RTEMS 5.2
bdpart.h
1
9/*
10 * Copyright (c) 2009-2012 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef RTEMS_BDPART_H
24#define RTEMS_BDPART_H
25
26#include <uuid/uuid.h>
27
28#include <rtems.h>
29#include <rtems/blkdev.h>
30
31#ifdef __cplusplus
32extern "C" {
33#endif /* __cplusplus */
34
90#define RTEMS_BDPART_MBR_EMPTY 0x0U
91
92#define RTEMS_BDPART_MBR_FAT_12 0x1U
93
94#define RTEMS_BDPART_MBR_FAT_16 0x4U
95
96#define RTEMS_BDPART_MBR_FAT_16_LBA 0xeU
97
98#define RTEMS_BDPART_MBR_FAT_32 0xbU
99
100#define RTEMS_BDPART_MBR_FAT_32_LBA 0xcU
101
102#define RTEMS_BDPART_MBR_EXTENDED 0x5U
103
104#define RTEMS_BDPART_MBR_DATA 0xdaU
105
106#define RTEMS_BDPART_MBR_GPT 0xeeU
107
108#define RTEMS_BDPART_MBR_FLAG_ACTIVE 0x80U
109
115#define RTEMS_BDPART_PARTITION_NUMBER_HINT 16
116
125
130
134 uuid_t type;
135
139 uuid_t id;
140
144 uint64_t flags;
146
150typedef enum {
155
161
165typedef union {
170
174 struct {
176
180 uint32_t disk_id;
181
190 } mbr;
191
195 struct {
197
201 uuid_t disk_id;
202 } gpt;
204
216 const char *disk_name,
218 rtems_bdpart_partition *partitions,
219 size_t *count
220);
221
226void rtems_bdpart_sort( rtems_bdpart_partition *partitions, size_t count);
227
242 const char *disk_name,
244 const rtems_bdpart_partition *partitions,
245 size_t count
246);
247
259 const char *disk_name,
261 rtems_bdpart_partition *partitions,
262 const unsigned *distribution,
263 size_t count
264);
265
278 const char *disk_name,
279 const rtems_bdpart_partition *partitions,
280 size_t count
281);
282
290
300 const char *disk_name,
301 const rtems_bdpart_partition *partitions,
302 size_t count
303);
304
320 const char *disk_name,
321 const rtems_bdpart_partition *partitions,
322 size_t count,
323 const char *mount_base
324);
325
330 const char *disk_name,
331 const rtems_bdpart_partition *partitions,
332 size_t count,
333 const char *mount_base
334);
335
340void rtems_bdpart_dump( const rtems_bdpart_partition *partitions, size_t count);
341
346void rtems_bdpart_to_partition_type( uint8_t mbr_type, uuid_t type);
347
356 const uuid_t type,
357 uint8_t *mbr_type
358);
359
362#define RTEMS_BDPART_MBR_CYLINDER_SIZE 63
363
364#define RTEMS_BDPART_NUMBER_SIZE 4
365
366#define RTEMS_BDPART_BLOCK_SIZE 512
367
368#define RTEMS_BDPART_MBR_TABLE_ENTRY_SIZE 16
369
370#define RTEMS_BDPART_MBR_OFFSET_TABLE_0 446
371
372#define RTEMS_BDPART_MBR_OFFSET_TABLE_1 \
373 (RTEMS_BDPART_MBR_OFFSET_TABLE_0 + RTEMS_BDPART_MBR_TABLE_ENTRY_SIZE)
374
375#define RTEMS_BDPART_MBR_OFFSET_DISK_ID 440
376
377#define RTEMS_BDPART_MBR_OFFSET_SIGNATURE_0 510
378
379#define RTEMS_BDPART_MBR_OFFSET_SIGNATURE_1 511
380
381#define RTEMS_BDPART_MBR_SIGNATURE_0 0x55U
382
383#define RTEMS_BDPART_MBR_SIGNATURE_1 0xaaU
384
385#define RTEMS_BDPART_MBR_OFFSET_BEGIN 8
386
387#define RTEMS_BDPART_MBR_OFFSET_SIZE 12
388
389#define RTEMS_BDPART_MBR_OFFSET_TYPE 4
390
391#define RTEMS_BDPART_MBR_OFFSET_FLAGS 0
392
393static inline uint8_t rtems_bdpart_mbr_partition_type(
394 const uuid_t type
395)
396{
397 return type [0];
398}
399
400rtems_status_code rtems_bdpart_get_disk_data(
401 const char *disk_name,
402 int *fd_ptr,
403 rtems_disk_device **dd_ptr,
404 rtems_blkdev_bnum *disk_end
405);
406
407#ifdef __cplusplus
408}
409#endif /* __cplusplus */
410
411#endif /* RTEMS_BDPART_H */
Block Device Management.
