41 #ifndef _RTEMS_RTEMS_TIMER_H 42 #define _RTEMS_RTEMS_TIMER_H 316 #define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY (uint32_t) -1 This value indicates the timer is currently in use as an time of day timer which will fire in the tim...
Definition: timer.h:93
uint32_t rtems_attribute
This defines the type used to contain Classic API attributes.
Definition: attr.h:44
rtems_status_code rtems_timer_cancel(rtems_id id)
rtems_timer_cancel
Definition: timercancel.c:38
The following defines the Object Control Block used to manage each object local to this node...
Definition: object.h:232
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:80
This value indicates the timer is currently in use as an interval timer which will fire in the clock ...
Definition: timer.h:75
rtems_status_code rtems_timer_fire_after(rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Fire After.
Definition: timerfireafter.c:28
The control block used to manage each watchdog timer.
Definition: watchdog.h:98
This value indicates the timer is currently not in use.
Definition: timer.h:98
rtems_status_code rtems_timer_delete(rtems_id id)
RTEMS Delete Timer.
Definition: timerdelete.c:28
Objects_Control Object
This field is the object management portion of a Timer instance.
Definition: timer.h:122
rtems_status_code rtems_timer_server_fire_when(rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Server Fire When Directive.
Definition: timerserverfirewhen.c:43
This value indicates the timer is currently in use as an interval timer which will fire in the timer ...
Definition: timer.h:81
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:119
rtems_status_code rtems_timer_create(rtems_name name, rtems_id *id)
RTEMS Create Timer.
Definition: timercreate.c:57
Data structure to manage and manipulate calendar time.
Definition: types.h:133
rtems_status_code
Classic API Status.
Definition: status.h:46
rtems_status_code rtems_timer_ident(rtems_name name, rtems_id *id)
RTEMS Timer Name to Id.
Definition: timerident.c:28
rtems_status_code rtems_timer_reset(rtems_id id)
RTEMS Timer Reset.
Definition: timerreset.c:41
rtems_status_code rtems_timer_fire_when(rtems_id id, rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Fire When.
Definition: timerfirewhen.c:26
uint32_t rtems_name
Classic API object name type.
Definition: types.h:74
Watchdog_Control Ticker
This field is the Watchdog instance which will be the scheduled.
Definition: timer.h:124
rtems_status_code rtems_timer_get_information(rtems_id id, rtems_timer_information *the_info)
RTEMS Get Timer Information.
Definition: timergetinfo.c:28
rtems_status_code rtems_timer_initiate_server(uint32_t priority, uint32_t stack_size, rtems_attribute attribute_set)
Definition: timerserver.c:323
rtems_status_code rtems_timer_server_fire_after(rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data)
RTEMS Timer Server Fire After.
Definition: timerserverfireafter.c:28
Timer_Classes
The following enumerated type details the classes to which a timer may belong.
Definition: timer.h:70
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdog.h:47
This value indicates the timer is currently in use as an time of day timer which will fire in the clo...
Definition: timer.h:87
Timer_Classes the_class
This field indicates what type of timer this currently is.
Definition: timer.h:126
The following records define the control block used to manage each timer.
Definition: timer.h:120
rtems_timer_service_routine(* rtems_timer_service_routine_entry)(rtems_id, void *)
This type defines the type used to manage and indirectly invoke Timer Service Routines (TSRs)...
Definition: timer.h:111
void rtems_timer_service_routine
The following types define a pointer to a timer service routine.
Definition: timer.h:104
