Data Structures | Functions
region.h File Reference
#include <rtems/rtems/attr.h>
#include <rtems/rtems/options.h>
#include <rtems/score/heap.h>
#include <rtems/score/threadq.h>
Include dependency graph for region.h:
struct  Region_Control
 The following records define the control block used to manage each region. More...
rtems_status_code rtems_region_create (rtems_name name, void *starting_address, uintptr_t length, uintptr_t page_size, rtems_attribute attribute_set, rtems_id *id)
 rtems_region_create More...
rtems_status_code rtems_region_extend (rtems_id id, void *starting_address, uintptr_t length)
 RTEMS Extend Region. More...
rtems_status_code rtems_region_ident (rtems_name name, rtems_id *id)
 RTEMS Region Name to Id. More...
rtems_status_code rtems_region_get_information (rtems_id id, Heap_Information_block *the_info)
 RTEMS Get Region Information. More...
rtems_status_code rtems_region_get_free_information (rtems_id id, Heap_Information_block *the_info)
 RTEMS Get Region Free Information. More...
rtems_status_code rtems_region_delete (rtems_id id)
 RTEMS Delete Region. More...
rtems_status_code rtems_region_get_segment (rtems_id id, uintptr_t size, rtems_option option_set, rtems_interval timeout, void **segment)
 RTEMS Get Region Segment. More...
rtems_status_code rtems_region_get_segment_size (rtems_id id, void *segment, uintptr_t *size)
 RTEMS Get Region Segment Size. More...
rtems_status_code rtems_region_return_segment (rtems_id id, void *segment)
 RTEMS Return Region Segment. More...
rtems_status_code rtems_region_resize_segment (rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size)
 Resize RTEMS Region Segment. More...
