RTEMS
5.2
bsps
powerpc
virtex4
include
bsp.h
1
9
10
* This include file contains all Virtex4 board IO definitions.
11
12
13
14
* derived from helas403/include/bsp.h:
15
* Id: bsp.h,v 1.4 2001/06/18 17:01:48 joel Exp
16
* Author: Thomas Doerfler <td@imd.m.isar.de>
17
* IMD Ingenieurbuero fuer Microcomputertechnik
18
19
* COPYRIGHT (c) 1998 by IMD
20
21
* Changes from IMD are covered by the original distributions terms.
22
* This file has been derived from the papyrus BSP.
23
24
* Author: Andrew Bray <andy@i-cubed.co.uk>
25
26
* COPYRIGHT (c) 1995 by i-cubed ltd.
27
28
* To anyone who acknowledges that this file is provided "AS IS"
29
* without any express or implied warranty:
30
* permission to use, copy, modify, and distribute this file
31
* for any purpose is hereby granted without fee, provided that
32
* the above copyright notice and this notice appears in all
33
* copies, and that the name of i-cubed limited not be used in
34
* advertising or publicity pertaining to distribution of the
35
* software without specific, written prior permission.
36
* i-cubed limited makes no representations about the suitability
37
* of this software for any purpose.
38
39
* Derived from c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
40
41
* COPYRIGHT (c) 1989-1999.
42
* On-Line Applications Research Corporation (OAR).
43
44
* The license and distribution terms for this file may be
45
* found in the file LICENSE in this distribution or at
46
* http://www.rtems.org/license/LICENSE.
47
48
49
50
#ifndef LIBBSP_POWERPC_VIRTEX4_BSP_H
51
#define LIBBSP_POWERPC_VIRTEX4_BSP_H
52
63
#include <bspopts.h>
64
65
66
* confdefs.h overrides for this BSP:
67
* - Interrupt stack space is not minimum if defined.
68
69
#define BSP_INTERRUPT_STACK_SIZE (16 * 1024)
70
71
#ifdef ASM
72
/* Definition of where to store registers in alignment handler */
73
#define ALIGN_REGS 0x0140
74
75
#else
76
rtems.h
77
78
bsp/default-initial-extension.h
79
80
#ifdef __cplusplus
81
extern
"C"
82
#endif
83
84
void
BSP_ask_for_reset(
void
85
86
87
* Prototypes for BSP methods shared across file boundaries
88
89
void
zero_bss(
void
90
91
#ifdef __cplusplus
92
93
#endif
94
95
#endif
/* ASM */
96
99
#endif
DEFAULT_INITIAL_EXTENSION Support.
rtems.h
