RTEMS 5.2
tm27.h
1/* @file
2 *
3 * @ingroup RTEMSBSPsARMLPC32XX
4 *
5 * @brief Implementations of interrupt mechanisms for Time Test 27
6 */
7
8/*
9 * Copyright (c) 2010 embedded brains GmbH. All rights reserved.
10 *
11 * embedded brains GmbH
12 * Obere Lagerstr. 30
13 * 82178 Puchheim
14 * Germany
15 * <info@embedded-brains.de>
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef _RTEMS_TMTEST27
23#error "This is an RTEMS internal file you must not include directly."
24#endif
25
26#ifndef __tm27_h
27#define __tm27_h
28
29#include <assert.h>
30
31#include <rtems.h>
32
33#include <bsp/lpc32xx.h>
34#include <bsp/irq.h>
35#include <bsp/irq-generic.h>
36
37#define MUST_WAIT_FOR_INTERRUPT 1
38
39static void Install_tm27_vector(void (*handler)(rtems_vector_number))
40{
42
43 LPC32XX_SW_INT = 0;
44
46 LPC32XX_IRQ_SW,
47 "SW",
50 NULL
51 );
52 assert(sc == RTEMS_SUCCESSFUL);
53}
54
55static void Cause_tm27_intr(void)
56{
57 LPC32XX_SW_INT = 0x1;
58}
59
60static void Clear_tm27_intr(void)
61{
62 LPC32XX_SW_INT = 0;
63 lpc32xx_irq_set_priority(LPC32XX_IRQ_SW, LPC32XX_IRQ_PRIORITY_LOWEST);
64}
65
66static void Lower_tm27_intr(void)
67{
68 bsp_interrupt_vector_enable(LPC32XX_IRQ_SW);
69 lpc32xx_irq_set_priority(LPC32XX_IRQ_SW, LPC32XX_IRQ_PRIORITY_HIGHEST);
70}
71
72#endif /* __tm27_h */
Information for the Assert Handler.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
@ RTEMS_SUCCESSFUL
Definition: status.h:47
void bsp_interrupt_vector_enable(rtems_vector_number vector)
Enables the interrupt vector with number vector.
Definition: irq.c:98
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
#define RTEMS_INTERRUPT_UNIQUE
Makes the interrupt handler unique. Prevents other handler from using the same interrupt vector.
Definition: irq-extension.h:44
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
This header file provides interfaces of the generic interrupt controller support.
Register base addresses.
