RTEMS 5.2
bestcomm.h
1/*
2 * Copyright (c) 2010-2013 embedded brains GmbH. All rights reserved.
3 *
4 * embedded brains GmbH
5 * Dornierstr. 4
6 * 82178 Puchheim
7 * Germany
8 * <rtems@embedded-brains.de>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef GEN5200_BESTCOMM_H
16#define GEN5200_BESTCOMM_H
17
18#include "bestcomm_ops.h"
19
20#include <assert.h>
21
22#include <rtems.h>
23
24#include <bsp/mpc5200.h>
26#include <bsp/bestcomm/bestcomm_glue.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif /* __cplusplus */
31
42typedef struct {
43 uint32_t *tdt_begin;
44 uint32_t *tdt_last;
45 volatile uint32_t (*var_table)[32];
46 uint32_t fdt_and_pragmas;
47 uint32_t reserved_0;
48 uint32_t reserved_1;
49 uint32_t *context_begin;
50 uint32_t reserved_2;
52
53#define BESTCOMM_TASK_ENTRY_TABLE ((volatile bestcomm_task_entry *) 0xf0008000)
54
55#define BESTCOMM_IRQ_EVENT RTEMS_EVENT_13
56
57typedef struct {
58 int task_index;
59 rtems_id event_task_id;
61
62void bestcomm_irq_create(bestcomm_irq *self, int task_index);
63
64void bestcomm_irq_destroy(const bestcomm_irq *self);
65
66static inline void bestcomm_irq_enable(const bestcomm_irq *self)
67{
68 bestcomm_glue_irq_enable(self->task_index);
69}
70
71static inline void bestcomm_irq_disable(const bestcomm_irq *self)
72{
73 bestcomm_glue_irq_disable(self->task_index);
74}
75
76static inline void bestcomm_irq_clear(const bestcomm_irq *self)
77{
78 SDMA_CLEAR_IEVENT(&mpc5200.sdma.IntPend, self->task_index);
79}
80
81static inline int bestcomm_irq_get_task_index(const bestcomm_irq *self)
82{
83 return self->task_index;
84}
85
86static inline rtems_id bestcomm_irq_get_event_task_id(const bestcomm_irq *self)
87{
88 return self->event_task_id;
89}
90
91static inline void bestcomm_irq_set_event_task_id(bestcomm_irq *self, rtems_id id)
92{
93 self->event_task_id = id;
94}
95
96static inline void bestcomm_irq_wakeup_event_task(const bestcomm_irq *self)
97{
98 rtems_status_code sc = rtems_event_send(self->event_task_id, BESTCOMM_IRQ_EVENT);
99 assert(sc == RTEMS_SUCCESSFUL);
100 (void) sc;
101}
102
103static inline void bestcomm_irq_wait(const bestcomm_irq *self)
104{
105 rtems_event_set events;
107 BESTCOMM_IRQ_EVENT,
110 &events
111 );
112 assert(sc == RTEMS_SUCCESSFUL);
113 assert(events == BESTCOMM_IRQ_EVENT);
114 (void) sc;
115}
116
117static inline bool bestcomm_irq_peek(const bestcomm_irq *self)
118{
119 rtems_event_set events;
120 rtems_status_code sc = rtems_event_receive(0, 0, 0, &events);
121 assert(sc == RTEMS_SUCCESSFUL);
122 (void) sc;
123
124 return (events & BESTCOMM_IRQ_EVENT) != 0;
125}
126
127typedef struct {
128 volatile uint16_t *task_control_register;
129
130 volatile uint32_t (*variable_table)[32];
131
132 TaskId task_index;
133
134 bestcomm_irq irq;
135
136 uint32_t *tdt_begin;
137
138 size_t tdt_opcode_count;
140
141void bestcomm_task_create(bestcomm_task *self, TaskId task_index);
142
143void bestcomm_task_create_and_load(
144 bestcomm_task *self,
145 TaskId task_index,
146 const uint32_t *tdt_source_begin,
147 size_t tdt_size
148);
149
150void bestcomm_task_destroy(bestcomm_task *self);
151
152void bestcomm_task_load(bestcomm_task *self, const uint32_t *tdt_source_begin, size_t tdt_size);
153
154static inline void bestcomm_task_set_priority(bestcomm_task *self, int priority)
155{
156 /* Allow higher priority initiator to block current initiator */
157 mpc5200.sdma.ipr[self->task_index] = SDMA_IPR_PRIOR(priority);
158}
159
160static inline void bestcomm_task_irq_enable(const bestcomm_task *self)
161{
162 bestcomm_irq_enable(&self->irq);
163}
164
165static inline void bestcomm_task_irq_disable(const bestcomm_task *self)
166{
167 bestcomm_irq_disable(&self->irq);
168}
169
170static inline void bestcomm_task_irq_clear(const bestcomm_task *self)
