130
#define PRIxrtems_signal_set PRIx32
131
132
/* newlib's ino_t is a typedef to __uint64_t */
133
#define PRIuino_t PRIu64
134
135
136
#define PRIxino_t PRIx64
137
138
/* ioctl_command_t */
139
#define PRIdioctl_command_t "ld"
140
141
/* rtems_blkdev_bnum */
142
#define PRIdrtems_blkdev_bnum PRId32
143
144
145
146
147
/* rtems_vector_number */
148
#define PRIdrtems_vector_number PRId32
149
152
#ifdef __cplusplus
153
154
#endif
155
156
#endif
inttypes.h
Provide printf() PRIxxx Constante Beyond Standards.
