19 #ifndef _RTEMS_SPTABLES_H 20 #define _RTEMS_SPTABLES_H 26 #include <rtems/config.h> 38 #if defined(RTEMS_MULTIPROCESSING) 47 #if defined(RTEMS_MULTIPROCESSING) 52 #if defined(SAPI_INIT) 53 const rtems_multiprocessing_table
54 _Initialization_Default_multiprocessing_table = {
63 extern const rtems_multiprocessing_table
64 _Initialization_Default_multiprocessing_table;
Constants and Structures Associated with the Initialization Manager.
Classic Input/Output Manager API.
#define STACK_MINIMUM_SIZE
The following constant defines the minimum stack size which every thread must exceed.
Definition: stack.h:43
Information Related to the Debug Support Within RTEMS.
