RTEMS 5.2
grpwm.h
1/*
2 * GRPWM PWM Driver interface.
3 *
4 * COPYRIGHT (c) 2009.
5 * Cobham Gaisler AB.
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __GRPWM_H__
13#define __GRPWM_H__
14
15#ifdef __cplusplus
16extern "C" {
17#endif
18
19extern void grpwm_register_drv (void);
20
21#define GRPWM_IOCTL_GET_CAP 1 /* Get Capabilities */
22#define GRPWM_IOCTL_SET_CONFIG 2 /* Configure one PWM Channel */
23#define GRPWM_IOCTL_SET_SCALER 3 /* Set one scaler */
24#define GRPWM_IOCTL_UPDATE 4 /* Set current period and compare value */
25#define GRPWM_IOCTL_IRQ 5 /* Set up IRQ handling */
26
27/*** Argument for GRPWM_IOCTL_GET_CAP ***/
28
29/* The Capability of the PWM core */
31 int channel_cnt; /* Number of channels */
32 unsigned int pwm; /* Capability1 register */
33 unsigned int wave; /* Capability2 register, Wave form capabilities of last PWM channel, otherwise 0 */
34};
35
36/*** Argument for GRPWM_IOCTL_GET_CONFIG and GRPWM_IOCTL_SET_CONFIG ***/
37
38/* Config One PWM */
40 unsigned int channel; /* Select channel to configure */
41
42 /* Specific for one PWM channel */
43 unsigned int options; /* PWM options */
44 unsigned char dbscaler; /* value greater than 15 disable Dead band */
45 unsigned char scaler_index; /* Select scaler used by PWM channel */
46
47 /* IRQ Setup */
48 unsigned char irqscaler; /* IRQ scaler */
49 void *isr_arg; /* Argument of IRQ handler */
50 void (*isr)(int channel, void *arg); /* Interrupt service routine for this PWM Channel */
51
52 /* Waveform set up */
53 int wave_activate; /* Enables Waveform functionality */
54 unsigned int wave_synccfg; /* Bits [29,30,31] is written into Wave-Config register */
55 unsigned int wave_sync; /* Sets sync compare register */
56 unsigned int *wave_data; /* If not NULL, the Wave RAM is filled with data */
57 unsigned int wave_data_length; /* Length of Wave RAM Data, Also used for wstopaddr */
58};
59
60#define GRPWM_CONFIG_OPTION_FLIP 0x04000000 /* Set this to Flip PWM output pair */
61#define GRPWM_CONFIG_OPTION_DEAD_BAND 0x00200000 /* Dead Band enable */
62#define GRPWM_CONFIG_OPTION_SYMMETRIC 0x00000040 /* If not defined, asymmetric */
63#define GRPWM_CONFIG_OPTION_ASYMMERTIC 0
64#define GRPWM_CONFIG_OPTION_DUAL 0x00000020 /* Dual Compare Enable */
65#define GRPWM_CONFIG_OPTION_PAIR 0x00000004 /* PWM Pair Enable */
66#define GRPWM_CONFIG_OPTION_SINGLE 0x00000000 /* PWM Pair Disable */
67#define GRPWM_CONFIG_OPTION_POLARITY_HIGH 0x00000002 /* PWM Polarity HIGH */
68#define GRPWM_CONFIG_OPTION_POLARITY_LOW 0x00000000 /* PWM Polarity LOW */
69
70#define GRPWM_CONFIG_OPTION_MASK ( \
71 GRPWM_CONFIG_OPTION_DEAD_BAND | GRPWM_CONFIG_OPTION_SYMMETRIC | \
72 GRPWM_CONFIG_OPTION_DUAL | GRPWM_CONFIG_OPTION_PAIR | \
73 GRPWM_CONFIG_OPTION_POLARITY_HIGH \
74 )
75
76/*** Argument for GPPWM_IOCTL_SET_SCALER ***/
77
79 unsigned int index_mask;/* Scaler update index mask, bit 0 = Scaler 0, bit 1 = Scaler 1 */
80 unsigned int values[8]; /* Scaler update values, values[N] is stored into scaler N, if mask & 1<<N is set */
81};
82
83/*** Argument for GRPWM_IOCTL_UPDATE ***/
84
85#define GRPWM_UPDATE_OPTION_ENABLE 0x01 /* Enable the PWM core */
86#define GRPWM_UPDATE_OPTION_DISABLE 0x02 /* Disable the PWM core */
87#define GRPWM_UPDATE_OPTION_PERIOD 0x04 /* Update period register */
88#define GRPWM_UPDATE_OPTION_COMP 0x08 /* Update Compare register */
89#define GRPWM_UPDATE_OPTION_DBCOMP 0x10 /* Update Dead band register */
90#define GRPWM_UPDATE_OPTION_FIX 0x20 /* Update fix output pins (bypass PWM) */
91
92/* FIX PIN bit-mask */
93#define GRPWM_UPDATE_FIX_ENABLE 1 /* Enable force ouput */
94#define GRPWM_UPDATE_FIX_DISABLE 0 /* Disable force ouput */
95#define GRPWM_UPDATE_FIX_0_LOW 0 /* PIN 0 OUPUT: LOW */
96#define GRPWM_UPDATE_FIX_0_HIGH 2 /* PIN 0 OUPUT: HIGH */
97#define GRPWM_UPDATE_FIX_1_LOW 0 /* PIN 1 OUPUT: LOW */
98#define GRPWM_UPDATE_FIX_1_HIGH 4 /* PIN 1 OUPUT: HIGH */
99
101 unsigned int options; /* Select what is updated */
102 unsigned int period; /* Period register content */
103 unsigned int compare; /* Compare register content */
104 unsigned int dbcomp; /* Dead band register content */
105 unsigned char fix; /* Bit-mask that select output on one or two PWM
106 * output pins. Depends on PAIR config value.
107 */
108};
110 unsigned char chanmask; /* Bit Mask select channels */
111 struct grpwm_ioctl_update_chan channels[8]; /* */
112};
113
114/*** Argument for GPPWM_IOCTL_IRQ ***/
115
116#define GRPWM_IRQ_DISABLE 0 /* Disable IRQ */
117#define GRPWM_IRQ_PERIOD 1 /* Enable IRQ on period match */
118#define GRPWM_IRQ_COMPARE 3 /* Enable IRQ on Compare Match */
119#define GRPWM_IRQ_CLEAR 0x10 /* Clear any pending IRQ on GRPWM and IRQ controller */
120
121#define GRPWM_IRQ_CHAN 0x100 /* Channel N is selected, by adding 0x100*N */
122
123#ifdef __cplusplus
124}
125#endif
126
127#endif
Definition: grpwm.h:30
Definition: grpwm.h:39
Definition: grpwm.h:78
Definition: grpwm.h:100
Definition: grpwm.h:109
