RTEMS
5.2
bsps
arm
beagle
include
bsp
spi.h
1
11
12
* Copyright (c) 2018 Pierre-Louis Garnier <garnie_a@epita.fr>
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef LIBBSP_ARM_BEAGLE_SPI_H
20
#define LIBBSP_ARM_BEAGLE_SPI_H
21
22
#include <bsp.h>
23
rtems/libi2c.h
24
rtems/irq.h
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
/* __cplusplus */
29
30
#define BBB_SPI_TIMEOUT 1000
31
32
#define BBB_SPI_0_BUS_PATH "/dev/spi-0"
33
34
#define BBB_SPI_0_IRQ AM335X_INT_SPI0INT
35
36
typedef
enum
37
SPI0,
38
SPI1,
39
SPI_COUNT
40
} bbb_spi_id_t;
41
42
43
44
typedef
struct
BEAGLE_SPI_BufferDescriptor_
45
unsigned
short
status;
46
unsigned
short
length;
47
volatile
void
*buffer;
48
BEAGLE_SPI_BufferDescriptor_t
49
50
typedef
struct
beagle_spi_softc
51
int
initialized;
52
rtems_id
task_id;
53
uintptr_t regs_base;
54
rtems_vector_number
irq;
55
beagle_spi_softc_t
56
57
typedef
struct
58
rtems_libi2c_bus_t
bus_desc;
59
beagle_spi_softc_t
softc;
60
beagle_spi_desc_t
61
62
63
* Initialize the driver
64
65
* Returns: o = ok or error code
66
67
rtems_status_code
beagle_spi_init
68
69
rtems_libi2c_bus_t
*bh
/* bus specifier structure */
70
71
72
73
* Receive some bytes from SPI device
74
75
* Returns: number of bytes received or (negative) error code
76
77
int
beagle_spi_read_bytes
78
79
rtems_libi2c_bus_t
*bh,
80
unsigned
char
*buf,
/* buffer to store bytes */
81
int
len
/* number of bytes to receive */
82
83
84
85
* Send some bytes to SPI device
86
87
* Returns: number of bytes sent or (negative) error code
88
89
int
beagle_spi_write_bytes
90
91
rtems_libi2c_bus_t
*bh,
92
unsigned
char
*buf,
/* buffer to send */
93
int
len
/* number of bytes to send */
94
95
96
97
* Set SPI to desired baudrate/clock mode/character mode
98
99
* Returns: rtems_status_code
100
101
rtems_status_code
beagle_spi_set_tfr_mode
102
103
rtems_libi2c_bus_t
*bh,
104
const
rtems_libi2c_tfr_mode_t
*tfr_mode
/* transfer mode info */
105
106
107
108
* Perform selected ioctl function for SPI
109
110
111
112
int
beagle_spi_ioctl
113
114
rtems_libi2c_bus_t
*bh,
115
int
cmd,
/* ioctl command code */
116
void
*arg
/* additional argument array */
117
118
119
120
* Register SPI bus and devices
121
122
* Returns: Bus number or error code
123
124
rtems_status_code
bsp_register_spi
125
126
const
char
*bus_path,
127
uintptr_t register_base,
128
rtems_vector_number
irq
129
130
131
static
inline
rtems_status_code
bbb_register_spi_0(
void
132
133
return
bsp_register_spi(
134
BBB_SPI_0_BUS_PATH,
135
AM335X_SPI0_BASE,
136
BBB_SPI_0_IRQ
137
138
139
140
#ifdef __cplusplus
141
142
#endif
/* __cplusplus */
143
144
#endif
/* LIBBSP_ARM_BEAGLE_SPI_H */
irq.h
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
rtems_status_code
rtems_status_code
Classic API Status.
Definition:
status.h:43
rtems_id
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition:
types.h:83
libi2c.h
Legacy I2C Library.
Definition:
spi.h:44
beagle_spi_desc_t
Definition:
spi.h:57
beagle_spi_softc
Definition:
spi.h:50
rtems_libi2c_bus_t_
Definition:
libi2c.h:163
Definition:
libi2c.h:462
