RTEMS
5.2
bsps
powerpc
qemuppc
include
bsp.h
1
9
10
* This include file contains some definitions specific to the
11
* qemu powerpc Prep simulator
12
13
14
15
* COPYRIGHT (c) 1989-2014.
16
* On-Line Applications Research Corporation (OAR).
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef LIBBSP_POWERPC_QEMUPPC_BSP_H
24
#define LIBBSP_POWERPC_QEMUPPC_BSP_H
25
36
#ifndef ASM
37
38
#include <bspopts.h>
39
bsp/default-initial-extension.h
40
41
rtems.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
47
48
* Convert decrementer value to tenths of microseconds (used by shared timer
49
* driver).
50
51
#define BSP_Convert_decrementer( _value ) \
52
((int) (((_value) * 10) / bsp_clicks_per_usec))
53
54
55
* Prototypes for methods that are referenced from .S
56
57
void
cmain(
void
58
59
#ifdef __cplusplus
60
61
#endif
62
63
#endif
/* !ASM */
64
67
#endif
DEFAULT_INITIAL_EXTENSION Support.
rtems.h
