RTEMS 5.2
bsp.h
1
9/* bsp.h
10 *
11 * This include file contains all GEN405 board IO definitions.
12 *
13 * derived from helas403/include/bsp.h:
14 * Id: bsp.h,v 1.4 2001/06/18 17:01:48 joel Exp
15 * Author: Thomas Doerfler <td@imd.m.isar.de>
16 * IMD Ingenieurbuero fuer Microcomputertechnik
17 *
18 * COPYRIGHT (c) 1998 by IMD
19 *
20 * Changes from IMD are covered by the original distributions terms.
21 * This file has been derived from the papyrus BSP.
22 *
23 * Author: Andrew Bray <andy@i-cubed.co.uk>
24 *
25 * COPYRIGHT (c) 1995 by i-cubed ltd.
26 *
27 * To anyone who acknowledges that this file is provided "AS IS"
28 * without any express or implied warranty:
29 * permission to use, copy, modify, and distribute this file
30 * for any purpose is hereby granted without fee, provided that
31 * the above copyright notice and this notice appears in all
32 * copies, and that the name of i-cubed limited not be used in
33 * advertising or publicity pertaining to distribution of the
34 * software without specific, written prior permission.
35 * i-cubed limited makes no representations about the suitability
36 * of this software for any purpose.
37 *
38 * Derived from c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
39 *
40 * COPYRIGHT (c) 1989-1999.
41 * On-Line Applications Research Corporation (OAR).
42 *
43 * The license and distribution terms for this file may be
44 * found in the file LICENSE in this distribution or at
45 * http://www.rtems.org/license/LICENSE.
46 *
47 */
48
49#ifndef LIBBSP_POWERPC_VIRTEX_BSP_H
50#define LIBBSP_POWERPC_VIRTEX_BSP_H
51
62#include <bspopts.h>
63
64#ifdef ASM
65/* Definition of where to store registers in alignment handler */
66#define ALIGN_REGS 0x0140
67
68#else
69#include <rtems.h>
70#include <bsp/irq.h>
71#include <bsp/vectors.h>
73
74#ifdef __cplusplus
75extern "C" {
76#endif
77
78#define BSP_FEATURE_IRQ_EXTENSION
79
80/* Network Defines */
81#if 1 /* EB/doe changes */
82#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"
83#else
84#include "xiltemac.h"
85#define RTEMS_BSP_NETWORK_DRIVER_NAME XILTEMAC_DRIVER_PREFIX
86#endif
87struct rtems_bsdnet_ifconfig;
88extern int xilTemac_driver_attach(struct rtems_bsdnet_ifconfig*, int );
89#define RTEMS_BSP_NETWORK_DRIVER_ATTACH xilTemac_driver_attach
90
91#ifdef __cplusplus
92}
93#endif
94
95#endif /* ASM */
96
99#endif
PowerPC Exceptions API.
DEFAULT_INITIAL_EXTENSION Support.
