RTEMS 5.2
aio.h
1
10/*
11 * COPYRIGHT (c) 1989-2011.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _AIO_H
20#define _AIO_H
21
22#include <sys/cdefs.h>
23#include <unistd.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
39#if defined(_POSIX_ASYNCHRONOUS_IO)
40
41/*
42 * 6.7.1 Data Definitions for Asynchronous Input and Output,
43 * P1003.1b-1993, p. 151
44 */
45
46#include <sys/types.h>
47#include <signal.h>
48#include <time.h>
49#include <fcntl.h>
50
51/*
52 * 6.7.1.2 Manifest Constants, P1003.1b-1993, p. 153
53 */
54
55#define AIO_CANCELED 0 /* all requested operations have been canceled */
56#define AIO_NOTCANCELED 1 /* some of the operations could not be canceled */
57 /* since they are in progress */
58#define AIO_ALLDONE 2 /* none of the requested operations could be */
59 /* canceled since they are already complete */
60
61/* lio_listio() options */
62
63/*
64 * LIO modes
65 */
66#define LIO_WAIT 0 /* calling process is to suspend until the */
67 /* operation is complete */
68#define LIO_NOWAIT 1 /* calling process is to continue execution while */
69 /* the operation is performed and no notification */
70 /* shall be given when the operation is completed */
71
72/*
73 * LIO opcodes
74 */
75#define LIO_NOP 0 /* no transfer is requested */
76#define LIO_READ 1 /* request a read() */
77#define LIO_WRITE 2 /* request a write() */
78#define LIO_SYNC 3 /* needed by aio_fsync() */
79
80/*
81 * 6.7.1.1 Asynchronous I/O Control Block, P1003.1b-1993, p. 151
82 */
83
84struct aiocb {
85 /* public */
86 int aio_fildes; /* File descriptor */
87 off_t aio_offset; /* File offset */
88 volatile void *aio_buf; /* Location of buffer */
89 size_t aio_nbytes; /* Length of transfer */
90 int aio_reqprio; /* Request priority offset */
91 struct sigevent aio_sigevent; /* Signal number and value */
92 int aio_lio_opcode; /* Operation to be performed */
93 /* private */
94 int error_code; /* Used for aio_error() */
95 ssize_t return_value; /* Used for aio_return() */
96};
97
98/*
99 * 6.7.2 Asynchronous Read, P1003.1b-1993, p. 154
100 */
101
102int aio_read(
103 struct aiocb *aiocbp
104);
105
106/*
107 * 6.7.3 Asynchronous Write, P1003.1b-1993, p. 155
108 */
109
110int aio_write(
111 struct aiocb *aiocbp
112);
113
114/*
115 * 6.7.4 List Directed I/O, P1003.1b-1993, p. 158
116 */
117
118int lio_listio(
119 int mode,
120 struct aiocb *__restrict const list[__restrict],
121 int nent,
122 struct sigevent *__restrict sig
123);
124
125/*
126 * 6.7.5 Retrieve Error of Asynchronous I/O Operation, P1003.1b-1993, p. 161
127 */
128
129int aio_error(
130 const struct aiocb *aiocbp
131);
132
133/*
134 * 6.7.6 Retrieve Return Status of Asynchronous I/O Operation,
135 * P1003.1b-1993, p. 162
136 */
137
138ssize_t aio_return(
139 const struct aiocb *aiocbp
140);
141
156int aio_cancel(
157 int filedes,
158 struct aiocb *aiocbp
159);
160
161/*
162 * 6.7.7 Wait for Asynchronous I/O Request, P1003.1b-1993, p. 164
163 */
164
165int aio_suspend(
166 const struct aiocb * const list[],
167 int nent,
168 const struct timespec *timeout
169);
170
171#if defined(_POSIX_SYNCHRONIZED_IO)
172
173/*
174 * 6.7.9 Asynchronous File Synchronization, P1003.1b-1993, p. 166
175 */
176
177int aio_fsync(
178 int op,
179 struct aiocb *aiocbp
180);
181
182#endif /* _POSIX_SYNCHRONIZED_IO */
183
184#endif /* _POSIX_ASYNCHRONOUS_IO */
185
188#ifdef __cplusplus
189}
190#endif
191
192#endif
193/* end of include file */