171{
172 bestcomm_irq_clear(&self->irq);
173}
174
175static inline rtems_id bestcomm_task_get_event_task_id(const bestcomm_task *self)
176{
177 return bestcomm_irq_get_event_task_id(&self->irq);
178}
179
180static inline void bestcomm_task_set_event_task_id(bestcomm_task *self, rtems_id id)
181{
182 bestcomm_irq_set_event_task_id(&self->irq, id);
183}
184
185static inline void bestcomm_task_associate_with_current_task(bestcomm_task *self)
186{
187 bestcomm_task_set_event_task_id(self, rtems_task_self());
188}
189
190static inline void bestcomm_task_start(const bestcomm_task *self)
191{
192 *self->task_control_register = SDMA_TCR_EN | SDMA_TCR_HIGH_EN;
193}
194
195static inline void bestcomm_task_start_with_autostart(const bestcomm_task *self)
196{
197 *self->task_control_register = (uint16_t)
198 (SDMA_TCR_EN | SDMA_TCR_HIGH_EN | SDMA_TCR_AUTO_START | SDMA_TCR_AS(self->task_index));
199}
200
201static inline void bestcomm_task_stop(const bestcomm_task *self)
202{
203 *self->task_control_register = 0;
204}
205
206static inline void bestcomm_task_wakeup_event_task(const bestcomm_task *self)
207{
208 bestcomm_irq_wakeup_event_task(&self->irq);
209}
210
211static inline void bestcomm_task_wait(const bestcomm_task *self)
212{
213 bestcomm_irq_wait(&self->irq);
214}
215
216static inline bool bestcomm_task_peek(const bestcomm_task *self)
217{
218 return bestcomm_irq_peek(&self->irq);
219}
220
221static inline bool bestcomm_task_is_running(const bestcomm_task *self)
222{
223 return (*self->task_control_register & SDMA_TCR_EN) != 0;
224}
225
226static inline uint32_t bestcomm_get_task_variable(const bestcomm_task *self, size_t index)
227{
228 assert(index < VAR_COUNT);
229 return (*self->variable_table)[index];
230}
231
232static inline volatile uint32_t *bestcomm_task_get_address_of_variable(const bestcomm_task *self, size_t index)
233{
234 assert(index < VAR_COUNT);
235 return &(*self->variable_table)[index];
236}
237
238static inline void bestcomm_task_set_variable(const bestcomm_task *self, size_t index, uint32_t value)
239{
240 assert(index < VAR_COUNT);
241 (*self->variable_table)[index] = value;
242}
243
244static inline uint32_t bestcomm_task_get_increment_and_condition(const bestcomm_task *self, size_t index)
245{
246 assert(index < INC_COUNT);
247 return (*self->variable_table)[INC(index)];
248}
249
250static inline void bestcomm_task_set_increment_and_condition_32(
251 const bestcomm_task *self,
252 size_t index,
253 uint32_t inc_and_cond
254)
255{
256 assert(index < INC_COUNT);
257 (*self->variable_table)[INC(index)] = inc_and_cond;
258}
259
260static inline void bestcomm_task_set_increment_and_condition(
261 const bestcomm_task *self,
262 size_t index,
263 int16_t inc,
264 int cond
265)
266{
267 bestcomm_task_set_increment_and_condition_32(self, index, INC_INIT(cond, inc));
268}
269
270static inline void bestcomm_task_set_increment(const bestcomm_task *self, size_t index, int16_t inc)
271{
272 bestcomm_task_set_increment_and_condition_32(self, index, INC_INIT(0, inc));
273}
274
275void bestcomm_task_clear_variables(const bestcomm_task *self);
276
277static inline uint32_t bestcomm_task_get_opcode(const bestcomm_task *self, size_t index)
278{
279 assert(index < self->tdt_opcode_count);
280 return self->tdt_begin[index];
281}
282
283static inline void bestcomm_task_set_opcode(bestcomm_task *self, size_t index, uint32_t opcode)
284{
285 assert(index < self->tdt_opcode_count);
286 self->tdt_begin[index] = opcode;
287}
288
289static inline void bestcomm_task_set_initiator(const bestcomm_task *self, int initiator)
290{
293 *self->task_control_register = BSP_BFLD16SET(*self->task_control_register, initiator, 3, 7);
295}
296
297static inline volatile bestcomm_task_entry *bestcomm_task_get_task_entry(const bestcomm_task *self)
