| struct | Timer_Control |
| The following records define the control block used to manage each timer. More... | |
| struct | rtems_timer_information |
| This is the structure filled in by the timer get information service. More... | |
| #define | RTEMS_TIMER_SERVER_DEFAULT_PRIORITY (uint32_t) -1 |
| This is the default value for the priority of the Timer Server. More... | |
Typedefs | |
| typedef void | rtems_timer_service_routine |
| The following types define a pointer to a timer service routine. | |
| typedef rtems_timer_service_routine(* | rtems_timer_service_routine_entry) (rtems_id, void *) |
| This type defines the type used to manage and indirectly invoke Timer Service Routines (TSRs). More... | |
Enumerations | |
| enum | Timer_Classes { TIMER_INTERVAL, TIMER_INTERVAL_ON_TASK, TIMER_TIME_OF_DAY, TIMER_TIME_OF_DAY_ON_TASK, TIMER_DORMANT } |
| The following enumerated type details the classes to which a timer may belong. More... | |
