RTEMS 5.2
cpuimpl.h
1
7/*
8 * Copyright (c) 2013, 2016 embedded brains GmbH
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef _RTEMS_SCORE_CPUIMPL_H
16#define _RTEMS_SCORE_CPUIMPL_H
17
18#include <rtems/score/cpu.h>
19
30#define CPU_PER_CPU_CONTROL_SIZE 0
31
32#ifdef ARM_MULTILIB_ARCH_V4
33
34#if defined(ARM_MULTILIB_VFP_D32)
35#define CPU_INTERRUPT_FRAME_SIZE 240
36#elif defined(ARM_MULTILIB_VFP)
37#define CPU_INTERRUPT_FRAME_SIZE 112
38#else
39#define CPU_INTERRUPT_FRAME_SIZE 40
40#endif
41
42#endif /* ARM_MULTILIB_ARCH_V4 */
43
44#ifndef ASM
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
50#ifdef ARM_MULTILIB_ARCH_V4
51
52typedef struct {
53#ifdef ARM_MULTILIB_VFP
54 uint32_t fpscr;
55#ifdef ARM_MULTILIB_VFP_D32
56 double d16;
57 double d17;
58 double d18;
59 double d19;
60 double d20;
61 double d21;
62 double d22;
63 double d23;
64 double d24;
65 double d25;
66 double d26;
67 double d27;
68 double d28;
69 double d29;
70 double d30;
71 double d31;
72#endif /* ARM_MULTILIB_VFP_D32 */
73 double d0;
74 double d1;
75 double d2;
76 double d3;
77 double d4;
78 double d5;
79 double d6;
80 double d7;
81#endif /* ARM_MULTILIB_VFP */
82 uint32_t r9;
83 uint32_t lr;
84 uint32_t r0;
85 uint32_t r1;
86 uint32_t r2;
87 uint32_t r3;
88 uint32_t return_pc;
89 uint32_t return_cpsr;
90 uint32_t r7;
91 uint32_t r12;
93
94#ifdef RTEMS_SMP
95
96static inline struct Per_CPU_Control *_ARM_Get_current_per_CPU_control( void )
97{
98 struct Per_CPU_Control *cpu_self;
99
100 /* Use PL1 only Thread ID Register (TPIDRPRW) */
101 __asm__ volatile (
102 "mrc p15, 0, %0, c13, c0, 4"
103 : "=r" ( cpu_self )
104 );
105
106 return cpu_self;
107}
108
109#define _CPU_Get_current_per_CPU_control() _ARM_Get_current_per_CPU_control()
110
111#endif /* RTEMS_SMP */
112
113#endif /* ARM_MULTILIB_ARCH_V4 */
114
115void _CPU_Context_volatile_clobber( uintptr_t pattern );
116
117void _CPU_Context_validate( uintptr_t pattern );
118
120{
121 __asm__ volatile ( "udf" );
122}
123
125{
126 __asm__ volatile ( "nop" );
127}
128
129#ifdef __cplusplus
130}
131#endif
132
133#endif /* ASM */
134
137#endif /* _RTEMS_SCORE_CPUIMPL_H */
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal(void)
Emits an illegal instruction.
Definition: cpuimpl.h:122
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation(void)
Emits a no operation instruction (nop).
Definition: cpuimpl.h:132
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Interrupt stack frame (ISF).
Definition: cpu.h:191
Per CPU Core Structure.
Definition: percpu.h:347