298{
299 return &BESTCOMM_TASK_ENTRY_TABLE[self->task_index];
300}
301
302static inline void bestcomm_task_set_pragma(const bestcomm_task *self, int bit_pos, bool enable)
303{
304 volatile bestcomm_task_entry *entry = bestcomm_task_get_task_entry(self);
305 uint32_t mask = BSP_BIT32(bit_pos);
306 uint32_t bit = enable ? mask : 0;
307 entry->fdt_and_pragmas = (entry->fdt_and_pragmas & ~mask) | bit;
308}
309
310static inline void bestcomm_task_enable_precise_increment(const bestcomm_task *self, bool enable)
311{
312 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_PRECISE_INC, enable);
313}
314
315static inline void bestcomm_task_enable_error_reset(const bestcomm_task *self, bool enable)
316{
317 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_RST_ERROR_NO, !enable);
318}
319
320static inline void bestcomm_task_enable_pack_data(const bestcomm_task *self, bool enable)
321{
322 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_PACK, enable);
323}
324
325static inline void bestcomm_task_enable_integer_mode(const bestcomm_task *self, bool enable)
326{
327 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_INTEGER, enable);
328}
329
330static inline void bestcomm_task_enable_speculative_read(const bestcomm_task *self, bool enable)
331{
332 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_SPECREAD, enable);
333}
334
335static inline void bestcomm_task_enable_combined_write(const bestcomm_task *self, bool enable)
336{
337 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_CW, enable);
338}
339
340static inline void bestcomm_task_enable_read_buffer(const bestcomm_task *self, bool enable)
341{
342 bestcomm_task_set_pragma(self, SDMA_PRAGMA_BIT_RL, enable);
343}
344
345static inline volatile uint16_t *bestcomm_task_get_task_control_register(const bestcomm_task *self)
346{
347 return self->task_control_register;
348}
349
350static inline int bestcomm_task_get_task_index(const bestcomm_task *self)
351{
352 return self->task_index;
353}
354
355static inline void bestcomm_task_free_tdt(bestcomm_task *self)
356{
357 bestcomm_free(self->tdt_begin);
358 self->tdt_begin = NULL;
359}
360
361static inline void bestcomm_task_clear_pragmas(const bestcomm_task *self)
362{
363 volatile bestcomm_task_entry *entry = bestcomm_task_get_task_entry(self);
364 entry->fdt_and_pragmas &= ~0xffU;
365}
366
369#ifdef __cplusplus
370}
371#endif /* __cplusplus */
372
373#endif /* GEN5200_BESTCOMM_H */
Information for the Assert Handler.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
uint32_t rtems_event_set
Integer type to hold an event set of up to 32 events represented as a bit field.
Definition: event.h:40
rtems_status_code rtems_event_send(rtems_id id, rtems_event_set event_in)
Sends an Event Set to the Target Task.
Definition: eventsend.c:25
rtems_status_code rtems_event_receive(rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out)
Receives pending events.
Definition: eventreceive.c:27
ISR_Level rtems_interrupt_level
Interrupt level type.
Definition: intr.h:42
#define rtems_interrupt_enable(_isr_cookie)
Enable RTEMS Interrupt.
Definition: intr.h:110
#define rtems_interrupt_disable(_isr_cookie)
Disable RTEMS Interrupt.
Definition: intr.h:99
#define RTEMS_WAIT
Definition: options.h:53
#define RTEMS_EVENT_ALL
Definition: options.h:65
rtems_status_code
Classic API Status.
Definition: status.h:43
@ RTEMS_SUCCESSFUL
Definition: status.h:47
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
rtems_id rtems_task_self(void)
RTEMS Get Self Task Id.
Definition: taskself.c:23
#define RTEMS_NO_TIMEOUT
Constant for indefinite wait.
Definition: rtems.h:174
Definition: bestcomm.h:57
Definition: bestcomm.h:42
Definition: bestcomm.h:127
Definition: mmu-config.c:40