rtems_status_code
Classic API Status.
Definition: status.h:43
struct rtems_bdpart_partition rtems_bdpart_partition
bool rtems_bdpart_to_mbr_partition_type(const uuid_t type, uint8_t *mbr_type)
Converts the partition type in type to the MBR partition type.
Definition: bdpart-read.c:52
void rtems_bdpart_to_partition_type(uint8_t mbr_type, uuid_t type)
Returns the partition type for the MBR partition type value mbr_type in type.
Definition: bdpart-read.c:46
rtems_status_code rtems_bdpart_read(const char *disk_name, rtems_bdpart_format *format, rtems_bdpart_partition *partitions, size_t *count)
Reads the partition information from the physical disk device with name disk_name.
Definition: bdpart-read.c:224
rtems_status_code rtems_bdpart_create(const char *disk_name, const rtems_bdpart_format *format, rtems_bdpart_partition *partitions, const unsigned *distribution, size_t count)
Creates a partition table in partitions with count partitions for the physical disk device with name ...
Definition: bdpart-create.c:29
rtems_status_code rtems_bdpart_register(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count)
Registers the partitions as logical disks for the physical disk device with name disk_name.
Definition: bdpart-register.c:64
rtems_bdpart_format_type
Definition: bdpart.h:150
rtems_status_code rtems_bdpart_unmount(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count, const char *mount_base)
Unmounts all file systems mounted with rtems_bdpart_mount().
rtems_status_code rtems_bdpart_unregister(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count)
Deletes the logical disks associated with the partitions of the disk device with name disk_name.
rtems_status_code rtems_bdpart_register_from_disk(const char *disk_name)
Definition: bdpart-register.c:127
rtems_status_code rtems_bdpart_write(const char *disk_name, const rtems_bdpart_format *format, const rtems_bdpart_partition *partitions, size_t count)
Writes the partition table to the physical disk device with name disk_name.
Definition: bdpart-write.c:86
rtems_status_code rtems_bdpart_mount(const char *disk_name, const rtems_bdpart_partition *partitions, size_t count, const char *mount_base)
Mounts all supported file systems inside the logical disks derived from the partitions of the physica...
void rtems_bdpart_dump(const rtems_bdpart_partition *partitions, size_t count)
Prints the partition table partitions with count partitions to standard output.
Definition: bdpart-dump.c:40
void rtems_bdpart_sort(rtems_bdpart_partition *partitions, size_t count)
Sorts the partition table partitions with count partitions to have ascending begin blocks.
Definition: bdpart-sort.c:45
@ RTEMS_BDPART_FORMAT_MBR
Definition: bdpart.h:154
@ RTEMS_BDPART_FORMAT_GPT
Definition: bdpart.h:159
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:45
Definition: mknod-pack_dev.c:254
Definition: bdpart.h:120
uuid_t type
Definition: bdpart.h:134
uint64_t flags
Definition: bdpart.h:144
uuid_t id
Definition: bdpart.h:139
rtems_blkdev_bnum end
Definition: bdpart.h:129
rtems_blkdev_bnum begin
Definition: bdpart.h:124
Description of a disk device (logical and physical disks).
Definition: diskdevs.h:157
Definition: bdpart.h:165
uint32_t disk_id
Definition: bdpart.h:180
uuid_t disk_id
Definition: bdpart.h:201
bool dos_compatibility
Definition: bdpart.h:189
rtems_bdpart_format_type type
Definition: bdpart.h:169
